root/radiance/ray/src/common/badarg.c
Revision: 2.8
Committed: Fri Feb 28 21:03:40 2014 UTC (11 years, 5 months ago) by greg
Changed isascii call to isprint in hopes this will work in non-ASCII locales
2 static const char RCSid[] = "$Id: badarg.c,v 2.7 2012/06/10 17:50:29 greg Exp $";
5 * Check argument list against format string.
6 *
7 * External symbols declared in rtio.h
8 */
9
10 #include "copyright.h"
11
12 #include <ctype.h>
13
14 #include "rtio.h"
15
16
17 int
18 badarg( /* check argument list */
19 int ac,
20 char **av,
21 char *fl
22 )
23 {
24 int i;
25 char *s;
26
27 if (fl == NULL)
28 fl = ""; /* no arguments? */
29 for (i = 1; *fl; i++,av++,fl++) {
30 if (i > ac || *av == NULL)
31 return(-1);
32 s = *av;
33 switch (*fl) {
34 case 's': /* string */
35 while (isspace(*s))
36 ++s;
37 if (*s == '\0')
38 return(i);
39 while (*s)
40 if (!isprint(*s++))
41 return(i);
42 break;
43 case 'i': /* integer */
44 if (!isintd(s, " \t\r\n"))
45 return(i);
46 break;
47 case 'f': /* float */
48 if (!isfltd(s, " \t\r\n"))
49 return(i);
50 break;
51 default: /* bad call! */
52 return(-1);
53 }
54 }
55 return(0); /* all's well */
56 }
