perf: Turned off alignment for Radiance picture files (not needed)
refactor: moved depth-of-field sampling to separate module
refactor: made font load errors non-fatal
feat: added growBoundingBox() to compute scene boundaries
feat: added routine to triangulate .OBJ scene in memory
Updated clean function
Added missing mention of new library libwfobj.a
Added AR variable to provide a way to override standard library builder
Changed HUGE reference to FHUGE + removed references to unused module maxheap.c
Added strlcpy.c compatibility module for non-BSD systems
Changes to evalglare by Jan Wienold
Added testBSDF build and provided for color (XYZ) output
Added required #include for drand48()
Changed to using _popen and _pclose under MicroSoft VisualStudio
Updated with dependency on triangulate.{c,h}
Added routines to triangulate polygons
Created routines for interpolating anisotropic 2-D samples
Minor bug fixes
Additional check for empty MGF string
Partial implementation of variable-resolution BSDFs
Minor fixes and adjustments
Eliminated tifftypes.h in favor of tiff.h throughout
Fixes for cross-compiling under Mac OS X
The header "uvcode.h" is no longer referenced by tmapluv.c
Minor dependency cleanup
Minor correction to last check-in which caused build to fail using rmake
Abstracted process and path handling for Windows. Renamed FLOAT to RREAL because of conflict on Windows. Added conditional compiles for some signal handlers.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
added new tcos() table-lookup function and tsin() and ttan() macros added DCHECK(test,error_type,error_message) macro for debugging checks
made pcond calling optional in tmapcolrs.c
added stupid unnecessary module for addobjnotify[]
added tmapluv.o module
added include of standard.h to readfargs.c
added missing SPECIAL entries
added rgl* modules for converting Radiance scenes into OpenGL
added tone mapping library functions (see tonemap.h)
added new set routines
changed move command to avoid problems with uncreated src/lib directory
added dependency on color.h to lamps.o for cie_rgb() macro
added comments to font file using new fgetval() routine
moved clip.c and plocate.c to library
added lookup.c
removed LIBDIR from fropen.o compile line
corrected dependency
added invmat4.o
added fdate module
added wordstring() function to wordfile.c created expandargs.c
moved portable i/o routines to portio.c
moved strcmp.o to COMPAT define and fixed clean operation
moved strcmp() to separate module
finally got proptext() working
added vfork.h include file
added wordfile module
added badarg() routine for argument checking
standardized macro settings
added COMPAT define
added multisamp
moved library to ../lib
added erf.o to SYSOBJ
moved urind(3) from urand.c to urind.c and added peano.c
added back in otypes.h include to modobject.c
moved routines from otypes.c to modobject.c
created words.c for manipulating words in strings
removed scanf calls from readfargs
added process.o module to library
distributed misc.c into error.c, getpath.c and strmisc.c
added separate readfargs() and freefargs() routines
added calcomp routines to library
added fropen.o to library
added missing dependency
