--- ray/src/common/SConscript 2005/02/02 00:16:02 1.6 +++ ray/src/common/SConscript 2010/06/02 15:58:30 1.13 @@ -10,38 +10,41 @@ getlibpath = env.StaticObject(source='getlibpath.c', CPPFLAGS='-DDEFPATH=\\":%s\\"' % env['RAD_RLIBDIR']) tmapcolrs = env.StaticObject(source='tmapcolrs.c', CPPFLAGS='-DPCOND=\\"pcond\\"') +ezxml = env.Object('ezxml.c', + CPPDEFINES=env.get('CPPDEFINES',[]) + env.get('EZXML_CPPDEFINES',[])) # source and object dependencies RTSCENE = Split('''cone.c face.c free_os.c instance.c readobj.c readoct.c - otypes.c objset.c octree.c readfargs.c modobject.c addobjnotify.c - font.c mesh.c readmesh.c tmesh.c sceneio.c xf.c''') + otypes.c objset.c octree.c readfargs.c modobject.c + font.c mesh.c readmesh.c tmesh.c sceneio.c xf.c''') #addobjnotify.c RTCOLOR = Split('''spec_rgb.c''') RTTMAP = Split('''tonemap.c tmapluv.c tmaptiff.c tmap16bit.c''') + [tmapcolrs] RTPIC = Split('color.c colrops.c resolu.c image.c bmpfile.c')+ RTCOLOR + RTTMAP RTERROR = Split('''error.c eputs.c wputs.c quit.c''') -RTCONT = Split('''lookup.c savestr.c savqstr.c''') +RTCONT = Split('''lookup.c savestr.c savqstr.c bsdf.c ezxml''') RTMATH = Split('''fvect.c invmat4.c linregr.c mat4.c tcos.c urand.c urind.c - zeroes.c dircode.c clip.c multisamp.c plocate.c''' + zeroes.c dircode.c clip.c multisamp.c plocate.c byteswap.c''' ) + env.get('RAD_MATHCOMPAT', []) RTFUNC = Split('''biggerlib.c caldefn.c calexpr.c calfunc.c calprnt.c chanvalue.c''') RTIO = Split('''fdate.c fgetline.c fgetval.c fgetword.c fputword.c loadvars.c - portio.c wordfile.c words.c header.c''') + portio.c wordfile.c words.c header.c timegm.c''') RTARGS = Split('''badarg.c expandarg.c''') + env.get('RAD_ARGSCOMPAT', []) RTPATH = Split('''getpath.c gethomedir.c paths.c''') + [getlibpath] RTLAMPS = Split('''fropen.c rexpr.c lamps.c''') RTPROC = Split('''process.c''') + env.get('RAD_PROCESS', []) -RTMEM = Split('ealloc.c bmalloc.c') + env.get('RAD_MEMCOMPAT', []) +RTMEM = Split('ealloc.c bmalloc.c') RTNET = Split('myhostname.c') +RTDUMMY = Split('addobjnotify.c') STD = (RTERROR + RTPATH + RTARGS + RTIO + RTMATH + RTCONT + RTMEM + RTFUNC + RTPROC + RTLAMPS) -ALL = RTSCENE + RTPIC + STD + RTNET + env.get('RAD_COMPAT',[]) +ALL = RTSCENE + RTPIC + STD + RTNET # build libraries rtscene = env.StaticLibrary(target=radlib('rtscene'), source=RTSCENE) @@ -59,9 +62,14 @@ rtcolor = env.StaticLibrary(target=radlib('rtcolor'), rtlamps = env.StaticLibrary(target=radlib('rtlamps'), source=RTLAMPS) rtpic = env.StaticLibrary(target=radlib('rtpic'), source=RTPIC) rtnet = env.StaticLibrary(target=radlib('rtnet'), source=RTNET) +# librtdummy is needed, because addobjnotify has different sizes depending +# on the program, and in some cases isn't actually needed at all. +# It should really be a pointer, and its content allocated +# dynamically during program initialization. +rtdummy = env.StaticLibrary(target=radlib('rtdummy'), source=RTDUMMY) -#librt = env.StaticLibrary(target=radlib('rt'), source=ALL) -#Default(librt) +#librtrad = env.StaticLibrary(target=radlib('rtrad'), source=ALL) +#Default(librtrad) LIBFILES = Split('tmesh.cal') env.Append(RAD_RLIBINSTALL=env.Install(env['RAD_RLIBDIR'], LIBFILES))
