root/radiance/ray/src/common/SConscript
Revision: 1.15
Committed: Fri Apr 15 21:52:16 2011 UTC (14 years ago) by greg
CVS Tags: rad4R2P2, rad5R0, rad4R2, rad4R1, rad4R2P1
Changes since 1.14: +7 -6 lines
SCONS fixes for latest build
1 import os
2
3 Import('env')
4
5 # compose paths
6 def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name)
7
8 # custom flags
9 getlibpath = env.StaticObject(source='getlibpath.c',
10 CPPFLAGS='-DDEFPATH=\\":%s\\"' % env['RAD_RLIBDIR'])
11 tmapcolrs = env.StaticObject(source='tmapcolrs.c',
12 CPPFLAGS='-DPCOND=\\"pcond\\"')
13 ezxml = env.Object('ezxml.c',
14 CPPDEFINES=env.get('CPPDEFINES',[]) + env.get('EZXML_CPPDEFINES',[]))
15
16 # source and object dependencies
17 RTSCENE = Split('''cone.c face.c free_os.c instance.c readobj.c readoct.c
18 otypes.c objset.c octree.c readfargs.c modobject.c
19 font.c mesh.c readmesh.c tmesh.c sceneio.c xf.c''') #addobjnotify.c
20
21 RTMGFOBJ = Split('''mgf_parser.c mgf_object.c mgf_xf.c mgf_context.c''')
22 RTCOLOR = Split('''spec_rgb.c''')
23 RTTMAP = Split('''tonemap.c tmapluv.c tmaptiff.c tmap16bit.c''') + [tmapcolrs]
24 RTPIC = Split('color.c colrops.c resolu.c image.c bmpfile.c falsecolor.c')+ RTCOLOR + RTTMAP
25
26 RTERROR = Split('''error.c eputs.c wputs.c quit.c''')
27 RTCONT = Split('''lookup.c savestr.c savqstr.c bsdf.c ccolor.c ccyrgb.c bsdf_m.c bsdf_t.c disk2square.c hilbert.c loadbsdf.c ezxml''')
28 #RTCONT = Split('''lookup.c savestr.c savqstr.c bsdf.c ezxml getpath.c gethomedir.c paths.c words.c fvect.c multisamp.c mat4.c''') + [getlibpath]
29 RTMATH = Split('''fvect.c invmat4.c linregr.c mat4.c tcos.c urand.c urind.c
30 zeroes.c dircode.c clip.c multisamp.c plocate.c byteswap.c'''
31 ) + env.get('RAD_MATHCOMPAT', [])
32 RTFUNC = Split('''biggerlib.c caldefn.c calexpr.c calfunc.c calprnt.c
33 chanvalue.c''')
34 RTIO = Split('''fdate.c fgetline.c fgetval.c fgetword.c fputword.c loadvars.c
35 portio.c wordfile.c words.c header.c timegm.c''')
36 RTARGS = Split('''badarg.c expandarg.c''') + env.get('RAD_ARGSCOMPAT', [])
37 RTPATH = Split('''getpath.c gethomedir.c paths.c''') + [getlibpath]
38 RTLAMPS = Split('''fropen.c rexpr.c lamps.c''')+ [getlibpath]
39
40 RTPROC = Split('''process.c''') + env.get('RAD_PROCESS', [])
41
42 RTMEM = Split('ealloc.c bmalloc.c')
43 RTNET = Split('myhostname.c')
44 RTDUMMY = Split('addobjnotify.c')
45
46 STD = (RTERROR + RTPATH + RTARGS + RTIO + RTMATH + RTCONT + RTMEM +
47 RTFUNC + RTPROC + RTLAMPS)
48
49 ALL = RTSCENE + RTPIC + STD + RTNET
50
51 # build libraries
52 rtscene = env.StaticLibrary(target=radlib('rtscene'), source=RTSCENE)
53 libmgf = env.StaticLibrary(target=radlib('mgf'), source=RTMGFOBJ)
54 rterror = env.StaticLibrary(target=radlib('rterror'), source=RTERROR)
55 rtpath = env.StaticLibrary(target=radlib('rtpath'), source=RTPATH)
56 rtargs = env.StaticLibrary(target=radlib('rtargs'), source=RTARGS)
57 rtio = env.StaticLibrary(target=radlib('rtio'), source=RTIO)
58 rtmath = env.StaticLibrary(target=radlib('rtmath'), source=RTMATH)
59 rtcont = env.StaticLibrary(target=radlib('rtcont'), source=RTCONT)
60 rtmem = env.StaticLibrary(target=radlib('rtmem'), source=RTMEM)
61 rtfunc = env.StaticLibrary(target=radlib('rtfunc'), source=RTFUNC)
62 rtproc = env.StaticLibrary(target=radlib('rtproc'), source=RTPROC)
63 rtcolor = env.StaticLibrary(target=radlib('rtcolor'), source=RTCOLOR)
64 rtlamps = env.StaticLibrary(target=radlib('rtlamps'), source=RTLAMPS)
65 rtpic = env.StaticLibrary(target=radlib('rtpic'), source=RTPIC)
66 rtnet = env.StaticLibrary(target=radlib('rtnet'), source=RTNET)
67 # librtdummy is needed, because addobjnotify has different sizes depending
68 # on the program, and in some cases isn't actually needed at all.
69 # It should really be a pointer, and its content allocated
70 # dynamically during program initialization.
71 rtdummy = env.StaticLibrary(target=radlib('rtdummy'), source=RTDUMMY)
72
73 rtall = env.StaticLibrary(target=radlib('rtall'), source=ALL)
74 #librtrad = env.StaticLibrary(target=radlib('rtrad'), source=ALL)
75 #Default(librtrad)
76
77 LIBFILES = Split('tmesh.cal')
78 env.Append(RAD_RLIBINSTALL=env.Install(env['RAD_RLIBDIR'], LIBFILES))
79
80 if env.has_key('OGL'):
81 oglincl = env.get('CPPPATH', []) + env.get('OGLINCLUDE', [])
82 RGL = Split('rglfile.c rglmat.c rgldomat.c rglsurf.c rglinst.c rglsrc.c')
83 librgl = env.StaticLibrary(target=radlib('rgl'), source=RGL,
84 CPPPATH=oglincl)
85 Default(librgl)
86
