root/Development/ray/src/common/SConscript
Revision: 1.15
Committed: Fri Apr 15 21:52:16 2011 UTC (14 years, 6 months ago) by greg
CVS Tags: rad5R0, rad4R2, rad4R1, rad4R2P1, rad4R2P2
Changes since 1.14: +7 -6 lines
SCONS fixes for latest build
# User Rev Content
1 schorsch 1.4 import os
2
3     Import('env')
4
5     # compose paths
6     def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name)
7
8     # custom flags
9     getlibpath = env.StaticObject(source='getlibpath.c',
10     CPPFLAGS='-DDEFPATH=\\":%s\\"' % env['RAD_RLIBDIR'])
11     tmapcolrs = env.StaticObject(source='tmapcolrs.c',
12     CPPFLAGS='-DPCOND=\\"pcond\\"')
13 schorsch 1.12 ezxml = env.Object('ezxml.c',
14     CPPDEFINES=env.get('CPPDEFINES',[]) + env.get('EZXML_CPPDEFINES',[]))
15 schorsch 1.4
16     # source and object dependencies
17     RTSCENE = Split('''cone.c face.c free_os.c instance.c readobj.c readoct.c
18 schorsch 1.10 otypes.c objset.c octree.c readfargs.c modobject.c
19     font.c mesh.c readmesh.c tmesh.c sceneio.c xf.c''') #addobjnotify.c
20 schorsch 1.4
21 greg 1.15 RTMGFOBJ = Split('''mgf_parser.c mgf_object.c mgf_xf.c mgf_context.c''')
22 schorsch 1.4 RTCOLOR = Split('''spec_rgb.c''')
23     RTTMAP = Split('''tonemap.c tmapluv.c tmaptiff.c tmap16bit.c''') + [tmapcolrs]
24 greg 1.15 RTPIC = Split('color.c colrops.c resolu.c image.c bmpfile.c falsecolor.c')+ RTCOLOR + RTTMAP
25 schorsch 1.4
26     RTERROR = Split('''error.c eputs.c wputs.c quit.c''')
27 greg 1.15 RTCONT = Split('''lookup.c savestr.c savqstr.c bsdf.c ccolor.c ccyrgb.c bsdf_m.c bsdf_t.c disk2square.c hilbert.c loadbsdf.c ezxml''')
28     #RTCONT = Split('''lookup.c savestr.c savqstr.c bsdf.c ezxml getpath.c gethomedir.c paths.c words.c fvect.c multisamp.c mat4.c''') + [getlibpath]
29 schorsch 1.4 RTMATH = Split('''fvect.c invmat4.c linregr.c mat4.c tcos.c urand.c urind.c
30 schorsch 1.9 zeroes.c dircode.c clip.c multisamp.c plocate.c byteswap.c'''
31 schorsch 1.4 ) + env.get('RAD_MATHCOMPAT', [])
32     RTFUNC = Split('''biggerlib.c caldefn.c calexpr.c calfunc.c calprnt.c
33     chanvalue.c''')
34     RTIO = Split('''fdate.c fgetline.c fgetval.c fgetword.c fputword.c loadvars.c
35 greg 1.13 portio.c wordfile.c words.c header.c timegm.c''')
36 schorsch 1.4 RTARGS = Split('''badarg.c expandarg.c''') + env.get('RAD_ARGSCOMPAT', [])
37     RTPATH = Split('''getpath.c gethomedir.c paths.c''') + [getlibpath]
38 greg 1.15 RTLAMPS = Split('''fropen.c rexpr.c lamps.c''')+ [getlibpath]
39 schorsch 1.4
40     RTPROC = Split('''process.c''') + env.get('RAD_PROCESS', [])
41
42 schorsch 1.7 RTMEM = Split('ealloc.c bmalloc.c')
43 schorsch 1.4 RTNET = Split('myhostname.c')
44 schorsch 1.10 RTDUMMY = Split('addobjnotify.c')
45 schorsch 1.4
46     STD = (RTERROR + RTPATH + RTARGS + RTIO + RTMATH + RTCONT + RTMEM +
47     RTFUNC + RTPROC + RTLAMPS)
48
49 greg 1.13 ALL = RTSCENE + RTPIC + STD + RTNET
50 schorsch 1.4
51     # build libraries
52     rtscene = env.StaticLibrary(target=radlib('rtscene'), source=RTSCENE)
53 greg 1.15 libmgf = env.StaticLibrary(target=radlib('mgf'), source=RTMGFOBJ)
54 schorsch 1.4 rterror = env.StaticLibrary(target=radlib('rterror'), source=RTERROR)
55     rtpath = env.StaticLibrary(target=radlib('rtpath'), source=RTPATH)
56     rtargs = env.StaticLibrary(target=radlib('rtargs'), source=RTARGS)
57     rtio = env.StaticLibrary(target=radlib('rtio'), source=RTIO)
58     rtmath = env.StaticLibrary(target=radlib('rtmath'), source=RTMATH)
59     rtcont = env.StaticLibrary(target=radlib('rtcont'), source=RTCONT)
60     rtmem = env.StaticLibrary(target=radlib('rtmem'), source=RTMEM)
61     rtfunc = env.StaticLibrary(target=radlib('rtfunc'), source=RTFUNC)
62     rtproc = env.StaticLibrary(target=radlib('rtproc'), source=RTPROC)
63     rtcolor = env.StaticLibrary(target=radlib('rtcolor'), source=RTCOLOR)
64     rtlamps = env.StaticLibrary(target=radlib('rtlamps'), source=RTLAMPS)
65     rtpic = env.StaticLibrary(target=radlib('rtpic'), source=RTPIC)
66     rtnet = env.StaticLibrary(target=radlib('rtnet'), source=RTNET)
67 schorsch 1.10 # librtdummy is needed, because addobjnotify has different sizes depending
68     # on the program, and in some cases isn't actually needed at all.
69     # It should really be a pointer, and its content allocated
70     # dynamically during program initialization.
71     rtdummy = env.StaticLibrary(target=radlib('rtdummy'), source=RTDUMMY)
72 schorsch 1.4
73 greg 1.15 rtall = env.StaticLibrary(target=radlib('rtall'), source=ALL)
74 schorsch 1.8 #librtrad = env.StaticLibrary(target=radlib('rtrad'), source=ALL)
75     #Default(librtrad)
76 schorsch 1.4
77     LIBFILES = Split('tmesh.cal')
78     env.Append(RAD_RLIBINSTALL=env.Install(env['RAD_RLIBDIR'], LIBFILES))
79
80     if env.has_key('OGL'):
81 schorsch 1.5 oglincl = env.get('CPPPATH', []) + env.get('OGLINCLUDE', [])
82     RGL = Split('rglfile.c rglmat.c rgldomat.c rglsurf.c rglinst.c rglsrc.c')
83     librgl = env.StaticLibrary(target=radlib('rgl'), source=RGL,
84     CPPPATH=oglincl)
85     Default(librgl)
86 schorsch 1.4
