--- ray/src/common/SConscript 2003/10/27 10:35:42 1.2 +++ ray/src/common/SConscript 2016/03/28 17:48:43 1.21 @@ -1,73 +1,73 @@ -import os - -Import('env') - -# compose paths -def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name) - -# custom flags -getlibpath = env.StaticObject(source='getlibpath.c', - CPPFLAGS='-DDEFPATH=\\":%s\\"' % env['RAD_RLIBDIR']) -tmapcolrs = env.StaticObject(source='tmapcolrs.c', - CPPFLAGS='-DPCOND=\\"pcond\\"') - -# source and object dependencies -RTSCENE = Split('''cone.c face.c free_os.c instance.c readobj.c readoct.c - otypes.c objset.c octree.c readfargs.c modobject.c addobjnotify.c - font.c mesh.c readmesh.c tmesh.c sceneio.c xf.c''') - -RTCOLOR = Split('''spec_rgb.c''') -RTTMAP = Split('''tonemap.c tmapluv.c tmaptiff.c tmap16bit.c''') + [tmapcolrs] -RTPIC = Split('''color.c colrops.c resolu.c image.c''') + RTCOLOR + RTTMAP - -RTERROR = Split('''error.c eputs.c wputs.c quit.c''') -RTCONT = Split('''lookup.c savestr.c savqstr.c''') -RTMATH = Split('''fvect.c invmat4.c linregr.c mat4.c tcos.c urand.c urind.c - zeroes.c dircode.c clip.c multisamp.c plocate.c''' - ) + env.get('RAD_MATHCOMPAT', []) -RTFUNC = Split('''biggerlib.c caldefn.c calexpr.c calfunc.c calprnt.c - chanvalue.c''') -RTIO = Split('''fdate.c fgetline.c fgetval.c fgetword.c fputword.c loadvars.c - portio.c wordfile.c words.c header.c''') -RTARGS = Split('''badarg.c expandarg.c''') + env.get('RAD_ARGSCOMPAT', []) -RTPATH = Split('''getpath.c gethomedir.c paths.c''') + [getlibpath] -RTLAMPS = Split('''fropen.c rexpr.c lamps.c''') - -RTPROC = Split('''process.c''') + env.get('RAD_PROCESS', []) - -RTMEM = Split('ealloc.c') + env.get('RAD_MEMCOMPAT', []) -RTNET = Split('myhostname.c') - -STD = (RTERROR + RTPATH + RTARGS + RTIO + RTMATH + RTCONT + RTMEM + - RTFUNC + RTPROC + RTLAMPS) - -ALL = RTSCENE + RTPIC + STD + RTNET + env.get('RAD_COMPAT',[]) - -# build libraries -rtscene = env.StaticLibrary(target=radlib('rtscene'), source=RTSCENE) - -rterror = env.StaticLibrary(target=radlib('rterror'), source=RTERROR) -rtpath = env.StaticLibrary(target=radlib('rtpath'), source=RTPATH) -rtargs = env.StaticLibrary(target=radlib('rtargs'), source=RTARGS) -rtio = env.StaticLibrary(target=radlib('rtio'), source=RTIO) -rtmath = env.StaticLibrary(target=radlib('rtmath'), source=RTMATH) -rtcont = env.StaticLibrary(target=radlib('rtcont'), source=RTCONT) -rtmem = env.StaticLibrary(target=radlib('rtmem'), source=RTMEM) -rtfunc = env.StaticLibrary(target=radlib('rtfunc'), source=RTFUNC) -rtproc = env.StaticLibrary(target=radlib('rtproc'), source=RTPROC) -rtcolor = env.StaticLibrary(target=radlib('rtcolor'), source=RTCOLOR) -rtlamps = env.StaticLibrary(target=radlib('rtlamps'), source=RTLAMPS) -rtpic = env.StaticLibrary(target=radlib('rtpic'), source=RTPIC) -rtnet = env.StaticLibrary(target=radlib('rtnet'), source=RTNET) - -#librt = env.StaticLibrary(target=radlib('rt'), source=ALL) -#Default(librt) - -LIBFILES = Split('tmesh.cal') -env.Append(RAD_RLIBINSTALL=env.Install(env['RAD_RLIBDIR'], LIBFILES)) - -if env.has_key('OGL'): - RGL = Split('rglfile.c rglmat.c rgldomat.c rglsurf.c rglinst.c rglsrc.c') - librgl = env.StaticLibrary(target=radlib('rgl'), source=RGL) - Default(librgl) - +import os + +Import('env') + +# compose paths +def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name) + +# custom flags +getlibpath = env.StaticObject(source='getlibpath.c', + CPPFLAGS='-DDEFPATH="\\"%s\\""' % env['RAD_RLIBDIR'].replace('\\','/')) +tmapcolrs = env.StaticObject(source='tmapcolrs.c', + CPPFLAGS='-DPCOND=\\"pcond\\"') +ezxml = env.StaticObject('ezxml.c', + CPPDEFINES=env.get('CPPDEFINES',[]) + env.get('EZXML_CPPDEFINES',[])) +objs = [getlibpath, tmapcolrs, ezxml] + +# the definition of addobjnotify conflicts with definitions in other files +# that are more essential to the library. +# We need to pass this one around and include it individually +addobjn = env.StaticObject(source='addobjnotify.c') +env['ADDOBJNOTIFY'] = addobjn + +# source and object dependencies +RTSCENE = Split('''cone.c face.c free_os.c instance.c readobj.c readoct.c + otypes.c objset.c octree.c readfargs.c modobject.c + font.c mesh.c readmesh.c tmesh.c sceneio.c xf.c''') +RTPIC = Split('''color.c colrops.c resolu.c image.c bmpfile.c falsecolor.c + tonemap.c tmapluv.c tmap16bit.c tmaptiff.c''') +RTERROR = Split('''error.c eputs.c wputs.c quit.c''') +RTCONT = Split('''lookup.c savestr.c savqstr.c ccolor.c ccyrgb.c + spec_rgb.c bsdf.c bsdf_m.c bsdf_t.c loadbsdf.c + disk2square.c hilbert.c interp2d.c triangulate.c''') +RTMATH = Split('''fvect.c invmat4.c linregr.c mat4.c tcos.c urand.c urind.c + zeroes.c dircode.c clip.c multisamp.c plocate.c byteswap.c''' + ) + env.get('RAD_MATHCOMPAT', []) +RTFUNC = Split('''biggerlib.c caldefn.c calexpr.c calfunc.c calprnt.c + chanvalue.c''') +RTIO = Split('''fdate.c fgetline.c fgetval.c fgetword.c fputword.c loadvars.c + portio.c wordfile.c words.c header.c timegm.c cvtcmd.c''') +RTARGS = Split('''badarg.c expandarg.c''') + env.get('RAD_ARGSCOMPAT', []) +RTPATH = Split('''getpath.c gethomedir.c paths.c''') +RTLAMPS = Split('''fropen.c rexpr.c lamps.c''') +RTPROC = Split('''process.c''') + env.get('RAD_PROCESS', []) +RTMEM = Split('ealloc.c bmalloc.c') +RTNET = Split('myhostname.c') + +librtrad = env.StaticLibrary(target=radlib('rtrad'), + source=RTERROR + RTPATH + RTARGS + RTIO + RTMATH + RTCONT + RTMEM + + RTFUNC + RTPROC + RTLAMPS + RTSCENE + RTPIC + RTNET + objs) + +MGF = Split('''mgf_parser.c mgf_object.c mgf_xf.c mgf_context.c''') +libmgf = env.StaticLibrary(target=radlib('mgf'), source=MGF) + +REETZ = Split('g3affine.c g3flist.c g3sphere.c g3vector.c gbasic.c maxheap.c') +libreetz = env.StaticLibrary(target=radlib('reetz'), source=REETZ) + +LIBFILES = Split('tmesh.cal') +env.Append(RAD_RLIBINSTALL=env.Install(env['RAD_RLIBDIR'], LIBFILES)) + +if env.has_key('OGL'): + oglincl = env.get('CPPPATH', []) + env.get('OGLINCLUDE', []) + RGL = Split('rglfile.c rglmat.c rgldomat.c rglsurf.c rglinst.c rglsrc.c') + librgl = env.StaticLibrary(target=radlib('rgl'), source=RGL, + CPPPATH=oglincl) + Default(librgl) + +# Python support modules for test suite and other scripts +for fn in Split('''__init__.py lcompare.py pyrad_proc.py'''): + Default(env.InstallScript( + os.path.join('$RAD_BUILDRLIB','pyradlib',fn), + os.path.join('pyradlib', fn))) + +# vim: set syntax=python:
