root/Development/ray/src/common/SConscript
Mon Jan 8 13:38:37 2018 UTC (7 years, 11 months ago) by schorsch
Changes since 1.22: +4 -0 lines
Diff to previous 1.22 , to selected 1.20
Thu Jul 14 17:32:12 2016 UTC (9 years, 5 months ago) by greg
Changes since 1.21: +1 -7 lines
Diff to previous 1.21 , to selected 1.20
Changes to evalglare by Jan Wienold
Mon Mar 28 17:48:43 2016 UTC (9 years, 9 months ago) by schorsch
Changes since 1.20: +6 -0 lines
Diff to previous 1.20
Refactoring of test suite, use independently of SCons and with Py2.7 or 3.x.
Revision 1.20 - (view) (download) (annotate) - [selected]
Fri Mar 18 22:54:22 2016 UTC (9 years, 9 months ago) by schorsch
Changes since 1.19: +15 -14 lines
Diff to previous 1.19
better solution for addobjnotify
Thu Mar 10 21:43:22 2016 UTC (9 years, 9 months ago) by schorsch
Changes since 1.18: +14 -38 lines
Diff to previous 1.18 , to selected 1.20
Thu Mar 10 01:49:56 2016 UTC (9 years, 9 months ago) by schorsch
Diff to previous 1.17 , to selected 1.20
SCons build system learns about platform architecture
Sat Mar 5 13:24:58 2016 UTC (9 years, 9 months ago) by schorsch
Changes since 1.16: +5 -1 lines
Diff to previous 1.16 , to selected 1.20
Sat Mar 5 00:29:28 2016 UTC (9 years, 10 months ago) by schorsch
Diff to previous 1.15 , to selected 1.20
update SCons
Fri Apr 15 21:52:16 2011 UTC (14 years, 8 months ago) by greg
Changes since 1.14: +7 -6 lines
Diff to previous 1.14 , to selected 1.20
SCONS fixes for latest build
Wed Dec 15 01:40:11 2010 UTC (15 years ago) by greg
Changes since 1.13: +3 -1 lines
Diff to previous 1.13 , to selected 1.20
Updated SConscript files for compiling under MINGW
Wed Jun 2 15:58:30 2010 UTC (15 years, 7 months ago) by greg
Diff to previous 1.12 , to selected 1.20
Fixes to MINGW build
Thu Oct 22 20:39:14 2009 UTC (16 years, 2 months ago) by schorsch
Changes since 1.11: +3 -1 lines
Diff to previous 1.11 , to selected 1.20
Special flags for ezxml got lost in last SCons update.
Wed Oct 7 22:05:42 2009 UTC (16 years, 2 months ago) by schorsch
Diff to previous 1.10 , to selected 1.20
Adapting to move of ezxml.c to common and removal of mkillum4.c.
Tue Dec 23 15:03:59 2008 UTC (17 years ago) by schorsch
Changes since 1.9: +8 -2 lines
Diff to previous 1.9 , to selected 1.20
Mon Apr 21 07:31:28 2008 UTC (17 years, 8 months ago) by schorsch
Diff to previous 1.8 , to selected 1.20
Scons update for mingw.
Fri Mar 10 19:40:12 2006 UTC (19 years, 9 months ago) by schorsch
Diff to previous 1.7 , to selected 1.20
Mon Sep 19 11:30:10 2005 UTC (20 years, 3 months ago) by schorsch
Diff to previous 1.6 , to selected 1.20
Wed Feb 2 00:16:02 2005 UTC (20 years, 11 months ago) by schorsch
Diff to previous 1.5 , to selected 1.20
Turned bmalloc.c into a standard module.
Sun Jul 4 12:08:47 2004 UTC (21 years, 6 months ago) by schorsch
Changes since 1.4: +5 -3 lines
Diff to previous 1.4 , to selected 1.20
Sat Jul 3 22:34:56 2004 UTC (21 years, 6 months ago) by schorsch
Changes since 1.3: +73 -73 lines
Diff to previous 1.3 , to selected 1.20
Converted from DOS to unix line endings.
Fri Mar 26 21:29:19 2004 UTC (21 years, 9 months ago) by schorsch
Diff to previous 1.2 , to selected 1.20
Small fixes to reduce warnings. Added bmpfile.c to SConscript.
Mon Oct 27 10:35:42 2003 UTC (22 years, 2 months ago) by schorsch
Changes since 1.1: +46 -18 lines
Diff to previous 1.1 , to selected 1.20
Tue Oct 21 19:27:28 2003 UTC (22 years, 2 months ago) by schorsch
Diff to selected 1.20
