root/radiance/ray/src/common/SConscript
Revision: 1.6
Committed: Wed Feb 2 00:16:02 2005 UTC (20 years, 5 months ago) by schorsch
CVS Tags: rad3R7P2, rad3R7P1
Turned bmalloc.c into a standard module.
# User Rev Content
1 schorsch 1.4 import os
2
3     Import('env')
4
5     # compose paths
6     def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name)
7
8     # custom flags
9     getlibpath = env.StaticObject(source='getlibpath.c',
10     CPPFLAGS='-DDEFPATH=\\":%s\\"' % env['RAD_RLIBDIR'])
11     tmapcolrs = env.StaticObject(source='tmapcolrs.c',
12     CPPFLAGS='-DPCOND=\\"pcond\\"')
13
14     # source and object dependencies
15     RTSCENE = Split('''cone.c face.c free_os.c instance.c readobj.c readoct.c
16     otypes.c objset.c octree.c readfargs.c modobject.c addobjnotify.c
17     font.c mesh.c readmesh.c tmesh.c sceneio.c xf.c''')
18
19     RTCOLOR = Split('''spec_rgb.c''')
20     RTTMAP = Split('''tonemap.c tmapluv.c tmaptiff.c tmap16bit.c''') + [tmapcolrs]
21     RTPIC = Split('color.c colrops.c resolu.c image.c bmpfile.c')+ RTCOLOR + RTTMAP
22
23     RTERROR = Split('''error.c eputs.c wputs.c quit.c''')
24     RTCONT = Split('''lookup.c savestr.c savqstr.c''')
25     RTMATH = Split('''fvect.c invmat4.c linregr.c mat4.c tcos.c urand.c urind.c
26     zeroes.c dircode.c clip.c multisamp.c plocate.c'''
27     ) + env.get('RAD_MATHCOMPAT', [])
28     RTFUNC = Split('''biggerlib.c caldefn.c calexpr.c calfunc.c calprnt.c
29     chanvalue.c''')
30     RTIO = Split('''fdate.c fgetline.c fgetval.c fgetword.c fputword.c loadvars.c
31     portio.c wordfile.c words.c header.c''')
32     RTARGS = Split('''badarg.c expandarg.c''') + env.get('RAD_ARGSCOMPAT', [])
33     RTPATH = Split('''getpath.c gethomedir.c paths.c''') + [getlibpath]
34     RTLAMPS = Split('''fropen.c rexpr.c lamps.c''')
35
36     RTPROC = Split('''process.c''') + env.get('RAD_PROCESS', [])
37
38 schorsch 1.6 RTMEM = Split('ealloc.c bmalloc.c') + env.get('RAD_MEMCOMPAT', [])
39 schorsch 1.4 RTNET = Split('myhostname.c')
40
41     STD = (RTERROR + RTPATH + RTARGS + RTIO + RTMATH + RTCONT + RTMEM +
42     RTFUNC + RTPROC + RTLAMPS)
43
44     ALL = RTSCENE + RTPIC + STD + RTNET + env.get('RAD_COMPAT',[])
45
46     # build libraries
47     rtscene = env.StaticLibrary(target=radlib('rtscene'), source=RTSCENE)
48
49     rterror = env.StaticLibrary(target=radlib('rterror'), source=RTERROR)
50     rtpath = env.StaticLibrary(target=radlib('rtpath'), source=RTPATH)
51     rtargs = env.StaticLibrary(target=radlib('rtargs'), source=RTARGS)
52     rtio = env.StaticLibrary(target=radlib('rtio'), source=RTIO)
53     rtmath = env.StaticLibrary(target=radlib('rtmath'), source=RTMATH)
54     rtcont = env.StaticLibrary(target=radlib('rtcont'), source=RTCONT)
55     rtmem = env.StaticLibrary(target=radlib('rtmem'), source=RTMEM)
56     rtfunc = env.StaticLibrary(target=radlib('rtfunc'), source=RTFUNC)
57     rtproc = env.StaticLibrary(target=radlib('rtproc'), source=RTPROC)
58     rtcolor = env.StaticLibrary(target=radlib('rtcolor'), source=RTCOLOR)
59     rtlamps = env.StaticLibrary(target=radlib('rtlamps'), source=RTLAMPS)
60     rtpic = env.StaticLibrary(target=radlib('rtpic'), source=RTPIC)
61     rtnet = env.StaticLibrary(target=radlib('rtnet'), source=RTNET)
62
63     #librt = env.StaticLibrary(target=radlib('rt'), source=ALL)
64     #Default(librt)
65
66     LIBFILES = Split('tmesh.cal')
67     env.Append(RAD_RLIBINSTALL=env.Install(env['RAD_RLIBDIR'], LIBFILES))
68
69     if env.has_key('OGL'):
70 schorsch 1.5 oglincl = env.get('CPPPATH', []) + env.get('OGLINCLUDE', [])
71     RGL = Split('rglfile.c rglmat.c rgldomat.c rglsurf.c rglinst.c rglsrc.c')
72     librgl = env.StaticLibrary(target=radlib('rgl'), source=RGL,
73     CPPPATH=oglincl)
74     Default(librgl)
75 schorsch 1.4
