root/radiance/ray/src/common/badarg.c
Revision: 2.4
Committed: Sat Jun 7 12:50:20 2003 UTC (22 years, 2 months ago) by schorsch
2 static const char RCSid[] = "$Id: badarg.c,v 2.3 2003/02/25 02:47:21 greg Exp $";
5 * Check argument list against format string.
6 *
7 * External symbols declared in standard.h
8 */
9
10 #include "copyright.h"
11
12 #include <ctype.h>
13
14 #include "standard.h"
15
16
17 int
18 badarg(ac, av, fl) /* check argument list */
19 int ac;
20 register char **av;
21 register char *fl;
22 {
23 register int i;
24
25 if (fl == NULL)
26 fl = ""; /* no arguments? */
27 for (i = 1; *fl; i++,av++,fl++) {
28 if (i > ac || *av == NULL)
29 return(-1);
30 switch (*fl) {
31 case 's': /* string */
32 if (**av == '\0' || isspace(**av))
33 return(i);
34 break;
35 case 'i': /* integer */
36 if (!isintd(*av, " \t\r\n"))
37 return(i);
38 break;
39 case 'f': /* float */
40 if (!isfltd(*av, " \t\r\n"))
41 return(i);
42 break;
43 default: /* bad call! */
44 return(-1);
45 }
46 }
47 return(0); /* all's well */
48 }
