root/radiance/ray/src/common/abitmap.h
Revision: 2.1
Committed: Wed Aug 14 20:05:23 2024 UTC (8 months, 4 weeks ago) by greg
1 /*
2 * abitmap.h
3 * panlib
4 *
5 * General bitmap class (mostly inline)
6 *
7 * Created by gward on Tue May 15 2001.
8 * Copyright (c) 2001 Anyhere Software. All rights reserved.
9 *
10 */
11 #ifndef _ABITMAP_H_
12 #define _ABITMAP_H_
13
14 #ifndef _TIFF_
15 #include "tiff.h" /* needed for uint32 type */
16 #endif
17
18 #define ABMend 0xffffffff // terminal return
19
20 // Inline bitmap class
21 class ABitMap {
22 private:
23 uint32 * bmap; // bitmap storage
24 uint32 len; // bitmap size
25 public:
26 ABitMap() { len=0; bmap=0; }
27 ABitMap(uint32 n, bool clrset=false) {
28 bmap=0; len=0; NewBitMap(n,clrset);
29 }
30 ABitMap(const ABitMap &orig) {
31 bmap=0; len=0; *this=orig;
32 }
33 ~ABitMap() {
34 delete [] bmap;
35 }
36 // Access to raw word data
37 uint32 * base() {
38 return bmap;
39 }
40 // Read-only word access
41 const uint32 * base() const {
42 return bmap;
43 }
44 // Number of words from #bits
45 static int32 bmlen(uint32 nbits) {
46 return (nbits+0x1f)>>5;
47 }
48 // Total number of words
49 int32 bmlen() const {
50 return bmlen(len);
51 }
52 // Reallocate and clear bitmap
53 bool NewBitMap(uint32 n, bool clrset=false);
54 // Clear bitmap to all 0's or 1's
55 void ClearBitMap(bool clrset=false);
56 // Steal another bitmap's contents
57 bool Take(ABitMap *srcp) {
58 if (srcp == this) return false;
59 delete [] bmap; bmap=0; len=0;
60 if (!srcp) return false;
61 bmap=srcp->bmap; len=srcp->len;
62 srcp->bmap=0; srcp->len=0;
63 return len;
64 }
65 // Return number of bits in bitmap
66 uint32 Length() const {
67 return len;
68 }
69 // Get original length if RLE (or 0)
70 uint32 RLength() const;
71 // Compress into a run-length encoded bitmap
72 bool GetRLE(ABitMap *rlep) const;
73 // Reconstitute bits from RLE encoding
74 bool SetFromRLE(const ABitMap &rle);
75 // Extract bitmap section (true if some overlap)
76 bool GetBits(ABitMap *dp, uint32 i) const;
77 // Extract bitmap section (fill if past end)
78 ABitMap GetBits(uint32 i, uint32 n, bool fill=false) const {
79 ABitMap bm(n, fill);
80 GetBits(&bm, i);
81 return bm;
82 }
83 // Overlay bitmap section (ignores bits past end)
84 bool AssignBits(uint32 i, const ABitMap &src);
85 // Apply operation to bitmap section
86 bool OpBits(uint32 i, char op, const ABitMap &src);
87 // Clear bitmap section
88 void ClearBits(uint32 i, uint32 n, bool clrset=false);
89 // Clear bits set in second bitmap
90 bool ClearBitsFrom(const ABitMap &src);
91 // Count number of bits set in bitmap
92 uint32 SumTotal(bool bit2cnt = true) const;
93 // Return the next bit position matching val (or ABMend)
94 uint32 Find(uint32 i = 0, bool val = true) const;
95 uint32 Find(int i, bool val = true) const {
96 return Find((uint32)i, val);
97 }
98 uint32 Find(long i, bool val = true) const {
99 return Find((uint32)i, val);
100 }
101 // Different interface to find the next bit matching val
102 bool Find(uint32 *ip, bool val = true) const {
103 if (!ip) return false;
104 if (*ip >= len) return false;
105 *ip = Find(*ip, val);
106 return (*ip < len);
107 }
108 // Access word for i'th bit
109 uint32 & Word(uint32 i) {
110 static uint32 dummy;
111 if (i >= len) return dummy;
112 return bmap[i>>5];
113 }
114 // Get word value for i'th bit (0 if out of range)
115 uint32 WordV(uint32 i) const {
116 if (i >= len) return 0;
117 return bmap[i>>5];
118 }
119 // Index corresponding bit in word
120 static uint32 Bit(uint32 i) {
121 return 1 << (i & 0x1f);
122 }
123 // Return value of i'th bit in bitmap
124 bool Check(uint32 i) const {
125 return (WordV(i) & Bit(i));
126 }
127 // Set i'th bit
128 void Set(uint32 i) {
129 Word(i) |= Bit(i);
130 }
131 // Reset i'th bit
132 void Reset(uint32 i) {
133 Word(i) &= ~Bit(i);
134 }
135 // Set i'th bit explicitly on or off
136 void Set(uint32 i, bool switchon) {
137 uint32 b = Bit(i);
138 uint32 & w = Word(i);
139 if (switchon) w |= b;
140 else w &= ~b;
141 }
142 // Toggle i'th bit
143 void Toggle(uint32 i) {
144 Word(i) ^= Bit(i);
145 }
146 // Set i'th bit if it's clear (or fail)
147 bool TestAndSet(uint32 i) {
148 if (i >= len) return false;
149 uint32 b = Bit(i);
150 uint32 & w = Word(i);
151 uint32 wasset = w & b;
152 w |= b;
153 return !wasset;
154 }
155 // Clear i'th bit if it's set (or fail)
156 bool TestAndReset(uint32 i) {
157 if (i >= len) return false;
158 uint32 b = Bit(i);
159 uint32 & w = Word(i);
160 uint32 wasset = w & b;
161 w &= ~b;
162 return wasset;
163 }
164 // Set i'th bit on/off (fail if no change)
165 bool TestAndSet(uint32 i, bool switchon) {
166 return switchon ? TestAndSet(i) : TestAndReset(i);
167 }
168 // Invert the entire bitmap
169 void Invert();
170 // Downward shift operator, zero fill
171 ABitMap & operator>>=(uint32 nbits);
172 // Upward shift operator, zero fill
173 ABitMap & operator<<=(uint32 nbits);
174 // Copy operator
175 ABitMap & operator=(const ABitMap &src);
176 // Bitwise OR-copy operator
177 ABitMap & operator|=(const ABitMap &src);
178 // Bitwise AND-assign operator
179 ABitMap & operator&=(const ABitMap &src);
180 // Bitwise XOR-assign operator
181 ABitMap & operator^=(const ABitMap &src);
182 // Subtraction operator, synonym for ClearBitsFrom()
183 ABitMap & operator-=(const ABitMap &src) {
184 ClearBitsFrom(src);
185 return *this;
186 }
187 // Compare two bitmaps for equality
188 bool operator==(const ABitMap &that) const;
189 };
190
191 inline bool
192 operator!=(const ABitMap &bm1, const ABitMap &bm2)
193 {
194 return !(bm1 == bm2);
195 }
196
197 inline ABitMap
198 operator>>(ABitMap bmLeft, uint32 nbr)
199 {
200 return bmLeft >>= nbr;
201 }
202
203 inline ABitMap
204 operator<<(ABitMap bmLeft, uint32 nbl)
205 {
206 return bmLeft <<= nbl;
207 }
208
209 inline ABitMap
210 operator|(ABitMap bmLeft, const ABitMap &bmRight)
211 {
212 return bmLeft |= bmRight;
213 }
214
215 inline ABitMap
216 operator&(ABitMap bmLeft, const ABitMap &bmRight)
217 {
218 return bmLeft &= bmRight;
219 }
220
221 inline ABitMap
222 operator^(ABitMap bmLeft, const ABitMap &bmRight)
223 {
224 return bmLeft ^= bmRight;
225 }
226
227 inline ABitMap
228 operator-(ABitMap bmLeft, const ABitMap &bmRight)
229 {
230 return bmLeft -= bmRight;
231 }
232
233 inline ABitMap
234 operator~(ABitMap bmUnary)
235 {
236 bmUnary.Invert();
237 return bmUnary;
238 }
239
240 // 2-dimensional bitmap class
241 class ABitMap2 : protected ABitMap {
242 private:
243 int width, height; // bitmap dimensions
244 protected:
245 uint32 bmi(int x, int y) const {
246 if (OffBitMap(x, y)) return ABMend;
247 return (uint32)y*width + x;
248 }
249 public:
250 ABitMap2() { width=height=0; }
251 ABitMap2(int w, int h, bool clrset=false) :
252 ABitMap((w>0)&(h>0)&&(w <= ABMend/h)
253 ? (uint32)w*h : (uint32)0, clrset) {
254 if (Length()) {
255 width=w; height=h;
256 } else { width=height=0; }
257 }
258 ABitMap2(const ABitMap2 &orig) {
259 *this=orig;
260 }
261 // Access to raw word data
262 uint32 * base() {
263 return ABitMap::base();
264 }
265 // Read-only word access
266 const uint32 * base() const {
267 return ABitMap::base();
268 }
269 // Total number of words
270 int32 bmlen() const {
271 return ABitMap::bmlen();
272 }
273 // Return bitmap width
274 int Width() const {
275 return width;
276 }
277 // Return bitmap height
278 int Height() const {
279 return height;
280 }
281 // Is the indicated bit off our bitmap?
282 bool OffBitMap(int x, int y) const {
283 return ((x < 0) | (x >= width) |
284 (y < 0) | (y >= height));
285 }
286 // Count number of bits set in bitmap
287 uint32 SumTotal(bool bit2cnt = true) const {
288 return ABitMap::SumTotal(bit2cnt);
289 }
290 // Reallocate and clear bitmap
291 bool NewBitMap(int w, int h, bool clrset=false) {
292 if ((w <= 0) | (h <= 0) || w > ABMend/h)
293 w = h = 0;
294 width=w; height=h;
295 return ABitMap::NewBitMap((uint32)w*h, clrset);
296 }
297 // Clear bitmap to all 0's or 1's
298 void ClearBitMap(bool clrset=false) {
299 ABitMap::ClearBitMap(clrset);
300 }
301 // Compress with run-length encoding into a 1-D bitmap
302 bool GetRLE(ABitMap *rlep) const {
303 return ABitMap::GetRLE(rlep);
304 }
305 // Reconstitute bits from RLE encoding (size must match)
306 bool SetFromRLE(int w, int h, const ABitMap &rle);
307 // Steal another bitmap's contents
308 bool Take(ABitMap2 *srcp) {
309 if (srcp == this) return false;
310 width=height=0;
311 if (!ABitMap::Take(srcp)) return false;
312 width=srcp->width; height=srcp->height;
313 srcp->width=srcp->height=0;
314 return true;
315 }
316 // Extract bitmap section (true if some overlap)
317 bool GetRect(ABitMap2 *dp, int sx, int sy) const;
318 // Extract bitmap section (fill outside overlap)
319 ABitMap2 GetRect(int sx, int sy, int w, int h, bool fill=false) const {
320 ABitMap2 bm2(w, h, fill);
321 GetRect(&bm2, sx, sy);
322 return bm2;
323 }
324 // Assign bitmap section (ignores anything past edges)
325 bool AssignRect(int dx, int dy, const ABitMap2 &src);
326 // Apply operation to bitmap section
327 bool OpRect(int dx, int dy, char op, const ABitMap2 &src);
328 // Clear a rectangle
329 void ClearRect(int x, int y, int w, int h, bool clrset=false);
330 // Find the next bit matching val (scanline order)
331 bool Find(int *xp, int *yp, bool val=true) const {
332 if (!xp | !yp) return false;
333 if (width <= 0) return false;
334 if ((*xp < 0) | (*yp < 0)) *xp = *yp = 0;
335 else if (*xp >= width) { *xp=0; ++(*yp); }
336 uint32 i = ABitMap::Find(bmi(*xp,*yp), val);
337 if (i == ABMend) { *yp = height; return false; }
338 *yp = int(i / width);
339 *xp = int(i - *yp*width);
340 return true;
341 }
342 // Get bounds of assigned region
343 bool GetBoundRect(int xymin[2], int wh[2], bool val=true) const;
344 // Return value of bit in bitmap
345 bool Check(int x, int y) const {
346 return ABitMap::Check(bmi(x,y));
347 }
348 // Set bit
349 void Set(int x, int y) {
350 ABitMap::Set(bmi(x,y));
351 }
352 // Reset bit
353 void Reset(int x, int y) {
354 ABitMap::Reset(bmi(x,y));
355 }
356 // Set bit explicitly on or off
357 void Set(int x, int y, bool switchon) {
358 ABitMap::Set(bmi(x,y), switchon);
359 }
360 // Toggle bit
361 void Toggle(int x, int y) {
362 ABitMap::Toggle(bmi(x,y));
363 }
364 // Set bit if it's clear (or fail)
365 bool TestAndSet(int x, int y) {
366 return ABitMap::TestAndSet(bmi(x,y));
367 }
368 // Clear bit if it's set (or fail)
369 bool TestAndReset(int x, int y) {
370 return ABitMap::TestAndReset(bmi(x,y));
371 }
372 // Set bit on/off (fail if no change)
373 bool TestAndSet(int x, int y, bool switchon) {
374 return ABitMap::TestAndSet(bmi(x,y), switchon);
375 }
376 // Invert the entire bitmap
377 void Invert() {
378 ABitMap::Invert();
379 }
380 // Shift bitmap, filling uncovered area as indicated
381 void Shift(int dx, int dy, int fill=0);
382 // Dilate (or erode) selection by given radius
383 void Expand(double rad, bool val=true);
384 // Clear bits set in second map
385 bool ClearBitsFrom(const ABitMap2 &src) {
386 if (width != src.width)
387 return false;
388 return ABitMap::ClearBitsFrom(src);
389 }
390 // Copy operator
391 ABitMap2 & operator=(const ABitMap2 &src) {
392 ABitMap::operator=(src);
393 width=src.width; height=src.height;
394 return *this;
395 }
396 // Bitwise OR-copy operator
397 ABitMap2 & operator|=(const ABitMap2 &src) {
398 ABitMap::operator|=(src);
399 width=src.width; height=src.height;
400 return *this;
401 }
402 // Bitwise AND-assign operator
403 ABitMap2 & operator&=(const ABitMap2 &src) {
404 if ((width!=src.width)|(height!=src.height))
405 return *this;
406 ABitMap::operator&=(src);
407 return *this;
408 }
409 // Bitwise XOR-assign operator
410 ABitMap2 & operator^=(const ABitMap2 &src) {
411 if ((width!=src.width)|(height!=src.height))
412 return *this;
413 ABitMap::operator^=(src);
414 return *this;
415 }
416 // Subtraction operator, synonym for ClearBitsFrom()
417 ABitMap2 & operator-=(const ABitMap2 &src) {
418 ClearBitsFrom(src);
419 return *this;
420 }
421 // Compare two bitmaps for equality
422 bool operator==(const ABitMap2 &that) const {
423 if (width != that.width)
424 return false;
425 return ABitMap::operator==(that);
426 }
427 };
428
429 inline bool
430 operator!=(const ABitMap2 &bm1, const ABitMap2 &bm2)
431 {
432 return !(bm1 == bm2);
433 }
434
435 inline ABitMap2
436 operator|(ABitMap2 bmLeft, const ABitMap2 &bmRight)
437 {
438 return bmLeft |= bmRight;
439 }
440
441 inline ABitMap2
442 operator&(ABitMap2 bmLeft, const ABitMap2 &bmRight)
443 {
444 return bmLeft &= bmRight;
445 }
446
447 inline ABitMap2
448 operator^(ABitMap2 bmLeft, const ABitMap2 &bmRight)
449 {
450 return bmLeft ^= bmRight;
451 }
452
453 inline ABitMap2
454 operator-(ABitMap2 bmLeft, const ABitMap2 &bmRight)
455 {
456 return bmLeft -= bmRight;
457 }
458
459 inline ABitMap2
460 operator~(ABitMap2 bmUnary)
461 {
462 bmUnary.Invert();
463 return bmUnary;
464 }
465
466 // Function to write a bitmap to a BMP file
467 extern bool WriteBitMap(const ABitMap &bm, const char *fname);
468
469 // Function to write a 2-D bitmap to a BMP file
470 extern bool WriteBitMap2(const ABitMap2 &bm2, const char *fname);
471
472 // Function to read a bitmap from a BMP file
473 extern bool ReadBitMap(ABitMap *bmp, const char *fname);
474
475 // Function to read a 2-D bitmap from a BMP file
476 extern bool ReadBitMap2(ABitMap2 *bm2p, const char *fname);
477
478 #endif // ! _ABITMAP_H_
