root/Development/ray/src/common/Rmakefile
Tue Jun 3 21:31:51 2025 UTC (4 months, 4 weeks ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.93: +3 -3 lines
Diff to previous 2.93 , to selected 2.12
Tue Dec 3 01:11:43 2024 UTC (10 months, 4 weeks ago) by greg
Changes since 2.92: +2 -2 lines
Diff to previous 2.92 , to selected 2.12
Wed Aug 14 20:05:23 2024 UTC (14 months, 2 weeks ago) by greg
Changes since 2.91: +16 -4 lines
Diff to previous 2.91 , to selected 2.12
Fri Aug 2 18:47:25 2024 UTC (15 months ago) by greg
Changes since 2.90: +5 -3 lines
Diff to previous 2.90 , to selected 2.12
feat(gensdaymtx,epw2wea,genssky): Taoning added new gensdaymtx and updated others
Sun Mar 6 16:27:55 2022 UTC (3 years, 7 months ago) by greg
Diff to previous 2.89 , to selected 2.12
perf: Turned off alignment for Radiance picture files (not needed)
Fri Dec 3 18:10:48 2021 UTC (3 years, 11 months ago) by greg
Changes since 2.88: +6 -4 lines
Diff to previous 2.88 , to selected 2.12
refactor: moved depth-of-field sampling to separate module
Fri Nov 19 22:51:31 2021 UTC (3 years, 11 months ago) by greg
Changes since 2.87: +4 -4 lines
Diff to previous 2.87 , to selected 2.12
refactor: made font load errors non-fatal
Fri Apr 9 15:26:41 2021 UTC (4 years, 6 months ago) by greg
Changes since 2.86: +3 -1 lines
Diff to previous 2.86 , to selected 2.12
feat: added growBoundingBox() to compute scene boundaries
Fri Mar 12 03:59:25 2021 UTC (4 years, 7 months ago) by greg
Changes since 2.85: +4 -2 lines
Diff to previous 2.85 , to selected 2.12
feat: added routine to triangulate .OBJ scene in memory
Tue Apr 21 02:42:35 2020 UTC (5 years, 6 months ago) by greg
Changes since 2.84: +2 -2 lines
Diff to previous 2.84 , to selected 2.12
Updated clean function
Mon Mar 30 18:31:20 2020 UTC (5 years, 7 months ago) by greg
Changes since 2.83: +2 -2 lines
Diff to previous 2.83 , to selected 2.12
Added missing mention of new library libwfobj.a
Mon Mar 30 18:28:35 2020 UTC (5 years, 7 months ago) by greg
Changes since 2.82: +15 -2 lines
Diff to previous 2.82 , to selected 2.12
Thu Nov 7 23:20:28 2019 UTC (5 years, 11 months ago) by greg
Diff to previous 2.81 , to selected 2.12
Fri Jul 26 16:18:06 2019 UTC (6 years, 3 months ago) by greg
Changes since 2.80: +11 -2 lines
Diff to previous 2.80 , to selected 2.12
Tue Jul 3 22:29:01 2018 UTC (7 years, 4 months ago) by greg
Changes since 2.79: +6 -5 lines
Diff to previous 2.79 , to selected 2.12
Added AR variable to provide a way to override standard library builder
Thu Apr 19 15:31:27 2018 UTC (7 years, 6 months ago) by greg
Diff to previous 2.78 , to selected 2.12
Changed HUGE reference to FHUGE + removed references to unused module maxheap.c
Wed Jan 17 22:36:44 2018 UTC (7 years, 9 months ago) by greg
Diff to previous 2.77 , to selected 2.12
Added strlcpy.c compatibility module for non-BSD systems
Thu Aug 18 17:57:57 2016 UTC (9 years, 2 months ago) by greg
Changes since 2.76: +3 -1 lines
Diff to previous 2.76 , to selected 2.12
Thu Jul 14 17:32:12 2016 UTC (9 years, 3 months ago) by greg
Diff to previous 2.75 , to selected 2.12
Changes to evalglare by Jan Wienold
Wed Feb 3 18:33:18 2016 UTC (9 years, 9 months ago) by greg
Changes since 2.74: +4 -1 lines
Diff to previous 2.74 , to selected 2.12
Added testBSDF build and provided for color (XYZ) output
Tue Feb 2 18:02:32 2016 UTC (9 years, 9 months ago) by greg
Changes since 2.73: +4 -3 lines
Diff to previous 2.73 , to selected 2.12
Wed Aug 12 23:07:59 2015 UTC (10 years, 2 months ago) by greg
Changes since 2.72: +22 -3 lines
Diff to previous 2.72 , to selected 2.12
Thu Jul 16 05:08:57 2015 UTC (10 years, 3 months ago) by greg
Diff to previous 2.71 , to selected 2.12
Added required #include for drand48()
Tue Mar 4 17:06:13 2014 UTC (11 years, 8 months ago) by greg
Changes since 2.70: +4 -1 lines
Diff to previous 2.70 , to selected 2.12
Changed to using _popen and _pclose under MicroSoft VisualStudio
Fri Feb 7 19:00:45 2014 UTC (11 years, 8 months ago) by greg
Changes since 2.69: +3 -1 lines
Diff to previous 2.69 , to selected 2.12
Updated with dependency on triangulate.{c,h}
Thu Jan 23 23:51:41 2014 UTC (11 years, 9 months ago) by greg
Changes since 2.68: +2 -2 lines
Diff to previous 2.68 , to selected 2.12
Added routines to triangulate polygons
Sat Feb 9 00:55:40 2013 UTC (12 years, 8 months ago) by greg
Changes since 2.67: +5 -3 lines
Diff to previous 2.67 , to selected 2.12
Created routines for interpolating anisotropic 2-D samples
Wed Aug 10 22:28:45 2011 UTC (14 years, 2 months ago) by greg
Diff to previous 2.66 , to selected 2.12
Minor bug fixes
Thu Jun 23 16:00:37 2011 UTC (14 years, 4 months ago) by greg
Changes since 2.65: +2 -6 lines
Diff to previous 2.65 , to selected 2.12
Additional check for empty MGF string
Sun Apr 24 19:39:21 2011 UTC (14 years, 6 months ago) by greg
Diff to previous 2.64 , to selected 2.12
Partial implementation of variable-resolution BSDFs
Fri Feb 18 02:41:55 2011 UTC (14 years, 8 months ago) by greg
Changes since 2.63: +6 -2 lines
Diff to previous 2.63 , to selected 2.12
Minor fixes and adjustments
Fri Feb 18 00:40:25 2011 UTC (14 years, 8 months ago) by greg
Changes since 2.62: +34 -8 lines
Diff to previous 2.62 , to selected 2.12
Wed Jun 17 20:41:47 2009 UTC (16 years, 4 months ago) by greg
Changes since 2.61: +10 -3 lines
Diff to previous 2.61 , to selected 2.12
Thu May 21 18:08:43 2009 UTC (16 years, 5 months ago) by greg
Changes since 2.60: +4 -1 lines
Diff to previous 2.60 , to selected 2.12
Sat May 31 19:38:36 2008 UTC (17 years, 5 months ago) by greg
Changes since 2.59: +7 -7 lines
Diff to previous 2.59 , to selected 2.12
Eliminated tifftypes.h in favor of tiff.h throughout
Sat Dec 23 17:27:45 2006 UTC (18 years, 10 months ago) by greg
Diff to previous 2.58 , to selected 2.12
Fri Mar 10 19:40:12 2006 UTC (19 years, 7 months ago) by schorsch
Changes since 2.57: +8 -8 lines
Diff to previous 2.57 , to selected 2.12
Tue Feb 14 02:51:43 2006 UTC (19 years, 8 months ago) by greg
Changes since 2.56: +8 -6 lines
Diff to previous 2.56 , to selected 2.12
Fixes for cross-compiling under Mac OS X
Mon Nov 14 22:18:18 2005 UTC (19 years, 11 months ago) by greg
Changes since 2.55: +4 -2 lines
Diff to previous 2.55 , to selected 2.12
Fri Feb 25 06:39:44 2005 UTC (20 years, 8 months ago) by greg
Diff to previous 2.54 , to selected 2.12
The header "uvcode.h" is no longer referenced by tmapluv.c
Wed Feb 2 00:09:14 2005 UTC (20 years, 9 months ago) by greg
Diff to previous 2.53 , to selected 2.12
Thu Jan 20 04:08:00 2005 UTC (20 years, 9 months ago) by greg
Changes since 2.52: +2 -2 lines
Diff to previous 2.52 , to selected 2.12
Minor dependency cleanup
Fri Nov 5 03:31:36 2004 UTC (21 years ago) by greg
Diff to previous 2.51 , to selected 2.12
Wed Oct 27 23:36:09 2004 UTC (21 years ago) by greg
CVS Tags: rad3R6P1
Diff to previous 2.50 , to selected 2.12
Wed Oct 27 23:23:47 2004 UTC (21 years ago) by greg
Diff to previous 2.49 , to selected 2.12
Fri Mar 26 03:11:50 2004 UTC (21 years, 7 months ago) by greg
Diff to previous 2.48 , to selected 2.12
Mon Nov 10 16:41:52 2003 UTC (21 years, 11 months ago) by greg
Changes since 2.47: +1 -3 lines
Diff to previous 2.47 , to selected 2.12
Tue Oct 28 13:16:00 2003 UTC (22 years ago) by greg
Diff to previous 2.46 , to selected 2.12
Minor correction to last check-in which caused build to fail using rmake
Mon Oct 27 10:19:31 2003 UTC (22 years ago) by schorsch
Diff to previous 2.45 , to selected 2.12
Mon Oct 20 15:10:18 2003 UTC (22 years ago) by greg
Diff to previous 2.44 , to selected 2.12
Wed Aug 20 09:35:56 2003 UTC (22 years, 2 months ago) by schorsch
Diff to previous 2.43 , to selected 2.12
Mon Jul 14 04:56:53 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.42: +6 -4 lines
Diff to previous 2.42 , to selected 2.12
Fri Jun 27 06:53:21 2003 UTC (22 years, 4 months ago) by greg
Changes since 2.41: +14 -4 lines
Diff to previous 2.41 , to selected 2.12
Thu Jun 26 00:58:09 2003 UTC (22 years, 4 months ago) by schorsch
Diff to previous 2.40 , to selected 2.12
Sun Jun 8 12:03:09 2003 UTC (22 years, 5 months ago) by schorsch
Diff to previous 2.39 , to selected 2.12
Sun Apr 27 06:08:03 2003 UTC (22 years, 6 months ago) by greg
Changes since 2.38: +1 -1 lines
Diff to previous 2.38 , to selected 2.12
Fri Mar 14 21:27:45 2003 UTC (22 years, 7 months ago) by greg
Changes since 2.37: +8 -7 lines
Diff to previous 2.37 , to selected 2.12
Mon Mar 10 19:38:19 2003 UTC (22 years, 7 months ago) by greg
Changes since 2.36: +15 -6 lines
Diff to previous 2.36 , to selected 2.12
Tue Mar 4 05:49:21 2003 UTC (22 years, 8 months ago) by greg
Diff to previous 2.35 , to selected 2.12
Sat Feb 22 02:07:21 2003 UTC (22 years, 8 months ago) by greg
Changes since 2.34: +15 -19 lines
Diff to previous 2.34 , to selected 2.12
Wed Dec 16 18:16:12 1998 UTC (26 years, 10 months ago) by gwlarson
Diff to previous 2.33 , to selected 2.12
added new tcos() table-lookup function and tsin() and ttan() macros
added DCHECK(test,error_type,error_message) macro for debugging checks
Fri Dec 4 18:01:55 1998 UTC (26 years, 11 months ago) by gwlarson
Diff to previous 2.32 , to selected 2.12
Wed Oct 28 09:30:41 1998 UTC (27 years ago) by gwlarson
Changes since 2.31: +3 -0 lines
Diff to previous 2.31 , to selected 2.12
made pcond calling optional in tmapcolrs.c
Fri Oct 23 09:26:51 1998 UTC (27 years ago) by gwlarson
Diff to previous 2.30 , to selected 2.12
added stupid unnecessary module for addobjnotify[]
Thu Oct 22 13:53:31 1998 UTC (27 years ago) by gwlarson
Changes since 2.29: +4 -2 lines
Diff to previous 2.29 , to selected 2.12
added tmapluv.o module
Tue Aug 25 10:20:31 1998 UTC (27 years, 2 months ago) by gwlarson
Changes since 2.28: +1 -3 lines
Diff to previous 2.28 , to selected 2.12
added include of standard.h to readfargs.c
Tue Jun 9 16:18:49 1998 UTC (27 years, 5 months ago) by gwlarson
Diff to previous 2.27 , to selected 2.12
added missing SPECIAL entries
Tue Jun 9 11:37:52 1998 UTC (27 years, 5 months ago) by gwlarson
Changes since 2.26: +12 -1 lines
Diff to previous 2.26 , to selected 2.12
added rgl* modules for converting Radiance scenes into OpenGL
Mon Dec 1 09:54:59 1997 UTC (27 years, 11 months ago) by gregl
Diff to previous 2.25 , to selected 2.12
Tue Nov 11 19:53:28 1997 UTC (27 years, 11 months ago) by gregl
Diff to previous 2.24 , to selected 2.12
Tue Apr 15 16:53:30 1997 UTC (28 years, 6 months ago) by greg
Changes since 2.23: +5 -1 lines
Diff to previous 2.23 , to selected 2.12
added tone mapping library functions (see tonemap.h)
Tue Mar 18 16:01:08 1997 UTC (28 years, 7 months ago) by greg
Changes since 2.22: +4 -1 lines
Diff to previous 2.22 , to selected 2.12
Fri Mar 7 15:45:32 1997 UTC (28 years, 8 months ago) by greg
Changes since 2.21: +1 -1 lines
Diff to previous 2.21 , to selected 2.12
added new set routines
Wed Jan 8 12:08:05 1997 UTC (28 years, 10 months ago) by greg
Diff to previous 2.20 , to selected 2.12
changed move command to avoid problems with uncreated src/lib directory
Wed Feb 7 16:36:01 1996 UTC (29 years, 9 months ago) by greg
Diff to previous 2.19 , to selected 2.12
Mon Oct 16 09:21:43 1995 UTC (30 years ago) by greg
Diff to previous 2.18 , to selected 2.12
added dependency on color.h to lamps.o for cie_rgb() macro
Fri Jun 30 16:06:38 1995 UTC (30 years, 4 months ago) by greg
Diff to previous 2.17 , to selected 2.12
added comments to font file using new fgetval() routine
Mon Apr 3 16:47:41 1995 UTC (30 years, 7 months ago) by greg
moved clip.c and plocate.c to library
Wed Jul 6 15:15:19 1994 UTC (31 years, 4 months ago) by greg
added lookup.c
Fri Jul 1 14:43:18 1994 UTC (31 years, 4 months ago) by greg
Changes since 2.14: +0 -3 lines
removed LIBDIR from fropen.o compile line
Wed Jun 29 18:18:07 1994 UTC (31 years, 4 months ago) by greg
corrected dependency
Thu Apr 14 04:44:42 1994 UTC (31 years, 6 months ago) by greg
Diff to previous 2.12
Tue Apr 12 15:18:16 1994 UTC (31 years, 6 months ago) by greg
added invmat4.o
Wed Mar 10 19:39:22 1993 UTC (32 years, 8 months ago) by greg
added fdate module
Sat Oct 17 08:08:00 1992 UTC (33 years ago) by greg
added wordstring() function to wordfile.c
created expandargs.c
Tue Sep 8 09:09:19 1992 UTC (33 years, 2 months ago) by greg
Mon Jul 13 15:36:26 1992 UTC (33 years, 3 months ago) by greg
moved portable i/o routines to portio.c
Tue Jul 7 14:26:06 1992 UTC (33 years, 4 months ago) by greg
moved strcmp.o to COMPAT define and fixed clean operation
Fri Jul 3 10:51:48 1992 UTC (33 years, 4 months ago) by greg
moved strcmp() to separate module
Wed Jul 1 15:10:37 1992 UTC (33 years, 4 months ago) by greg
Wed Jun 24 17:53:00 1992 UTC (33 years, 4 months ago) by greg
finally got proptext() working
Thu Mar 19 09:32:03 1992 UTC (33 years, 7 months ago) by greg
added vfork.h include file
Wed Mar 4 09:59:37 1992 UTC (33 years, 8 months ago) by greg
added wordfile module
Tue Nov 12 16:55:49 1991 UTC (33 years, 11 months ago) by greg
Diff to previous 1.19 , to selected 2.12
Thu Nov 7 11:03:57 1991 UTC (34 years ago) by greg
Diff to previous 1.18 , to selected 2.12
added badarg() routine for argument checking
Wed Oct 23 13:43:17 1991 UTC (34 years ago) by greg
Diff to previous 1.17 , to selected 2.12
Wed Oct 23 10:44:35 1991 UTC (34 years ago) by greg
Diff to previous 1.16 , to selected 2.12
standardized macro settings
Wed Oct 9 13:00:21 1991 UTC (34 years, 1 month ago) by greg
Changes since 1.15: +6 -4 lines
Diff to previous 1.15 , to selected 2.12
added COMPAT define
Thu Aug 22 11:55:30 1991 UTC (34 years, 2 months ago) by greg
Diff to previous 1.14 , to selected 2.12
added multisamp
Thu Aug 22 09:21:20 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.13: +5 -4 lines
Diff to previous 1.13 , to selected 2.12
moved library to ../lib
Tue Aug 20 15:33:45 1991 UTC (34 years, 2 months ago) by greg
Diff to previous 1.12 , to selected 2.12
added erf.o to SYSOBJ
Mon Aug 12 13:07:00 1991 UTC (34 years, 2 months ago) by greg
Diff to previous 1.11 , to selected 2.12
moved urind(3) from urand.c to urind.c and added peano.c
Mon Jul 29 15:47:43 1991 UTC (34 years, 3 months ago) by greg
Diff to previous 1.10 , to selected 2.12
added back in otypes.h include to modobject.c
Wed Jul 24 12:06:34 1991 UTC (34 years, 3 months ago) by greg
Diff to previous 1.9 , to selected 2.12
moved routines from otypes.c to modobject.c
Mon Jul 22 14:33:05 1991 UTC (34 years, 3 months ago) by greg
Diff to previous 1.8 , to selected 2.12
created words.c for manipulating words in strings
Mon Jul 22 11:22:59 1991 UTC (34 years, 3 months ago) by greg
Diff to previous 1.7 , to selected 2.12
removed scanf calls from readfargs
Mon Jul 22 09:39:18 1991 UTC (34 years, 3 months ago) by greg
Diff to previous 1.6 , to selected 2.12
added process.o module to library
Fri Jul 19 13:40:49 1991 UTC (34 years, 3 months ago) by greg
Diff to previous 1.5 , to selected 2.12
distributed misc.c into error.c, getpath.c and strmisc.c
Fri Jul 19 09:25:45 1991 UTC (34 years, 3 months ago) by greg
Changes since 1.4: +6 -1 lines
Diff to previous 1.4 , to selected 2.12
added separate readfargs() and freefargs() routines
Tue Jul 16 10:28:51 1991 UTC (34 years, 3 months ago) by greg
Changes since 1.3: +12 -0 lines
Diff to previous 1.3 , to selected 2.12
added calcomp routines to library
Mon Jul 15 12:00:34 1991 UTC (34 years, 3 months ago) by greg
Changes since 1.2: +6 -2 lines
Diff to previous 1.2 , to selected 2.12
added fropen.o to library
Mon Jul 15 11:40:49 1991 UTC (34 years, 3 months ago) by greg
Diff to previous 1.1 , to selected 2.12
added missing dependency
Mon Jul 15 11:25:02 1991 UTC (34 years, 3 months ago) by greg
Diff to selected 2.12
