| 1 |
greg |
2.2 |
/* RCSid $Id$ */ |
| 2 |
greg |
2.1 |
| 3 |
 *  abitmap.h |
| 4 |
 *  panlib |
| 5 |
| 6 |
 *  General bitmap class (mostly inline) |
| 7 |
| 8 |
 *  Created by gward on Tue May 15 2001. |
| 9 |
 *  Copyright (c) 2001 Anyhere Software. All rights reserved. |
| 10 |
| 11 |
| 12 |
#ifndef _ABITMAP_H_ |
| 13 |
#define _ABITMAP_H_ |
| 14 |
| 15 |
#ifndef _TIFF_ |
| 16 |
#include "tiff.h"               /* needed for uint32 type */ |
| 17 |
#endif |
| 18 |
| 19 |
#define ABMend          0xffffffff      // terminal return |
| 20 |
| 21 |
// Inline bitmap class |
| 22 |
class ABitMap { |
| 23 |
private: |
| 24 |
        uint32 *        bmap;           // bitmap storage |
| 25 |
        uint32          len;            // bitmap size |
| 26 |
public: |
| 27 |
                        ABitMap() { len=0; bmap=0; } |
| 28 |
                        ABitMap(uint32 n, bool clrset=false) { |
| 29 |
                                bmap=0; len=0; NewBitMap(n,clrset); |
| 30 |
| 31 |
                        ABitMap(const ABitMap &orig) { |
| 32 |
                                bmap=0; len=0; *this=orig; |
| 33 |
| 34 |
                        ~ABitMap() { |
| 35 |
                                delete [] bmap; |
| 36 |
| 37 |
                        // Access to raw word data |
| 38 |
        uint32 *        base() { |
| 39 |
                                return bmap; |
| 40 |
| 41 |
                        // Read-only word access |
| 42 |
        const uint32 *  base() const { |
| 43 |
                                return bmap; |
| 44 |
| 45 |
                        // Number of words from #bits |
| 46 |
        static int32    bmlen(uint32 nbits) { |
| 47 |
                                return (nbits+0x1f)>>5; |
| 48 |
| 49 |
                        // Total number of words |
| 50 |
        int32           bmlen() const { |
| 51 |
                                return bmlen(len); |
| 52 |
| 53 |
                        // Reallocate and clear bitmap |
| 54 |
        bool            NewBitMap(uint32 n, bool clrset=false); |
| 55 |
                        // Clear bitmap to all 0's or 1's |
| 56 |
        void            ClearBitMap(bool clrset=false); |
| 57 |
                        // Steal another bitmap's contents |
| 58 |
        bool            Take(ABitMap *srcp) { |
| 59 |
                                if (srcp == this) return false; |
| 60 |
                                delete [] bmap; bmap=0; len=0; |
| 61 |
                                if (!srcp) return false; |
| 62 |
                                bmap=srcp->bmap; len=srcp->len; |
| 63 |
                                srcp->bmap=0; srcp->len=0; |
| 64 |
                                return len; |
| 65 |
| 66 |
                        // Return number of bits in bitmap |
| 67 |
        uint32          Length() const { |
| 68 |
                                return len; |
| 69 |
| 70 |
                        // Get original length if RLE (or 0) |
| 71 |
        uint32          RLength() const; |
| 72 |
                        // Compress into a run-length encoded bitmap |
| 73 |
        bool            GetRLE(ABitMap *rlep) const; |
| 74 |
                        // Reconstitute bits from RLE encoding |
| 75 |
        bool            SetFromRLE(const ABitMap &rle); |
| 76 |
                        // Extract bitmap section (true if some overlap) |
| 77 |
        bool            GetBits(ABitMap *dp, uint32 i) const; |
| 78 |
                        // Extract bitmap section (fill if past end) |
| 79 |
        ABitMap         GetBits(uint32 i, uint32 n, bool fill=false) const { |
| 80 |
                                ABitMap bm(n, fill); |
| 81 |
                                GetBits(&bm, i); |
| 82 |
                                return bm; |
| 83 |
| 84 |
                        // Overlay bitmap section (ignores bits past end) |
| 85 |
        bool            AssignBits(uint32 i, const ABitMap &src); |
| 86 |
                        // Apply operation to bitmap section |
| 87 |
        bool            OpBits(uint32 i, char op, const ABitMap &src); |
| 88 |
                        // Clear bitmap section |
| 89 |
        void            ClearBits(uint32 i, uint32 n, bool clrset=false); |
| 90 |
                        // Clear bits set in second bitmap |
| 91 |
        bool            ClearBitsFrom(const ABitMap &src); |
| 92 |
                        // Count number of bits set in bitmap |
| 93 |
        uint32          SumTotal(bool bit2cnt = true) const; |
| 94 |
                        // Return the next bit position matching val (or ABMend) |
| 95 |
        uint32          Find(uint32 i = 0, bool val = true) const; |
| 96 |
        uint32          Find(int i, bool val = true) const { |
| 97 |
                                return Find((uint32)i, val); |
| 98 |
| 99 |
        uint32          Find(long i, bool val = true) const { |
| 100 |
| 101 |
| 102 |
                        // Different interface to find the next bit matching val |
| 103 |
        bool            Find(uint32 *ip, bool val = true) const { |
| 104 |
                                if (!ip) return false; |
| 105 |
                                if (*ip >= len) return false; |
| 106 |
                                *ip = Find(*ip, val); |
| 107 |
                                return (*ip < len); |
| 108 |
| 109 |
                        // Access word for i'th bit |
| 110 |
        uint32 &        Word(uint32 i) { |
| 111 |
                                static uint32   dummy; |
| 112 |
                                if (i >= len) return dummy; |
| 113 |
                                return bmap[i>>5]; |
| 114 |
| 115 |
                        // Get word value for i'th bit (0 if out of range) |
| 116 |
        uint32          WordV(uint32 i) const { |
| 117 |
                                if (i >= len) return 0; |
| 118 |
| 119 |
| 120 |
                        // Index corresponding bit in word |
| 121 |
        static uint32   Bit(uint32 i) { |
| 122 |
                                return 1 << (i & 0x1f); |
| 123 |
| 124 |
                        // Return value of i'th bit in bitmap |
| 125 |
        bool            Check(uint32 i) const { |
| 126 |
                                return (WordV(i) & Bit(i)); |
| 127 |
| 128 |
                        // Set i'th bit |
| 129 |
        void            Set(uint32 i) { |
| 130 |
                                Word(i) |= Bit(i); |
| 131 |
| 132 |
                        // Reset i'th bit |
| 133 |
        void            Reset(uint32 i) { |
| 134 |
                                Word(i) &= ~Bit(i); |
| 135 |
| 136 |
                        // Set i'th bit explicitly on or off |
| 137 |
        void            Set(uint32 i, bool switchon) { |
| 138 |
                                uint32          b = Bit(i); |
| 139 |
                                uint32 &        w = Word(i); |
| 140 |
                                if (switchon) w |= b; |
| 141 |
                                else w &= ~b; |
| 142 |
| 143 |
                        // Toggle i'th bit |
| 144 |
        void            Toggle(uint32 i) { |
| 145 |
                                Word(i) ^= Bit(i); |
| 146 |
| 147 |
                        // Set i'th bit if it's clear (or fail) |
| 148 |
        bool            TestAndSet(uint32 i) { |
| 149 |
                                if (i >= len) return false; |
| 150 |
| 151 |
| 152 |
                                uint32          wasset = w & b; |
| 153 |
                                w |= b; |
| 154 |
                                return !wasset; |
| 155 |
| 156 |
                        // Clear i'th bit if it's set (or fail) |
| 157 |
        bool            TestAndReset(uint32 i) { |
| 158 |
| 159 |
| 160 |
| 161 |
| 162 |
                                w &= ~b; |
| 163 |
                                return wasset; |
| 164 |
| 165 |
                        // Set i'th bit on/off (fail if no change) |
| 166 |
        bool            TestAndSet(uint32 i, bool switchon) { |
| 167 |
                                return switchon ? TestAndSet(i) : TestAndReset(i); |
| 168 |
| 169 |
                        // Invert the entire bitmap |
| 170 |
        void            Invert(); |
| 171 |
                        // Downward shift operator, zero fill |
| 172 |
        ABitMap &       operator>>=(uint32 nbits); |
| 173 |
                        // Upward shift operator, zero fill |
| 174 |
        ABitMap &       operator<<=(uint32 nbits); |
| 175 |
                        // Copy operator |
| 176 |
        ABitMap &       operator=(const ABitMap &src); |
| 177 |
                        // Bitwise OR-copy operator |
| 178 |
        ABitMap &       operator|=(const ABitMap &src); |
| 179 |
                        // Bitwise AND-assign operator |
| 180 |
        ABitMap &       operator&=(const ABitMap &src); |
| 181 |
                        // Bitwise XOR-assign operator |
| 182 |
        ABitMap &       operator^=(const ABitMap &src); |
| 183 |
                        // Subtraction operator, synonym for ClearBitsFrom() |
| 184 |
        ABitMap &       operator-=(const ABitMap &src) { |
| 185 |
                                ClearBitsFrom(src); |
| 186 |
                                return *this; |
| 187 |
| 188 |
                        // Compare two bitmaps for equality |
| 189 |
        bool            operator==(const ABitMap &that) const; |
| 190 |
| 191 |
| 192 |
inline bool |
| 193 |
operator!=(const ABitMap &bm1, const ABitMap &bm2) |
| 194 |
| 195 |
        return !(bm1 == bm2); |
| 196 |
| 197 |
| 198 |
inline ABitMap |
| 199 |
operator>>(ABitMap bmLeft, uint32 nbr) |
| 200 |
| 201 |
        return bmLeft >>= nbr; |
| 202 |
| 203 |
| 204 |
inline ABitMap |
| 205 |
operator<<(ABitMap bmLeft, uint32 nbl) |
| 206 |
| 207 |
        return bmLeft <<= nbl; |
| 208 |
| 209 |
| 210 |
inline ABitMap |
| 211 |
operator|(ABitMap bmLeft, const ABitMap &bmRight) |
| 212 |
| 213 |
        return bmLeft |= bmRight; |
| 214 |
| 215 |
| 216 |
inline ABitMap |
| 217 |
operator&(ABitMap bmLeft, const ABitMap &bmRight) |
| 218 |
| 219 |
        return bmLeft &= bmRight; |
| 220 |
| 221 |
| 222 |
inline ABitMap |
| 223 |
operator^(ABitMap bmLeft, const ABitMap &bmRight) |
| 224 |
| 225 |
        return bmLeft ^= bmRight; |
| 226 |
| 227 |
| 228 |
inline ABitMap |
| 229 |
operator-(ABitMap bmLeft, const ABitMap &bmRight) |
| 230 |
| 231 |
        return bmLeft -= bmRight; |
| 232 |
| 233 |
| 234 |
inline ABitMap |
| 235 |
operator~(ABitMap bmUnary) |
| 236 |
| 237 |
        bmUnary.Invert(); |
| 238 |
        return bmUnary; |
| 239 |
| 240 |
| 241 |
// 2-dimensional bitmap class |
| 242 |
class ABitMap2 : protected ABitMap { |
| 243 |
private: |
| 244 |
        int             width, height;          // bitmap dimensions |
| 245 |
protected: |
| 246 |
        uint32          bmi(int x, int y) const { |
| 247 |
                                if (OffBitMap(x, y)) return ABMend; |
| 248 |
                                return (uint32)y*width + x; |
| 249 |
| 250 |
public: |
| 251 |
                        ABitMap2() { width=height=0; } |
| 252 |
                        ABitMap2(int w, int h, bool clrset=false) : |
| 253 |
                                        ABitMap((w>0)&(h>0)&&(w <= ABMend/h) |
| 254 |
                                                ? (uint32)w*h : (uint32)0, clrset) { |
| 255 |
                                if (Length()) { |
| 256 |
                                        width=w; height=h; |
| 257 |
                                } else { width=height=0; } |
| 258 |
| 259 |
                        ABitMap2(const ABitMap2 &orig) { |
| 260 |
                                *this=orig; |
| 261 |
| 262 |
| 263 |
        uint32 *        base() { |
| 264 |
                                return ABitMap::base(); |
| 265 |
| 266 |
| 267 |
| 268 |
| 269 |
| 270 |
| 271 |
| 272 |
                                return ABitMap::bmlen(); |
| 273 |
| 274 |
                        // Return bitmap width |
| 275 |
        int             Width() const { |
| 276 |
                                return width; |
| 277 |
| 278 |
                        // Return bitmap height |
| 279 |
        int             Height() const { |
| 280 |
                                return height; |
| 281 |
| 282 |
                        // Is the indicated bit off our bitmap? |
| 283 |
        bool            OffBitMap(int x, int y) const { |
| 284 |
                                return ((x < 0) | (x >= width) | |
| 285 |
                                        (y < 0) | (y >= height)); |
| 286 |
| 287 |
| 288 |
        uint32          SumTotal(bool bit2cnt = true) const { |
| 289 |
                                return ABitMap::SumTotal(bit2cnt); |
| 290 |
| 291 |
| 292 |
        bool            NewBitMap(int w, int h, bool clrset=false) { |
| 293 |
                                if ((w <= 0) | (h <= 0) || w > ABMend/h) |
| 294 |
                                        w = h = 0; |
| 295 |
| 296 |
                                return ABitMap::NewBitMap((uint32)w*h, clrset); |
| 297 |
| 298 |
| 299 |
        void            ClearBitMap(bool clrset=false) { |
| 300 |
                                ABitMap::ClearBitMap(clrset); |
| 301 |
| 302 |
                        // Compress with run-length encoding into a 1-D bitmap |
| 303 |
        bool            GetRLE(ABitMap *rlep) const { |
| 304 |
                                return ABitMap::GetRLE(rlep); |
| 305 |
| 306 |
                        // Reconstitute bits from RLE encoding (size must match) |
| 307 |
        bool            SetFromRLE(int w, int h, const ABitMap &rle); |
| 308 |
| 309 |
        bool            Take(ABitMap2 *srcp) { |
| 310 |
| 311 |
                                width=height=0; |
| 312 |
                                if (!ABitMap::Take(srcp)) return false; |
| 313 |
                                width=srcp->width; height=srcp->height; |
| 314 |
                                srcp->width=srcp->height=0; |
| 315 |
                                return true; |
| 316 |
| 317 |
| 318 |
        bool            GetRect(ABitMap2 *dp, int sx, int sy) const; |
| 319 |
                        // Extract bitmap section (fill outside overlap) |
| 320 |
        ABitMap2        GetRect(int sx, int sy, int w, int h, bool fill=false) const { |
| 321 |
                                ABitMap2        bm2(w, h, fill); |
| 322 |
                                GetRect(&bm2, sx, sy); |
| 323 |
                                return bm2; |
| 324 |
| 325 |
                        // Assign bitmap section (ignores anything past edges) |
| 326 |
        bool            AssignRect(int dx, int dy, const ABitMap2 &src); |
| 327 |
| 328 |
        bool            OpRect(int dx, int dy, char op, const ABitMap2 &src); |
| 329 |
                        // Clear a rectangle |
| 330 |
        void            ClearRect(int x, int y, int w, int h, bool clrset=false); |
| 331 |
                        // Find the next bit matching val (scanline order) |
| 332 |
        bool            Find(int *xp, int *yp, bool val=true) const { |
| 333 |
                                if (!xp | !yp) return false; |
| 334 |
                                if (width <= 0) return false; |
| 335 |
                                if ((*xp < 0) | (*yp < 0)) *xp = *yp = 0; |
| 336 |
                                else if (*xp >= width) { *xp=0; ++(*yp); } |
| 337 |
                                uint32  i = ABitMap::Find(bmi(*xp,*yp), val); |
| 338 |
                                if (i == ABMend) { *yp = height; return false; } |
| 339 |
                                *yp = int(i / width); |
| 340 |
                                *xp = int(i - *yp*width); |
| 341 |
                                return true; |
| 342 |
| 343 |
                        // Get bounds of assigned region |
| 344 |
        bool            GetBoundRect(int xymin[2], int wh[2], bool val=true) const; |
| 345 |
                        // Return value of bit in bitmap |
| 346 |
        bool            Check(int x, int y) const { |
| 347 |
                                return ABitMap::Check(bmi(x,y)); |
| 348 |
| 349 |
                        // Set bit |
| 350 |
        void            Set(int x, int y) { |
| 351 |
                                ABitMap::Set(bmi(x,y)); |
| 352 |
| 353 |
                        // Reset bit |
| 354 |
        void            Reset(int x, int y) { |
| 355 |
                                ABitMap::Reset(bmi(x,y)); |
| 356 |
| 357 |
                        // Set bit explicitly on or off |
| 358 |
        void            Set(int x, int y, bool switchon) { |
| 359 |
                                ABitMap::Set(bmi(x,y), switchon); |
| 360 |
| 361 |
                        // Toggle bit |
| 362 |
        void            Toggle(int x, int y) { |
| 363 |
                                ABitMap::Toggle(bmi(x,y)); |
| 364 |
| 365 |
                        // Set bit if it's clear (or fail) |
| 366 |
        bool            TestAndSet(int x, int y) { |
| 367 |
                                return ABitMap::TestAndSet(bmi(x,y)); |
| 368 |
| 369 |
                        // Clear bit if it's set (or fail) |
| 370 |
        bool            TestAndReset(int x, int y) { |
| 371 |
                                return ABitMap::TestAndReset(bmi(x,y)); |
| 372 |
| 373 |
                        // Set bit on/off (fail if no change) |
| 374 |
        bool            TestAndSet(int x, int y, bool switchon) { |
| 375 |
                                return ABitMap::TestAndSet(bmi(x,y), switchon); |
| 376 |
| 377 |
| 378 |
        void            Invert() { |
| 379 |
                                ABitMap::Invert(); |
| 380 |
| 381 |
                        // Shift bitmap, filling uncovered area as indicated |
| 382 |
        void            Shift(int dx, int dy, int fill=0); |
| 383 |
                        // Dilate (or erode) selection by given radius |
| 384 |
        void            Expand(double rad, bool val=true); |
| 385 |
                        // Clear bits set in second map |
| 386 |
        bool            ClearBitsFrom(const ABitMap2 &src) { |
| 387 |
                                if (width != src.width) |
| 388 |
                                        return false; |
| 389 |
                                return ABitMap::ClearBitsFrom(src); |
| 390 |
| 391 |
                        // Copy operator |
| 392 |
        ABitMap2 &      operator=(const ABitMap2 &src) { |
| 393 |
                                ABitMap::operator=(src); |
| 394 |
                                width=src.width; height=src.height; |
| 395 |
                                return *this; |
| 396 |
| 397 |
| 398 |
        ABitMap2 &      operator|=(const ABitMap2 &src) { |
| 399 |
                                ABitMap::operator|=(src); |
| 400 |
| 401 |
                                return *this; |
| 402 |
| 403 |
| 404 |
        ABitMap2 &      operator&=(const ABitMap2 &src) { |
| 405 |
                                if ((width!=src.width)|(height!=src.height)) |
| 406 |
                                        return *this; |
| 407 |
                                ABitMap::operator&=(src); |
| 408 |
                                return *this; |
| 409 |
| 410 |
| 411 |
        ABitMap2 &      operator^=(const ABitMap2 &src) { |
| 412 |
| 413 |
                                        return *this; |
| 414 |
                                ABitMap::operator^=(src); |
| 415 |
                                return *this; |
| 416 |
| 417 |
| 418 |
        ABitMap2 &      operator-=(const ABitMap2 &src) { |
| 419 |
| 420 |
                                return *this; |
| 421 |
| 422 |
| 423 |
        bool            operator==(const ABitMap2 &that) const { |
| 424 |
                                if (width != that.width) |
| 425 |
                                        return false; |
| 426 |
                                return ABitMap::operator==(that); |
| 427 |
| 428 |
| 429 |
| 430 |
inline bool |
| 431 |
operator!=(const ABitMap2 &bm1, const ABitMap2 &bm2) |
| 432 |
| 433 |
| 434 |
| 435 |
| 436 |
inline ABitMap2 |
| 437 |
operator|(ABitMap2 bmLeft, const ABitMap2 &bmRight) |
| 438 |
| 439 |
| 440 |
| 441 |
| 442 |
inline ABitMap2 |
| 443 |
operator&(ABitMap2 bmLeft, const ABitMap2 &bmRight) |
| 444 |
| 445 |
| 446 |
| 447 |
| 448 |
inline ABitMap2 |
| 449 |
operator^(ABitMap2 bmLeft, const ABitMap2 &bmRight) |
| 450 |
| 451 |
| 452 |
| 453 |
| 454 |
inline ABitMap2 |
| 455 |
operator-(ABitMap2 bmLeft, const ABitMap2 &bmRight) |
| 456 |
| 457 |
| 458 |
| 459 |
| 460 |
inline ABitMap2 |
| 461 |
operator~(ABitMap2 bmUnary) |
| 462 |
| 463 |
        bmUnary.Invert(); |
| 464 |
        return bmUnary; |
| 465 |
| 466 |
| 467 |
// Function to write a bitmap to a BMP file |
| 468 |
extern bool     WriteBitMap(const ABitMap &bm, const char *fname); |
| 469 |
| 470 |
// Function to write a 2-D bitmap to a BMP file |
| 471 |
extern bool     WriteBitMap2(const ABitMap2 &bm2, const char *fname); |
| 472 |
| 473 |
// Function to read a bitmap from a BMP file |
| 474 |
extern bool     ReadBitMap(ABitMap *bmp, const char *fname); |
| 475 |
| 476 |
// Function to read a 2-D bitmap from a BMP file |
| 477 |
extern bool     ReadBitMap2(ABitMap2 *bm2p, const char *fname); |
| 478 |
| 479 |
#endif  // ! _ABITMAP_H_ |
