SCONS fixes for latest build
Updated SConscript files for compiling under MINGW
Fixes to MINGW build
Special flags for ezxml got lost in last SCons update.
Adapting to move of ezxml.c to common and removal of mkillum4.c.
Scons update for mingw.
Turned bmalloc.c into a standard module.
Converted from DOS to unix line endings.
Small fixes to reduce warnings. Added bmpfile.c to SConscript.
