root/radiance/ray/src/common/abitmap.h
Revision: 2.2
Committed: Sat Aug 24 23:25:24 2024 UTC (11 months, 2 weeks ago) by greg
CVS Tags: rad6R0, HEAD
chore: Added RCS tags to files
1 /* RCSid $Id$ */
2 /*
3 * abitmap.h
4 * panlib
5 *
6 * General bitmap class (mostly inline)
7 *
8 * Created by gward on Tue May 15 2001.
9 * Copyright (c) 2001 Anyhere Software. All rights reserved.
10 *
11 */
12 #ifndef _ABITMAP_H_
13 #define _ABITMAP_H_
14
15 #ifndef _TIFF_
16 #include "tiff.h" /* needed for uint32 type */
17 #endif
18
19 #define ABMend 0xffffffff // terminal return
20
21 // Inline bitmap class
22 class ABitMap {
23 private:
24 uint32 * bmap; // bitmap storage
25 uint32 len; // bitmap size
26 public:
27 ABitMap() { len=0; bmap=0; }
28 ABitMap(uint32 n, bool clrset=false) {
29 bmap=0; len=0; NewBitMap(n,clrset);
30 }
31 ABitMap(const ABitMap &orig) {
32 bmap=0; len=0; *this=orig;
33 }
34 ~ABitMap() {
35 delete [] bmap;
36 }
37 // Access to raw word data
38 uint32 * base() {
39 return bmap;
40 }
41 // Read-only word access
42 const uint32 * base() const {
43 return bmap;
44 }
45 // Number of words from #bits
46 static int32 bmlen(uint32 nbits) {
47 return (nbits+0x1f)>>5;
48 }
49 // Total number of words
50 int32 bmlen() const {
51 return bmlen(len);
52 }
53 // Reallocate and clear bitmap
54 bool NewBitMap(uint32 n, bool clrset=false);
55 // Clear bitmap to all 0's or 1's
56 void ClearBitMap(bool clrset=false);
57 // Steal another bitmap's contents
58 bool Take(ABitMap *srcp) {
59 if (srcp == this) return false;
60 delete [] bmap; bmap=0; len=0;
61 if (!srcp) return false;
62 bmap=srcp->bmap; len=srcp->len;
63 srcp->bmap=0; srcp->len=0;
64 return len;
65 }
66 // Return number of bits in bitmap
67 uint32 Length() const {
68 return len;
69 }
70 // Get original length if RLE (or 0)
71 uint32 RLength() const;
72 // Compress into a run-length encoded bitmap
73 bool GetRLE(ABitMap *rlep) const;
74 // Reconstitute bits from RLE encoding
75 bool SetFromRLE(const ABitMap &rle);
76 // Extract bitmap section (true if some overlap)
77 bool GetBits(ABitMap *dp, uint32 i) const;
78 // Extract bitmap section (fill if past end)
79 ABitMap GetBits(uint32 i, uint32 n, bool fill=false) const {
80 ABitMap bm(n, fill);
81 GetBits(&bm, i);
82 return bm;
83 }
84 // Overlay bitmap section (ignores bits past end)
85 bool AssignBits(uint32 i, const ABitMap &src);
86 // Apply operation to bitmap section
87 bool OpBits(uint32 i, char op, const ABitMap &src);
88 // Clear bitmap section
89 void ClearBits(uint32 i, uint32 n, bool clrset=false);
90 // Clear bits set in second bitmap
91 bool ClearBitsFrom(const ABitMap &src);
92 // Count number of bits set in bitmap
93 uint32 SumTotal(bool bit2cnt = true) const;
94 // Return the next bit position matching val (or ABMend)
95 uint32 Find(uint32 i = 0, bool val = true) const;
96 uint32 Find(int i, bool val = true) const {
97 return Find((uint32)i, val);
98 }
99 uint32 Find(long i, bool val = true) const {
100 return Find((uint32)i, val);
101 }
102 // Different interface to find the next bit matching val
103 bool Find(uint32 *ip, bool val = true) const {
104 if (!ip) return false;
105 if (*ip >= len) return false;
106 *ip = Find(*ip, val);
107 return (*ip < len);
108 }
109 // Access word for i'th bit
110 uint32 & Word(uint32 i) {
111 static uint32 dummy;
112 if (i >= len) return dummy;
113 return bmap[i>>5];
114 }
115 // Get word value for i'th bit (0 if out of range)
116 uint32 WordV(uint32 i) const {
117 if (i >= len) return 0;
118 return bmap[i>>5];
119 }
120 // Index corresponding bit in word
121 static uint32 Bit(uint32 i) {
122 return 1 << (i & 0x1f);
123 }
124 // Return value of i'th bit in bitmap
125 bool Check(uint32 i) const {
126 return (WordV(i) & Bit(i));
127 }
128 // Set i'th bit
129 void Set(uint32 i) {
130 Word(i) |= Bit(i);
131 }
132 // Reset i'th bit
133 void Reset(uint32 i) {
134 Word(i) &= ~Bit(i);
135 }
136 // Set i'th bit explicitly on or off
137 void Set(uint32 i, bool switchon) {
138 uint32 b = Bit(i);
139 uint32 & w = Word(i);
140 if (switchon) w |= b;
141 else w &= ~b;
142 }
143 // Toggle i'th bit
144 void Toggle(uint32 i) {
145 Word(i) ^= Bit(i);
146 }
147 // Set i'th bit if it's clear (or fail)
148 bool TestAndSet(uint32 i) {
149 if (i >= len) return false;
150 uint32 b = Bit(i);
151 uint32 & w = Word(i);
152 uint32 wasset = w & b;
153 w |= b;
154 return !wasset;
155 }
156 // Clear i'th bit if it's set (or fail)
157 bool TestAndReset(uint32 i) {
158 if (i >= len) return false;
159 uint32 b = Bit(i);
160 uint32 & w = Word(i);
161 uint32 wasset = w & b;
162 w &= ~b;
163 return wasset;
164 }
165 // Set i'th bit on/off (fail if no change)
166 bool TestAndSet(uint32 i, bool switchon) {
167 return switchon ? TestAndSet(i) : TestAndReset(i);
168 }
169 // Invert the entire bitmap
170 void Invert();
171 // Downward shift operator, zero fill
172 ABitMap & operator>>=(uint32 nbits);
173 // Upward shift operator, zero fill
174 ABitMap & operator<<=(uint32 nbits);
175 // Copy operator
176 ABitMap & operator=(const ABitMap &src);
177 // Bitwise OR-copy operator
178 ABitMap & operator|=(const ABitMap &src);
179 // Bitwise AND-assign operator
180 ABitMap & operator&=(const ABitMap &src);
181 // Bitwise XOR-assign operator
182 ABitMap & operator^=(const ABitMap &src);
183 // Subtraction operator, synonym for ClearBitsFrom()
184 ABitMap & operator-=(const ABitMap &src) {
185 ClearBitsFrom(src);
186 return *this;
187 }
188 // Compare two bitmaps for equality
189 bool operator==(const ABitMap &that) const;
190 };
191
192 inline bool
193 operator!=(const ABitMap &bm1, const ABitMap &bm2)
194 {
195 return !(bm1 == bm2);
196 }
197
198 inline ABitMap
199 operator>>(ABitMap bmLeft, uint32 nbr)
200 {
201 return bmLeft >>= nbr;
202 }
203
204 inline ABitMap
205 operator<<(ABitMap bmLeft, uint32 nbl)
206 {
207 return bmLeft <<= nbl;
208 }
209
210 inline ABitMap
211 operator|(ABitMap bmLeft, const ABitMap &bmRight)
212 {
213 return bmLeft |= bmRight;
214 }
215
216 inline ABitMap
217 operator&(ABitMap bmLeft, const ABitMap &bmRight)
218 {
219 return bmLeft &= bmRight;
220 }
221
222 inline ABitMap
223 operator^(ABitMap bmLeft, const ABitMap &bmRight)
224 {
225 return bmLeft ^= bmRight;
226 }
227
228 inline ABitMap
229 operator-(ABitMap bmLeft, const ABitMap &bmRight)
230 {
231 return bmLeft -= bmRight;
232 }
233
234 inline ABitMap
235 operator~(ABitMap bmUnary)
236 {
237 bmUnary.Invert();
238 return bmUnary;
239 }
240
241 // 2-dimensional bitmap class
242 class ABitMap2 : protected ABitMap {
243 private:
244 int width, height; // bitmap dimensions
245 protected:
246 uint32 bmi(int x, int y) const {
247 if (OffBitMap(x, y)) return ABMend;
248 return (uint32)y*width + x;
249 }
250 public:
251 ABitMap2() { width=height=0; }
252 ABitMap2(int w, int h, bool clrset=false) :
253 ABitMap((w>0)&(h>0)&&(w <= ABMend/h)
254 ? (uint32)w*h : (uint32)0, clrset) {
255 if (Length()) {
256 width=w; height=h;
257 } else { width=height=0; }
258 }
259 ABitMap2(const ABitMap2 &orig) {
260 *this=orig;
261 }
262 // Access to raw word data
263 uint32 * base() {
264 return ABitMap::base();
265 }
266 // Read-only word access
267 const uint32 * base() const {
268 return ABitMap::base();
269 }
270 // Total number of words
271 int32 bmlen() const {
272 return ABitMap::bmlen();
273 }
274 // Return bitmap width
275 int Width() const {
276 return width;
277 }
278 // Return bitmap height
279 int Height() const {
280 return height;
281 }
282 // Is the indicated bit off our bitmap?
283 bool OffBitMap(int x, int y) const {
284 return ((x < 0) | (x >= width) |
285 (y < 0) | (y >= height));
286 }
287 // Count number of bits set in bitmap
288 uint32 SumTotal(bool bit2cnt = true) const {
289 return ABitMap::SumTotal(bit2cnt);
290 }
291 // Reallocate and clear bitmap
292 bool NewBitMap(int w, int h, bool clrset=false) {
293 if ((w <= 0) | (h <= 0) || w > ABMend/h)
294 w = h = 0;
295 width=w; height=h;
296 return ABitMap::NewBitMap((uint32)w*h, clrset);
297 }
298 // Clear bitmap to all 0's or 1's
299 void ClearBitMap(bool clrset=false) {
300 ABitMap::ClearBitMap(clrset);
301 }
302 // Compress with run-length encoding into a 1-D bitmap
303 bool GetRLE(ABitMap *rlep) const {
304 return ABitMap::GetRLE(rlep);
305 }
306 // Reconstitute bits from RLE encoding (size must match)
307 bool SetFromRLE(int w, int h, const ABitMap &rle);
308 // Steal another bitmap's contents
309 bool Take(ABitMap2 *srcp) {
310 if (srcp == this) return false;
311 width=height=0;
312 if (!ABitMap::Take(srcp)) return false;
313 width=srcp->width; height=srcp->height;
314 srcp->width=srcp->height=0;
315 return true;
316 }
317 // Extract bitmap section (true if some overlap)
318 bool GetRect(ABitMap2 *dp, int sx, int sy) const;
319 // Extract bitmap section (fill outside overlap)
320 ABitMap2 GetRect(int sx, int sy, int w, int h, bool fill=false) const {
321 ABitMap2 bm2(w, h, fill);
322 GetRect(&bm2, sx, sy);
323 return bm2;
324 }
325 // Assign bitmap section (ignores anything past edges)
326 bool AssignRect(int dx, int dy, const ABitMap2 &src);
327 // Apply operation to bitmap section
328 bool OpRect(int dx, int dy, char op, const ABitMap2 &src);
329 // Clear a rectangle
330 void ClearRect(int x, int y, int w, int h, bool clrset=false);
331 // Find the next bit matching val (scanline order)
332 bool Find(int *xp, int *yp, bool val=true) const {
333 if (!xp | !yp) return false;
334 if (width <= 0) return false;
335 if ((*xp < 0) | (*yp < 0)) *xp = *yp = 0;
336 else if (*xp >= width) { *xp=0; ++(*yp); }
337 uint32 i = ABitMap::Find(bmi(*xp,*yp), val);
338 if (i == ABMend) { *yp = height; return false; }
339 *yp = int(i / width);
340 *xp = int(i - *yp*width);
341 return true;
342 }
343 // Get bounds of assigned region
344 bool GetBoundRect(int xymin[2], int wh[2], bool val=true) const;
345 // Return value of bit in bitmap
346 bool Check(int x, int y) const {
347 return ABitMap::Check(bmi(x,y));
348 }
349 // Set bit
350 void Set(int x, int y) {
351 ABitMap::Set(bmi(x,y));
352 }
353 // Reset bit
354 void Reset(int x, int y) {
355 ABitMap::Reset(bmi(x,y));
356 }
357 // Set bit explicitly on or off
358 void Set(int x, int y, bool switchon) {
359 ABitMap::Set(bmi(x,y), switchon);
360 }
361 // Toggle bit
362 void Toggle(int x, int y) {
363 ABitMap::Toggle(bmi(x,y));
364 }
365 // Set bit if it's clear (or fail)
366 bool TestAndSet(int x, int y) {
367 return ABitMap::TestAndSet(bmi(x,y));
368 }
369 // Clear bit if it's set (or fail)
370 bool TestAndReset(int x, int y) {
371 return ABitMap::TestAndReset(bmi(x,y));
372 }
373 // Set bit on/off (fail if no change)
374 bool TestAndSet(int x, int y, bool switchon) {
375 return ABitMap::TestAndSet(bmi(x,y), switchon);
376 }
377 // Invert the entire bitmap
378 void Invert() {
379 ABitMap::Invert();
380 }
381 // Shift bitmap, filling uncovered area as indicated
382 void Shift(int dx, int dy, int fill=0);
383 // Dilate (or erode) selection by given radius
384 void Expand(double rad, bool val=true);
385 // Clear bits set in second map
386 bool ClearBitsFrom(const ABitMap2 &src) {
387 if (width != src.width)
388 return false;
389 return ABitMap::ClearBitsFrom(src);
390 }
391 // Copy operator
392 ABitMap2 & operator=(const ABitMap2 &src) {
393 ABitMap::operator=(src);
394 width=src.width; height=src.height;
395 return *this;
396 }
397 // Bitwise OR-copy operator
398 ABitMap2 & operator|=(const ABitMap2 &src) {
399 ABitMap::operator|=(src);
400 width=src.width; height=src.height;
401 return *this;
402 }
403 // Bitwise AND-assign operator
404 ABitMap2 & operator&=(const ABitMap2 &src) {
405 if ((width!=src.width)|(height!=src.height))
406 return *this;
407 ABitMap::operator&=(src);
408 return *this;
409 }
410 // Bitwise XOR-assign operator
411 ABitMap2 & operator^=(const ABitMap2 &src) {
412 if ((width!=src.width)|(height!=src.height))
413 return *this;
414 ABitMap::operator^=(src);
415 return *this;
416 }
417 // Subtraction operator, synonym for ClearBitsFrom()
418 ABitMap2 & operator-=(const ABitMap2 &src) {
419 ClearBitsFrom(src);
420 return *this;
421 }
422 // Compare two bitmaps for equality
423 bool operator==(const ABitMap2 &that) const {
424 if (width != that.width)
425 return false;
426 return ABitMap::operator==(that);
427 }
428 };
429
430 inline bool
431 operator!=(const ABitMap2 &bm1, const ABitMap2 &bm2)
432 {
433 return !(bm1 == bm2);
434 }
435
436 inline ABitMap2
437 operator|(ABitMap2 bmLeft, const ABitMap2 &bmRight)
438 {
439 return bmLeft |= bmRight;
440 }
441
442 inline ABitMap2
443 operator&(ABitMap2 bmLeft, const ABitMap2 &bmRight)
444 {
445 return bmLeft &= bmRight;
446 }
447
448 inline ABitMap2
449 operator^(ABitMap2 bmLeft, const ABitMap2 &bmRight)
450 {
451 return bmLeft ^= bmRight;
452 }
453
454 inline ABitMap2
455 operator-(ABitMap2 bmLeft, const ABitMap2 &bmRight)
456 {
457 return bmLeft -= bmRight;
458 }
459
460 inline ABitMap2
461 operator~(ABitMap2 bmUnary)
462 {
463 bmUnary.Invert();
464 return bmUnary;
465 }
466
467 // Function to write a bitmap to a BMP file
468 extern bool WriteBitMap(const ABitMap &bm, const char *fname);
469
470 // Function to write a 2-D bitmap to a BMP file
471 extern bool WriteBitMap2(const ABitMap2 &bm2, const char *fname);
472
473 // Function to read a bitmap from a BMP file
474 extern bool ReadBitMap(ABitMap *bmp, const char *fname);
475
476 // Function to read a 2-D bitmap from a BMP file
477 extern bool ReadBitMap2(ABitMap2 *bm2p, const char *fname);
478
479 #endif // ! _ABITMAP_H_
