root/radiance/ray/src/common/bmalloc.c
Revision: 2.3
Committed: Sat Feb 22 02:07:21 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.2: +71 -16 lines
5 * Bmalloc provides basic memory allocation without overhead (no free lists).
6 * Use only to take the load off of malloc for all those
7 * piddling little requests that you never expect to free.
8 * Bmalloc defers to malloc for big requests.
9 * Bfree should hand memory to bmalloc, but it usually fails here.
10 *
11 * External symbols declared in standard.h
12 */
13
14 /* ====================================================================
15 * The Radiance Software License, Version 1.0
16 *
17 * Copyright (c) 1990 - 2002 The Regents of the University of California,
18 * through Lawrence Berkeley National Laboratory. All rights reserved.
19 *
20 * Redistribution and use in source and binary forms, with or without
21 * modification, are permitted provided that the following conditions
22 * are met:
23 *
24 * 1. Redistributions of source code must retain the above copyright
25 * notice, this list of conditions and the following disclaimer.
26 *
27 * 2. Redistributions in binary form must reproduce the above copyright
28 * notice, this list of conditions and the following disclaimer in
29 * the documentation and/or other materials provided with the
30 * distribution.
31 *
32 * 3. The end-user documentation included with the redistribution,
33 * if any, must include the following acknowledgment:
34 * "This product includes Radiance software
35 * (http://radsite.lbl.gov/)
36 * developed by the Lawrence Berkeley National Laboratory
37 * (http://www.lbl.gov/)."
38 * Alternately, this acknowledgment may appear in the software itself,
39 * if and wherever such third-party acknowledgments normally appear.
40 *
41 * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
42 * and "The Regents of the University of California" must
43 * not be used to endorse or promote products derived from this
44 * software without prior written permission. For written
45 * permission, please contact [email protected].
46 *
47 * 5. Products derived from this software may not be called "Radiance",
48 * nor may "Radiance" appear in their name, without prior written
49 * permission of Lawrence Berkeley National Laboratory.
50 *
51 * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
52 * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
53 * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
54 * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
55 * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
56 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
57 * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
58 * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
59 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
60 * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
61 * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
62 * SUCH DAMAGE.
63 * ====================================================================
64 *
65 * This software consists of voluntary contributions made by many
66 * individuals on behalf of Lawrence Berkeley National Laboratory. For more
67 * information on Lawrence Berkeley National Laboratory, please see
68 * <http://www.lbl.gov/>.
69 */
70
71 #include <stdlib.h>
72
73 #ifndef MBLKSIZ
74 #define MBLKSIZ 16376 /* size of memory allocation block */
75 #endif
76 #define WASTEFRAC 12 /* don't waste more than a fraction */
77 #ifndef ALIGNT
78 #define ALIGNT double /* type for alignment */
79 #endif
80 #define BYTES_WORD sizeof(ALIGNT)
81
82 static char *bposition = NULL;
83 static unsigned int nremain = 0;
84
85
86 char *
87 bmalloc(n) /* allocate a block of n bytes */
88 register unsigned int n;
89 {
90 if (n > nremain && (n > MBLKSIZ || nremain > MBLKSIZ/WASTEFRAC))
91 return(malloc(n)); /* too big */
92
93 n = (n+(BYTES_WORD-1))&~(BYTES_WORD-1); /* word align */
94
95 if (n > nremain && (bposition = (char *)malloc(nremain = MBLKSIZ)) == NULL) {
96 nremain = 0;
97 return(NULL);
98 }
99 bposition += n;
100 nremain -= n;
101 return(bposition - n);
102 }
103
104
105 void
106 bfree(p, n) /* free random memory */
107 register char *p;
108 register unsigned int n;
109 {
110 register unsigned int bsiz;
111 /* check alignment */
112 bsiz = BYTES_WORD - ((unsigned int)p&(BYTES_WORD-1));
113 if (bsiz < BYTES_WORD) {
114 p += bsiz;
115 n -= bsiz;
116 }
117 if (p + n == bposition) { /* just allocated? */
118 bposition = p;
119 nremain += n;
120 return;
121 }
122 if (n > nremain) { /* better than what we've got? */
123 bposition = p;
124 nremain = n;
125 return;
126 }
127 /* just throw it away, then */
128 }
