root/Development/ray/src/common/SConscript
Revision: 1.19
Committed: Thu Mar 10 21:43:22 2016 UTC (9 years, 6 months ago) by schorsch
Changes since 1.18: +14 -38 lines
1 import os
2
3 Import('env')
4
5 # compose paths
6 def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name)
7
8 # custom flags
9 getlibpath = env.StaticObject(source='getlibpath.c',
10 CPPFLAGS='-DDEFPATH="\\"%s\\""' % env['RAD_RLIBDIR'].replace('\\','/'))
11 tmapcolrs = env.StaticObject(source='tmapcolrs.c',
12 CPPFLAGS='-DPCOND=\\"pcond\\"')
13 ezxml = env.Object('ezxml.c',
14 CPPDEFINES=env.get('CPPDEFINES',[]) + env.get('EZXML_CPPDEFINES',[]))
15
16 # source and object dependencies
17 RTSCENE = Split('''cone.c face.c free_os.c instance.c readobj.c readoct.c
18 otypes.c objset.c octree.c readfargs.c modobject.c
19 font.c mesh.c readmesh.c tmesh.c sceneio.c xf.c''') #addobjnotify.c
20 RTPIC = Split('''color.c colrops.c resolu.c image.c bmpfile.c falsecolor.c
21 tonemap.c tmapluv.c tmaptiff.c tmap16bit.c''') + [tmapcolrs]
22 RTERROR = Split('''error.c eputs.c wputs.c quit.c''')
23 RTCONT = Split('''ezxml lookup.c savestr.c savqstr.c ccolor.c ccyrgb.c
24 spec_rgb.c bsdf.c bsdf_m.c bsdf_t.c loadbsdf.c
25 disk2square.c hilbert.c interp2d.c triangulate.c''')
26 RTMATH = Split('''fvect.c invmat4.c linregr.c mat4.c tcos.c urand.c urind.c
27 zeroes.c dircode.c clip.c multisamp.c plocate.c byteswap.c'''
28 ) + env.get('RAD_MATHCOMPAT', [])
29 RTFUNC = Split('''biggerlib.c caldefn.c calexpr.c calfunc.c calprnt.c
30 chanvalue.c''')
31 RTIO = Split('''fdate.c fgetline.c fgetval.c fgetword.c fputword.c loadvars.c
32 portio.c wordfile.c words.c header.c timegm.c cvtcmd.c''')
33 RTARGS = Split('''badarg.c expandarg.c''') + env.get('RAD_ARGSCOMPAT', [])
34 RTPATH = Split('''getpath.c gethomedir.c paths.c''') + [getlibpath]
35 RTLAMPS = Split('''fropen.c rexpr.c lamps.c''')
36 RTPROC = Split('''process.c''') + env.get('RAD_PROCESS', [])
37 RTMEM = Split('ealloc.c bmalloc.c')
38 RTNET = Split('myhostname.c')
39 librtrad = env.StaticLibrary(target=radlib('rtrad'),
40 source=(RTERROR + RTPATH + RTARGS + RTIO + RTMATH + RTCONT + RTMEM
41 + RTFUNC + RTPROC + RTLAMPS + RTSCENE + RTPIC + RTNET))
42
43 MGF = Split('''mgf_parser.c mgf_object.c mgf_xf.c mgf_context.c''')
44 libmgf = env.StaticLibrary(target=radlib('mgf'), source=MGF)
45
46 REETZ = Split('g3affine.c g3flist.c g3sphere.c g3vector.c gbasic.c maxheap.c')
47 libreetz = env.StaticLibrary(target=radlib('reetz'), source=REETZ)
48
49 # librtdummy is needed, because addobjnotify has different sizes depending
50 # on the program, and in some cases isn't actually needed at all.
51 # It should really be a pointer, and its content allocated
52 # dynamically during program initialization.
53 RTDUMMY = Split('addobjnotify.c')
54 rtdummy = env.StaticLibrary(target=radlib('rtdummy'), source=RTDUMMY)
55
56 LIBFILES = Split('tmesh.cal')
57 env.Append(RAD_RLIBINSTALL=env.Install(env['RAD_RLIBDIR'], LIBFILES))
58
59 if env.has_key('OGL'):
60 oglincl = env.get('CPPPATH', []) + env.get('OGLINCLUDE', [])
61 RGL = Split('rglfile.c rglmat.c rgldomat.c rglsurf.c rglinst.c rglsrc.c')
62 librgl = env.StaticLibrary(target=radlib('rgl'), source=RGL,
63 CPPPATH=oglincl)
64 Default(librgl)
65
66 # vim: set syntax=python:
