root/Development/ray/src/common/SConscript
Revision: 1.22
Committed: Thu Jul 14 17:32:12 2016 UTC (9 years, 5 months ago) by greg
Changes since 1.21: +1 -7 lines
Changes to evalglare by Jan Wienold
# User Rev Content
1 schorsch 1.4 import os
2
3     Import('env')
4
5     # compose paths
6     def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name)
7
8     # custom flags
9     getlibpath = env.StaticObject(source='getlibpath.c',
10 schorsch 1.18 CPPFLAGS='-DDEFPATH="\\"%s\\""' % env['RAD_RLIBDIR'].replace('\\','/'))
11 schorsch 1.4 tmapcolrs = env.StaticObject(source='tmapcolrs.c',
12     CPPFLAGS='-DPCOND=\\"pcond\\"')
13 schorsch 1.20 ezxml = env.StaticObject('ezxml.c',
14 schorsch 1.12 CPPDEFINES=env.get('CPPDEFINES',[]) + env.get('EZXML_CPPDEFINES',[]))
15 schorsch 1.20 objs = [getlibpath, tmapcolrs, ezxml]
16
17     # the definition of addobjnotify conflicts with definitions in other files
18     # that are more essential to the library.
19     # We need to pass this one around and include it individually
20     addobjn = env.StaticObject(source='addobjnotify.c')
21     env['ADDOBJNOTIFY'] = addobjn
22 schorsch 1.4
23     # source and object dependencies
24     RTSCENE = Split('''cone.c face.c free_os.c instance.c readobj.c readoct.c
25 schorsch 1.10 otypes.c objset.c octree.c readfargs.c modobject.c
26 schorsch 1.20 font.c mesh.c readmesh.c tmesh.c sceneio.c xf.c''')
27 schorsch 1.19 RTPIC = Split('''color.c colrops.c resolu.c image.c bmpfile.c falsecolor.c
28 schorsch 1.20 tonemap.c tmapluv.c tmap16bit.c tmaptiff.c''')
29 schorsch 1.4 RTERROR = Split('''error.c eputs.c wputs.c quit.c''')
30 schorsch 1.20 RTCONT = Split('''lookup.c savestr.c savqstr.c ccolor.c ccyrgb.c
31 schorsch 1.19 spec_rgb.c bsdf.c bsdf_m.c bsdf_t.c loadbsdf.c
32     disk2square.c hilbert.c interp2d.c triangulate.c''')
33 schorsch 1.4 RTMATH = Split('''fvect.c invmat4.c linregr.c mat4.c tcos.c urand.c urind.c
34 schorsch 1.9 zeroes.c dircode.c clip.c multisamp.c plocate.c byteswap.c'''
35 schorsch 1.4 ) + env.get('RAD_MATHCOMPAT', [])
36     RTFUNC = Split('''biggerlib.c caldefn.c calexpr.c calfunc.c calprnt.c
37     chanvalue.c''')
38     RTIO = Split('''fdate.c fgetline.c fgetval.c fgetword.c fputword.c loadvars.c
39 schorsch 1.17 portio.c wordfile.c words.c header.c timegm.c cvtcmd.c''')
40 schorsch 1.4 RTARGS = Split('''badarg.c expandarg.c''') + env.get('RAD_ARGSCOMPAT', [])
41 schorsch 1.20 RTPATH = Split('''getpath.c gethomedir.c paths.c''')
42 schorsch 1.19 RTLAMPS = Split('''fropen.c rexpr.c lamps.c''')
43 schorsch 1.4 RTPROC = Split('''process.c''') + env.get('RAD_PROCESS', [])
44 schorsch 1.7 RTMEM = Split('ealloc.c bmalloc.c')
45 schorsch 1.4 RTNET = Split('myhostname.c')
46 schorsch 1.20
47 schorsch 1.19 librtrad = env.StaticLibrary(target=radlib('rtrad'),
48 schorsch 1.20 source=RTERROR + RTPATH + RTARGS + RTIO + RTMATH + RTCONT + RTMEM
49     + RTFUNC + RTPROC + RTLAMPS + RTSCENE + RTPIC + RTNET + objs)
50 schorsch 1.4
51 schorsch 1.19 MGF = Split('''mgf_parser.c mgf_object.c mgf_xf.c mgf_context.c''')
52     libmgf = env.StaticLibrary(target=radlib('mgf'), source=MGF)
53 schorsch 1.4
54 greg 1.22 REETZ = Split('g3affine.c g3flist.c g3sphere.c g3vector.c gbasic.c maxheap.c muc_randvar.c')
55 schorsch 1.19 libreetz = env.StaticLibrary(target=radlib('reetz'), source=REETZ)
56 schorsch 1.4
57     LIBFILES = Split('tmesh.cal')
58     env.Append(RAD_RLIBINSTALL=env.Install(env['RAD_RLIBDIR'], LIBFILES))
59
60     if env.has_key('OGL'):
61 schorsch 1.5 oglincl = env.get('CPPPATH', []) + env.get('OGLINCLUDE', [])
62     RGL = Split('rglfile.c rglmat.c rgldomat.c rglsurf.c rglinst.c rglsrc.c')
63     librgl = env.StaticLibrary(target=radlib('rgl'), source=RGL,
64     CPPPATH=oglincl)
65     Default(librgl)
66 schorsch 1.4
67 schorsch 1.17 # vim: set syntax=python:
