root/radiance/ray/src/common/SConscript
Revision: 1.8
Committed: Fri Mar 10 19:40:12 2006 UTC (19 years, 1 month ago) by schorsch
1 import os
2
3 Import('env')
4
5 # compose paths
6 def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name)
7
8 # custom flags
9 getlibpath = env.StaticObject(source='getlibpath.c',
10 CPPFLAGS='-DDEFPATH=\\":%s\\"' % env['RAD_RLIBDIR'])
11 tmapcolrs = env.StaticObject(source='tmapcolrs.c',
12 CPPFLAGS='-DPCOND=\\"pcond\\"')
13
14 # source and object dependencies
15 RTSCENE = Split('''cone.c face.c free_os.c instance.c readobj.c readoct.c
16 otypes.c objset.c octree.c readfargs.c modobject.c addobjnotify.c
17 font.c mesh.c readmesh.c tmesh.c sceneio.c xf.c''')
18
19 RTCOLOR = Split('''spec_rgb.c''')
20 RTTMAP = Split('''tonemap.c tmapluv.c tmaptiff.c tmap16bit.c''') + [tmapcolrs]
21 RTPIC = Split('color.c colrops.c resolu.c image.c bmpfile.c')+ RTCOLOR + RTTMAP
22
23 RTERROR = Split('''error.c eputs.c wputs.c quit.c''')
24 RTCONT = Split('''lookup.c savestr.c savqstr.c''')
25 RTMATH = Split('''fvect.c invmat4.c linregr.c mat4.c tcos.c urand.c urind.c
26 zeroes.c dircode.c clip.c multisamp.c plocate.c'''
27 ) + env.get('RAD_MATHCOMPAT', [])
28 RTFUNC = Split('''biggerlib.c caldefn.c calexpr.c calfunc.c calprnt.c
29 chanvalue.c''')
30 RTIO = Split('''fdate.c fgetline.c fgetval.c fgetword.c fputword.c loadvars.c
31 portio.c wordfile.c words.c header.c''')
32 RTARGS = Split('''badarg.c expandarg.c''') + env.get('RAD_ARGSCOMPAT', [])
33 RTPATH = Split('''getpath.c gethomedir.c paths.c''') + [getlibpath]
34 RTLAMPS = Split('''fropen.c rexpr.c lamps.c''')
35
36 RTPROC = Split('''process.c''') + env.get('RAD_PROCESS', [])
37
38 RTMEM = Split('ealloc.c bmalloc.c')
39 RTNET = Split('myhostname.c')
40
41 STD = (RTERROR + RTPATH + RTARGS + RTIO + RTMATH + RTCONT + RTMEM +
42 RTFUNC + RTPROC + RTLAMPS)
43
44 ALL = RTSCENE + RTPIC + STD + RTNET + env.get('RAD_COMPAT',[])
45
46 # build libraries
47 rtscene = env.StaticLibrary(target=radlib('rtscene'), source=RTSCENE)
48
49 rterror = env.StaticLibrary(target=radlib('rterror'), source=RTERROR)
50 rtpath = env.StaticLibrary(target=radlib('rtpath'), source=RTPATH)
51 rtargs = env.StaticLibrary(target=radlib('rtargs'), source=RTARGS)
52 rtio = env.StaticLibrary(target=radlib('rtio'), source=RTIO)
53 rtmath = env.StaticLibrary(target=radlib('rtmath'), source=RTMATH)
54 rtcont = env.StaticLibrary(target=radlib('rtcont'), source=RTCONT)
55 rtmem = env.StaticLibrary(target=radlib('rtmem'), source=RTMEM)
56 rtfunc = env.StaticLibrary(target=radlib('rtfunc'), source=RTFUNC)
57 rtproc = env.StaticLibrary(target=radlib('rtproc'), source=RTPROC)
58 rtcolor = env.StaticLibrary(target=radlib('rtcolor'), source=RTCOLOR)
59 rtlamps = env.StaticLibrary(target=radlib('rtlamps'), source=RTLAMPS)
60 rtpic = env.StaticLibrary(target=radlib('rtpic'), source=RTPIC)
61 rtnet = env.StaticLibrary(target=radlib('rtnet'), source=RTNET)
62
63 #librtrad = env.StaticLibrary(target=radlib('rtrad'), source=ALL)
64 #Default(librtrad)
65
66 LIBFILES = Split('tmesh.cal')
67 env.Append(RAD_RLIBINSTALL=env.Install(env['RAD_RLIBDIR'], LIBFILES))
68
69 if env.has_key('OGL'):
70 oglincl = env.get('CPPPATH', []) + env.get('OGLINCLUDE', [])
71 RGL = Split('rglfile.c rglmat.c rgldomat.c rglsurf.c rglinst.c rglsrc.c')
72 librgl = env.StaticLibrary(target=radlib('rgl'), source=RGL,
73 CPPPATH=oglincl)
74 Default(librgl)
75
