root/radiance/ray/src/common/badarg.c
Fri Mar 7 17:32:12 2014 UTC (10 years, 3 months ago) by greg
Changes since 2.10: +8 -6 lines
Fixed problem with newlines in string arguments, which should be allowed
Sat Mar 1 18:56:41 2014 UTC (10 years, 3 months ago) by greg
Changes since 2.9: +1 -3 lines
Removed unnecessary test (whoops)
Sat Mar 1 18:54:08 2014 UTC (10 years, 3 months ago) by greg
Changes since 2.8: +6 -5 lines
Minor consistency correction for string check
Fri Feb 28 21:03:40 2014 UTC (10 years, 3 months ago) by greg
Changed isascii call to isprint in hopes this will work in non-ASCII locales
Sun Jun 10 17:50:29 2012 UTC (11 years, 11 months ago) by greg
Changes since 2.6: +14 -7 lines
Made more accepting of strings that start with a space
Sat Jun 7 12:50:20 2003 UTC (21 years ago) by schorsch
Changes since 2.2: +1 -56 lines
Changes since 2.1: +60 -4 lines
Tue Nov 12 16:56:14 1991 UTC (32 years, 7 months ago) by greg
Fri Nov 8 09:58:38 1991 UTC (32 years, 7 months ago) by greg
Changes since 1.1: +5 -3 lines
added acceptance of larger delimiter set
Thu Nov 7 11:03:34 1991 UTC (32 years, 7 months ago) by greg
Diff to selected 2.2
