1 |
import os |
2 |
3 |
Import('env') |
4 |
5 |
# compose paths |
6 |
def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name) |
7 |
8 |
# custom flags |
9 |
getlibpath = env.StaticObject(source='getlibpath.c', |
10 |
CPPFLAGS='-DDEFPATH=\\":%s\\"' % env['RAD_RLIBDIR']) |
11 |
tmapcolrs = env.StaticObject(source='tmapcolrs.c', |
12 |
CPPFLAGS='-DPCOND=\\"pcond\\"') |
13 |
14 |
# source and object dependencies |
15 |
RTSCENE = Split('''cone.c face.c free_os.c instance.c readobj.c readoct.c |
16 |
otypes.c objset.c octree.c readfargs.c modobject.c |
17 |
font.c mesh.c readmesh.c tmesh.c sceneio.c xf.c''') #addobjnotify.c |
18 |
19 |
RTCOLOR = Split('''spec_rgb.c''') |
20 |
RTTMAP = Split('''tonemap.c tmapluv.c tmaptiff.c tmap16bit.c''') + [tmapcolrs] |
21 |
RTPIC = Split('color.c colrops.c resolu.c image.c bmpfile.c')+ RTCOLOR + RTTMAP |
22 |
23 |
RTERROR = Split('''error.c eputs.c wputs.c quit.c''') |
24 |
RTCONT = Split('''lookup.c savestr.c savqstr.c bsdf.c ezxml.c''') |
25 |
RTMATH = Split('''fvect.c invmat4.c linregr.c mat4.c tcos.c urand.c urind.c |
26 |
zeroes.c dircode.c clip.c multisamp.c plocate.c byteswap.c''' |
27 |
) + env.get('RAD_MATHCOMPAT', []) |
28 |
RTFUNC = Split('''biggerlib.c caldefn.c calexpr.c calfunc.c calprnt.c |
29 |
chanvalue.c''') |
30 |
RTIO = Split('''fdate.c fgetline.c fgetval.c fgetword.c fputword.c loadvars.c |
31 |
portio.c wordfile.c words.c header.c''') |
32 |
RTARGS = Split('''badarg.c expandarg.c''') + env.get('RAD_ARGSCOMPAT', []) |
33 |
RTPATH = Split('''getpath.c gethomedir.c paths.c''') + [getlibpath] |
34 |
RTLAMPS = Split('''fropen.c rexpr.c lamps.c''') |
35 |
36 |
RTPROC = Split('''process.c''') + env.get('RAD_PROCESS', []) |
37 |
38 |
RTMEM = Split('ealloc.c bmalloc.c') |
39 |
RTNET = Split('myhostname.c') |
40 |
RTDUMMY = Split('addobjnotify.c') |
41 |
42 |
STD = (RTERROR + RTPATH + RTARGS + RTIO + RTMATH + RTCONT + RTMEM + |
43 |
RTFUNC + RTPROC + RTLAMPS) |
44 |
45 |
ALL = RTSCENE + RTPIC + STD + RTNET + env.get('RAD_COMPAT',[]) |
46 |
47 |
# build libraries |
48 |
rtscene = env.StaticLibrary(target=radlib('rtscene'), source=RTSCENE) |
49 |
50 |
rterror = env.StaticLibrary(target=radlib('rterror'), source=RTERROR) |
51 |
rtpath = env.StaticLibrary(target=radlib('rtpath'), source=RTPATH) |
52 |
rtargs = env.StaticLibrary(target=radlib('rtargs'), source=RTARGS) |
53 |
rtio = env.StaticLibrary(target=radlib('rtio'), source=RTIO) |
54 |
rtmath = env.StaticLibrary(target=radlib('rtmath'), source=RTMATH) |
55 |
rtcont = env.StaticLibrary(target=radlib('rtcont'), source=RTCONT) |
56 |
rtmem = env.StaticLibrary(target=radlib('rtmem'), source=RTMEM) |
57 |
rtfunc = env.StaticLibrary(target=radlib('rtfunc'), source=RTFUNC) |
58 |
rtproc = env.StaticLibrary(target=radlib('rtproc'), source=RTPROC) |
59 |
rtcolor = env.StaticLibrary(target=radlib('rtcolor'), source=RTCOLOR) |
60 |
rtlamps = env.StaticLibrary(target=radlib('rtlamps'), source=RTLAMPS) |
61 |
rtpic = env.StaticLibrary(target=radlib('rtpic'), source=RTPIC) |
62 |
rtnet = env.StaticLibrary(target=radlib('rtnet'), source=RTNET) |
63 |
# librtdummy is needed, because addobjnotify has different sizes depending |
64 |
# on the program, and in some cases isn't actually needed at all. |
65 |
# It should really be a pointer, and its content allocated |
66 |
# dynamically during program initialization. |
67 |
rtdummy = env.StaticLibrary(target=radlib('rtdummy'), source=RTDUMMY) |
68 |
69 |
#librtrad = env.StaticLibrary(target=radlib('rtrad'), source=ALL) |
70 |
#Default(librtrad) |
71 |
72 |
LIBFILES = Split('tmesh.cal') |
73 |
env.Append(RAD_RLIBINSTALL=env.Install(env['RAD_RLIBDIR'], LIBFILES)) |
74 |
75 |
if env.has_key('OGL'): |
76 |
oglincl = env.get('CPPPATH', []) + env.get('OGLINCLUDE', []) |
77 |
RGL = Split('rglfile.c rglmat.c rgldomat.c rglsurf.c rglinst.c rglsrc.c') |
78 |
librgl = env.StaticLibrary(target=radlib('rgl'), source=RGL, |
79 |
CPPPATH=oglincl) |
80 |
Default(librgl) |
81 |
