root/radiance/ray/src/common/Rmakefile
Fri Mar 26 03:11:50 2004 UTC (20 years, 1 month ago) by greg
Diff to previous 2.48 , to selected 1.16
Mon Nov 10 16:41:52 2003 UTC (20 years, 5 months ago) by greg
Changes since 2.47: +1 -3 lines
Diff to previous 2.47 , to selected 1.16
Tue Oct 28 13:16:00 2003 UTC (20 years, 6 months ago) by greg
Diff to previous 2.46 , to selected 1.16
Minor correction to last check-in which caused build to fail using rmake
Diff to previous 2.45 , to selected 1.16
Mon Oct 20 15:10:18 2003 UTC (20 years, 6 months ago) by greg
Diff to previous 2.44 , to selected 1.16
Wed Aug 20 09:35:56 2003 UTC (20 years, 8 months ago) by schorsch
Diff to previous 2.43 , to selected 1.16
Mon Jul 14 04:56:53 2003 UTC (20 years, 9 months ago) by greg
Changes since 2.42: +6 -4 lines
Diff to previous 2.42 , to selected 1.16
Changes since 2.41: +14 -4 lines
Diff to previous 2.41 , to selected 1.16
Diff to previous 2.40 , to selected 1.16
Sun Jun 8 12:03:09 2003 UTC (20 years, 11 months ago) by schorsch
Diff to previous 2.39 , to selected 1.16
Sun Apr 27 06:08:03 2003 UTC (21 years ago) by greg
Changes since 2.38: +1 -1 lines
Diff to previous 2.38 , to selected 1.16
Fri Mar 14 21:27:45 2003 UTC (21 years, 1 month ago) by greg
Changes since 2.37: +8 -7 lines
Diff to previous 2.37 , to selected 1.16
Mon Mar 10 19:38:19 2003 UTC (21 years, 1 month ago) by greg
Changes since 2.36: +15 -6 lines
Diff to previous 2.36 , to selected 1.16
Tue Mar 4 05:49:21 2003 UTC (21 years, 2 months ago) by greg
Diff to previous 2.35 , to selected 1.16
Sat Feb 22 02:07:21 2003 UTC (21 years, 2 months ago) by greg
Changes since 2.34: +15 -19 lines
Diff to previous 2.34 , to selected 1.16
Wed Dec 16 18:16:12 1998 UTC (25 years, 4 months ago) by gwlarson
Diff to previous 2.33 , to selected 1.16
added new tcos() table-lookup function and tsin() and ttan() macros
added DCHECK(test,error_type,error_message) macro for debugging checks
Fri Dec 4 18:01:55 1998 UTC (25 years, 5 months ago) by gwlarson
Diff to previous 2.32 , to selected 1.16
Wed Oct 28 09:30:41 1998 UTC (25 years, 6 months ago) by gwlarson
Changes since 2.31: +3 -0 lines
Diff to previous 2.31 , to selected 1.16
made pcond calling optional in tmapcolrs.c
Fri Oct 23 09:26:51 1998 UTC (25 years, 6 months ago) by gwlarson
Diff to previous 2.30 , to selected 1.16
added stupid unnecessary module for addobjnotify[]
Thu Oct 22 13:53:31 1998 UTC (25 years, 6 months ago) by gwlarson
Changes since 2.29: +4 -2 lines
Diff to previous 2.29 , to selected 1.16
added tmapluv.o module
Tue Aug 25 10:20:31 1998 UTC (25 years, 8 months ago) by gwlarson
Changes since 2.28: +1 -3 lines
Diff to previous 2.28 , to selected 1.16
added include of standard.h to readfargs.c
Tue Jun 9 16:18:49 1998 UTC (25 years, 11 months ago) by gwlarson
Diff to previous 2.27 , to selected 1.16
added missing SPECIAL entries
Tue Jun 9 11:37:52 1998 UTC (25 years, 11 months ago) by gwlarson
Changes since 2.26: +12 -1 lines
Diff to previous 2.26 , to selected 1.16
added rgl* modules for converting Radiance scenes into OpenGL
Mon Dec 1 09:54:59 1997 UTC (26 years, 5 months ago) by gregl
Diff to previous 2.25 , to selected 1.16
Tue Nov 11 19:53:28 1997 UTC (26 years, 5 months ago) by gregl
Diff to previous 2.24 , to selected 1.16
Tue Apr 15 16:53:30 1997 UTC (27 years ago) by greg
Changes since 2.23: +5 -1 lines
Diff to previous 2.23 , to selected 1.16
added tone mapping library functions (see tonemap.h)
Tue Mar 18 16:01:08 1997 UTC (27 years, 1 month ago) by greg
Changes since 2.22: +4 -1 lines
Diff to previous 2.22 , to selected 1.16
Fri Mar 7 15:45:32 1997 UTC (27 years, 2 months ago) by greg
Changes since 2.21: +1 -1 lines
Diff to previous 2.21 , to selected 1.16
added new set routines
Wed Jan 8 12:08:05 1997 UTC (27 years, 4 months ago) by greg
Diff to previous 2.20 , to selected 1.16
changed move command to avoid problems with uncreated src/lib directory
Wed Feb 7 16:36:01 1996 UTC (28 years, 3 months ago) by greg
Diff to previous 2.19 , to selected 1.16
Mon Oct 16 09:21:43 1995 UTC (28 years, 6 months ago) by greg
Diff to previous 2.18 , to selected 1.16
added dependency on color.h to lamps.o for cie_rgb() macro
Fri Jun 30 16:06:38 1995 UTC (28 years, 10 months ago) by greg
Diff to previous 2.17 , to selected 1.16
added comments to font file using new fgetval() routine
Mon Apr 3 16:47:41 1995 UTC (29 years, 1 month ago) by greg
Diff to previous 2.16 , to selected 1.16
moved clip.c and plocate.c to library
Wed Jul 6 15:15:19 1994 UTC (29 years, 10 months ago) by greg
Diff to previous 2.15 , to selected 1.16
added lookup.c
Fri Jul 1 14:43:18 1994 UTC (29 years, 10 months ago) by greg
Changes since 2.14: +0 -3 lines
Diff to previous 2.14 , to selected 1.16
removed LIBDIR from fropen.o compile line
Wed Jun 29 18:18:07 1994 UTC (29 years, 10 months ago) by greg
Diff to previous 2.13 , to selected 1.16
corrected dependency
Thu Apr 14 04:44:42 1994 UTC (30 years ago) by greg
Diff to previous 2.12 , to selected 1.16
Tue Apr 12 15:18:16 1994 UTC (30 years ago) by greg
Diff to previous 2.11 , to selected 1.16
added invmat4.o
Wed Mar 10 19:39:22 1993 UTC (31 years, 2 months ago) by greg
Diff to previous 2.10 , to selected 1.16
added fdate module
Sat Oct 17 08:08:00 1992 UTC (31 years, 6 months ago) by greg
Diff to previous 2.9 , to selected 1.16
added wordstring() function to wordfile.c
created expandargs.c
Tue Sep 8 09:09:19 1992 UTC (31 years, 8 months ago) by greg
Diff to previous 2.8 , to selected 1.16
Mon Jul 13 15:36:26 1992 UTC (31 years, 9 months ago) by greg
Diff to previous 2.7 , to selected 1.16
moved portable i/o routines to portio.c
Tue Jul 7 14:26:06 1992 UTC (31 years, 10 months ago) by greg
Diff to previous 2.6 , to selected 1.16
moved strcmp.o to COMPAT define and fixed clean operation
Fri Jul 3 10:51:48 1992 UTC (31 years, 10 months ago) by greg
Diff to previous 2.5 , to selected 1.16
moved strcmp() to separate module
Wed Jul 1 15:10:37 1992 UTC (31 years, 10 months ago) by greg
Diff to previous 2.4 , to selected 1.16
Wed Jun 24 17:53:00 1992 UTC (31 years, 10 months ago) by greg
Diff to previous 2.3 , to selected 1.16
finally got proptext() working
Thu Mar 19 09:32:03 1992 UTC (32 years, 1 month ago) by greg
Diff to previous 2.2 , to selected 1.16
added vfork.h include file
Wed Mar 4 09:59:37 1992 UTC (32 years, 2 months ago) by greg
Diff to previous 2.1 , to selected 1.16
added wordfile module
Tue Nov 12 16:55:49 1991 UTC (32 years, 5 months ago) by greg
Diff to previous 1.19 , to selected 1.16
Thu Nov 7 11:03:57 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.18 , to selected 1.16
added badarg() routine for argument checking
Wed Oct 23 13:43:17 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.17 , to selected 1.16
Wed Oct 23 10:44:35 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.16
standardized macro settings
Revision 1.16 - (view) (download) (annotate) - [selected]
Wed Oct 9 13:00:21 1991 UTC (32 years, 7 months ago) by greg
Changes since 1.15: +6 -4 lines
Diff to previous 1.15
added COMPAT define
Thu Aug 22 11:55:30 1991 UTC (32 years, 8 months ago) by greg
Diff to previous 1.14 , to selected 1.16
added multisamp
Thu Aug 22 09:21:20 1991 UTC (32 years, 8 months ago) by greg
Changes since 1.13: +5 -4 lines
Diff to previous 1.13 , to selected 1.16
moved library to ../lib
Tue Aug 20 15:33:45 1991 UTC (32 years, 8 months ago) by greg
Diff to previous 1.12 , to selected 1.16
added erf.o to SYSOBJ
Mon Aug 12 13:07:00 1991 UTC (32 years, 9 months ago) by greg
Diff to previous 1.11 , to selected 1.16
moved urind(3) from urand.c to urind.c and added peano.c
Mon Jul 29 15:47:43 1991 UTC (32 years, 9 months ago) by greg
Diff to previous 1.10 , to selected 1.16
added back in otypes.h include to modobject.c
Wed Jul 24 12:06:34 1991 UTC (32 years, 9 months ago) by greg
Diff to previous 1.9 , to selected 1.16
moved routines from otypes.c to modobject.c
Mon Jul 22 14:33:05 1991 UTC (32 years, 9 months ago) by greg
Diff to previous 1.8 , to selected 1.16
created words.c for manipulating words in strings
Mon Jul 22 11:22:59 1991 UTC (32 years, 9 months ago) by greg
Diff to previous 1.7 , to selected 1.16
removed scanf calls from readfargs
Mon Jul 22 09:39:18 1991 UTC (32 years, 9 months ago) by greg
Diff to previous 1.6 , to selected 1.16
added process.o module to library
Fri Jul 19 13:40:49 1991 UTC (32 years, 9 months ago) by greg
Diff to previous 1.5 , to selected 1.16
distributed misc.c into error.c, getpath.c and strmisc.c
Fri Jul 19 09:25:45 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.4: +6 -1 lines
Diff to previous 1.4 , to selected 1.16
added separate readfargs() and freefargs() routines
Tue Jul 16 10:28:51 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.3: +12 -0 lines
Diff to previous 1.3 , to selected 1.16
added calcomp routines to library
Mon Jul 15 12:00:34 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.2: +6 -2 lines
Diff to previous 1.2 , to selected 1.16
added fropen.o to library
Mon Jul 15 11:40:49 1991 UTC (32 years, 9 months ago) by greg
Diff to previous 1.1 , to selected 1.16
added missing dependency
Mon Jul 15 11:25:02 1991 UTC (32 years, 9 months ago) by greg
Diff to selected 1.16
