root/radiance/ray/src/common/SConscript
Fri Apr 15 21:52:16 2011 UTC (14 years, 3 months ago) by greg
Changes since 1.14: +7 -6 lines
Diff to previous 1.14 , to selected 1.13
SCONS fixes for latest build
Wed Dec 15 01:40:11 2010 UTC (14 years, 7 months ago) by greg
Changes since 1.13: +3 -1 lines
Diff to previous 1.13
Updated SConscript files for compiling under MINGW
Revision 1.13 - (view) (download) (annotate) - [selected]
Wed Jun 2 15:58:30 2010 UTC (15 years, 2 months ago) by greg
Diff to previous 1.12
Fixes to MINGW build
Thu Oct 22 20:39:14 2009 UTC (15 years, 9 months ago) by schorsch
Changes since 1.11: +3 -1 lines
Diff to previous 1.11 , to selected 1.13
Special flags for ezxml got lost in last SCons update.
Wed Oct 7 22:05:42 2009 UTC (15 years, 10 months ago) by schorsch
Diff to previous 1.10 , to selected 1.13
Adapting to move of ezxml.c to common and removal of mkillum4.c.
Tue Dec 23 15:03:59 2008 UTC (16 years, 7 months ago) by schorsch
Changes since 1.9: +8 -2 lines
Diff to previous 1.9 , to selected 1.13
Mon Apr 21 07:31:28 2008 UTC (17 years, 3 months ago) by schorsch
Diff to previous 1.8 , to selected 1.13
Scons update for mingw.
Fri Mar 10 19:40:12 2006 UTC (19 years, 5 months ago) by schorsch
Diff to previous 1.7 , to selected 1.13
Mon Sep 19 11:30:10 2005 UTC (19 years, 10 months ago) by schorsch
Diff to previous 1.6 , to selected 1.13
Wed Feb 2 00:16:02 2005 UTC (20 years, 6 months ago) by schorsch
Diff to previous 1.5 , to selected 1.13
Turned bmalloc.c into a standard module.
Sun Jul 4 12:08:47 2004 UTC (21 years, 1 month ago) by schorsch
Changes since 1.4: +5 -3 lines
Diff to previous 1.4 , to selected 1.13
Sat Jul 3 22:34:56 2004 UTC (21 years, 1 month ago) by schorsch
Changes since 1.3: +73 -73 lines
Diff to previous 1.3 , to selected 1.13
Converted from DOS to unix line endings.
Fri Mar 26 21:29:19 2004 UTC (21 years, 4 months ago) by schorsch
Diff to previous 1.2 , to selected 1.13
Small fixes to reduce warnings. Added bmpfile.c to SConscript.
Mon Oct 27 10:35:42 2003 UTC (21 years, 9 months ago) by schorsch
Changes since 1.1: +46 -18 lines
Diff to previous 1.1 , to selected 1.13
Tue Oct 21 19:27:28 2003 UTC (21 years, 9 months ago) by schorsch
Diff to selected 1.13
