root/Development/ray/src/common/SConscript
Revision: 1.12
Committed: Thu Oct 22 20:39:14 2009 UTC (16 years, 2 months ago) by schorsch
Changes since 1.11: +3 -1 lines
Special flags for ezxml got lost in last SCons update.
1 import os
2
3 Import('env')
4
5 # compose paths
6 def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name)
7
8 # custom flags
9 getlibpath = env.StaticObject(source='getlibpath.c',
10 CPPFLAGS='-DDEFPATH=\\":%s\\"' % env['RAD_RLIBDIR'])
11 tmapcolrs = env.StaticObject(source='tmapcolrs.c',
12 CPPFLAGS='-DPCOND=\\"pcond\\"')
13 ezxml = env.Object('ezxml.c',
14 CPPDEFINES=env.get('CPPDEFINES',[]) + env.get('EZXML_CPPDEFINES',[]))
15
16 # source and object dependencies
17 RTSCENE = Split('''cone.c face.c free_os.c instance.c readobj.c readoct.c
18 otypes.c objset.c octree.c readfargs.c modobject.c
19 font.c mesh.c readmesh.c tmesh.c sceneio.c xf.c''') #addobjnotify.c
20
21 RTCOLOR = Split('''spec_rgb.c''')
22 RTTMAP = Split('''tonemap.c tmapluv.c tmaptiff.c tmap16bit.c''') + [tmapcolrs]
23 RTPIC = Split('color.c colrops.c resolu.c image.c bmpfile.c')+ RTCOLOR + RTTMAP
24
25 RTERROR = Split('''error.c eputs.c wputs.c quit.c''')
26 RTCONT = Split('''lookup.c savestr.c savqstr.c bsdf.c ezxml''')
27 RTMATH = Split('''fvect.c invmat4.c linregr.c mat4.c tcos.c urand.c urind.c
28 zeroes.c dircode.c clip.c multisamp.c plocate.c byteswap.c'''
29 ) + env.get('RAD_MATHCOMPAT', [])
30 RTFUNC = Split('''biggerlib.c caldefn.c calexpr.c calfunc.c calprnt.c
31 chanvalue.c''')
32 RTIO = Split('''fdate.c fgetline.c fgetval.c fgetword.c fputword.c loadvars.c
33 portio.c wordfile.c words.c header.c''')
34 RTARGS = Split('''badarg.c expandarg.c''') + env.get('RAD_ARGSCOMPAT', [])
35 RTPATH = Split('''getpath.c gethomedir.c paths.c''') + [getlibpath]
36 RTLAMPS = Split('''fropen.c rexpr.c lamps.c''')
37
38 RTPROC = Split('''process.c''') + env.get('RAD_PROCESS', [])
39
40 RTMEM = Split('ealloc.c bmalloc.c')
41 RTNET = Split('myhostname.c')
42 RTDUMMY = Split('addobjnotify.c')
43
44 STD = (RTERROR + RTPATH + RTARGS + RTIO + RTMATH + RTCONT + RTMEM +
45 RTFUNC + RTPROC + RTLAMPS)
46
47 ALL = RTSCENE + RTPIC + STD + RTNET + env.get('RAD_COMPAT',[])
48
49 # build libraries
50 rtscene = env.StaticLibrary(target=radlib('rtscene'), source=RTSCENE)
51
52 rterror = env.StaticLibrary(target=radlib('rterror'), source=RTERROR)
53 rtpath = env.StaticLibrary(target=radlib('rtpath'), source=RTPATH)
54 rtargs = env.StaticLibrary(target=radlib('rtargs'), source=RTARGS)
55 rtio = env.StaticLibrary(target=radlib('rtio'), source=RTIO)
56 rtmath = env.StaticLibrary(target=radlib('rtmath'), source=RTMATH)
57 rtcont = env.StaticLibrary(target=radlib('rtcont'), source=RTCONT)
58 rtmem = env.StaticLibrary(target=radlib('rtmem'), source=RTMEM)
59 rtfunc = env.StaticLibrary(target=radlib('rtfunc'), source=RTFUNC)
60 rtproc = env.StaticLibrary(target=radlib('rtproc'), source=RTPROC)
61 rtcolor = env.StaticLibrary(target=radlib('rtcolor'), source=RTCOLOR)
62 rtlamps = env.StaticLibrary(target=radlib('rtlamps'), source=RTLAMPS)
63 rtpic = env.StaticLibrary(target=radlib('rtpic'), source=RTPIC)
64 rtnet = env.StaticLibrary(target=radlib('rtnet'), source=RTNET)
65 # librtdummy is needed, because addobjnotify has different sizes depending
66 # on the program, and in some cases isn't actually needed at all.
67 # It should really be a pointer, and its content allocated
68 # dynamically during program initialization.
69 rtdummy = env.StaticLibrary(target=radlib('rtdummy'), source=RTDUMMY)
70
71 #librtrad = env.StaticLibrary(target=radlib('rtrad'), source=ALL)
72 #Default(librtrad)
73
74 LIBFILES = Split('tmesh.cal')
75 env.Append(RAD_RLIBINSTALL=env.Install(env['RAD_RLIBDIR'], LIBFILES))
76
77 if env.has_key('OGL'):
78 oglincl = env.get('CPPPATH', []) + env.get('OGLINCLUDE', [])
79 RGL = Split('rglfile.c rglmat.c rgldomat.c rglsurf.c rglinst.c rglsrc.c')
80 librgl = env.StaticLibrary(target=radlib('rgl'), source=RGL,
81 CPPPATH=oglincl)
82 Default(librgl)
83
