--- ray/src/common/SConscript 2016/03/05 00:29:28 1.16 +++ ray/src/common/SConscript 2016/03/10 01:49:56 1.18 @@ -7,7 +7,7 @@ def radlib(name): return os.path.join(env['RAD_BUILDLI # custom flags getlibpath = env.StaticObject(source='getlibpath.c', - CPPFLAGS='-DDEFPATH=\\":%s\\"' % env['RAD_RLIBDIR']) + CPPFLAGS='-DDEFPATH="\\"%s\\""' % env['RAD_RLIBDIR'].replace('\\','/')) tmapcolrs = env.StaticObject(source='tmapcolrs.c', CPPFLAGS='-DPCOND=\\"pcond\\"') ezxml = env.Object('ezxml.c', @@ -32,10 +32,12 @@ RTMATH = Split('''fvect.c invmat4.c linregr.c mat4.c t RTFUNC = Split('''biggerlib.c caldefn.c calexpr.c calfunc.c calprnt.c chanvalue.c''') RTIO = Split('''fdate.c fgetline.c fgetval.c fgetword.c fputword.c loadvars.c - portio.c wordfile.c words.c header.c timegm.c''') + portio.c wordfile.c words.c header.c timegm.c cvtcmd.c''') RTARGS = Split('''badarg.c expandarg.c''') + env.get('RAD_ARGSCOMPAT', []) RTPATH = Split('''getpath.c gethomedir.c paths.c''') + [getlibpath] RTLAMPS = Split('''fropen.c rexpr.c lamps.c''')+ [getlibpath] +REETZ = Split('''g3affine.c g3flist.c g3sphere.c g3vector.c gbasic.c + maxheap.c''') RTPROC = Split('''process.c''') + env.get('RAD_PROCESS', []) @@ -62,6 +64,7 @@ rtfunc = env.StaticLibrary(target=radlib('rtfunc'), so rtproc = env.StaticLibrary(target=radlib('rtproc'), source=RTPROC) rtcolor = env.StaticLibrary(target=radlib('rtcolor'), source=RTCOLOR) rtlamps = env.StaticLibrary(target=radlib('rtlamps'), source=RTLAMPS) +reetz = env.StaticLibrary(target=radlib('reetz'), source=REETZ) rtpic = env.StaticLibrary(target=radlib('rtpic'), source=RTPIC) rtnet = env.StaticLibrary(target=radlib('rtnet'), source=RTNET) # librtdummy is needed, because addobjnotify has different sizes depending @@ -84,3 +87,4 @@ if env.has_key('OGL'): CPPPATH=oglincl) Default(librgl) +# vim: set syntax=python:
