root/radiance/ray/src/common/README
Revision: 2.6
Committed: Wed Apr 30 14:17:37 1997 UTC (27 years ago) by greg
Changes since 2.5: +5 -0 lines
added tone mapping library routines
1 LIBRARY ROUTINES AND HEADER FILES
2 SCCSid "$SunId$ LBL"
3
4 This directory contains library routines and common header files for
5 the RADIANCE programs in the directories on the same level.
6
7 calcomp.h header file for expression parser
8 color.h header for routines using pixel color values
9 cone.h header file for cones (cones, cylinders, rings, cups, tubes)
10 face.h header for routines using polygonal faces
11 font.h header for font handling rountines
12 fvect.h header file for floating point routines using vectors
13 linregr.h header file for linear regression calculation
14 mat4.h definitions for 4x4 matrix operations
15 object.h header file for routines using objects and object sets
16 octree.h header file for routines using octrees
17 otypes.h defines for object types
18 paths.h header file defining standard path names for this architecture
19 plocate.h header for 3D vector location
20 random.h header file for random(3) and urand() function
21 resolu.h definitions for resolution line in image file.
22 standard.h standard include file for most programs
23 targa.h header file for reading and writing Targa format files
24 tmerrmsg.h error messages for tone mapping routines
25 tmprivat.h private header file for tone mapping routines
26 tonemap.h header file for tone mapping routines
27 vfork.h header file for routines using vfork()
28 view.h header file for image generation
29 xraster.h header file for X routines using images
30 xtwind.h header for X text window routines
31 badarg.c check argument list against format string
32 bcopy.c substitutes for library routines
33 bmalloc.c memory allocation without overhead (no free lists)
34 caldefn.c store variable definitions
35 calexpr.c compute data values using expression parser
36 calfunc.c routines for calcomp using functions
37 calprnt.c routines for printing calcomp expressions
38 clip.c routine to clip 3D line segments to a box
39 color.c routines for color calculations
40 colrops.c integer operations on COLR scanlines
41 cone.c routines for making cones
42 cputs.c default routine for command-line error output
43 ealloc.c memory routines which call quit on error
44 eputs.c default routine for error output
45 erf.c BSD implementation of erf() and erfc()
46 error.c standard error reporting function
47 expandarg.c expand command-line argument to read from environ or file
48 face.c routines dealing with polygonal faces
49 fdate.c return UNIX date in system-independent interface
50 fgetline.c read line with escaped newlines
51 fgetval.c scanf replacement that skips # comments
52 fgetword.c read white space separated words from stream
53 fixargv0.c MS-DOS compatibility routine to fix program name + arg. list
54 font.c library routines for font handling
55 frexp.c free exponent (library routine replacement)
56 fropen.c find and open a Radiance library file
57 fvect.c routines for float vector calculations
58 fwrite.c standard lib replacement
59 getlibpath.c return standard library path from RAYLIB (or default)
60 getpagesize.c return system page size for non-BSD machine
61 getpath.c function to search for file in a list of directories
62 header.c routines for reading and writing information headers
63 image.c routines for image generation / pixel mapping
64 instance.c routines for octree objects
65 invmat4.c compute inverse of 4x4 matrix
66 lamps.c load lamp data
67 linregr.c basic linear regression calculation
68 lookup.c hash table lookup routines
69 malloc.c fast malloc for memory hogs and VM environments
70 mat4.c routines dealing with 4 X 4 homogeneous matrices
71 mktemp.c make temporary file (system-independent replacement)
72 modobject.c routines for tracking object modifiers
73 multisamp.c binary space partitioning curve for multidimensional sampling
74 myhostname.c system-independent host name call
75 objset.c routines for maintaining object sets
76 octree.c routines dealing with octrees and cubes
77 otypes.c object type lookup and error reporting
78 peano.c generate an N-dimensional Peano space-filling curve
79 plocate.c routine to locate 3D vector w.r.t. box
80 popen.c system-independent replacement for popen(3) call
81 portio.c routines for portable binary input and output
82 process.c routines to communicate with separate process via dual pipes
83 quit.c default quit() routine, calles exit()
84 random.c BSD random number generator
85 readfargs.c allocate, read and free object arguments (RADIANCE parser)
86 readobj.c routines for reading in object descriptions
87 readoct.c routines to read octree information
88 resolu.c read and write image resolutions
89 rexpr.c regular expression parser (ala grep)
90 savestr.c routines for efficient string storage
91 savqstr.c quick and dirty string saver
92 spec_rgb.c convert colors and spectral ranges
93 strcmp.c more efficient standard lib replacement for use with savestr()
94 tmapcolrs.c routines for applying tone mapping to COLR scanlines
95 tonemap.c basic tone mapping routines
96 urand.c anticorrelated random function due to Christophe Schlick
97 urind.c compute pseudo-asyncronous entry point for urand(3)
98 wordfile.c open and read a file of whitespace-separated words
99 words.c routines for recognizing and moving about words in strings
100 wputs.c default warning message output function
101 x11findwind.c find a window by its name under X
102 xf.c routines to convert transform arguments into 4X4 matrix
103 xraster.c X10R4 raster handling routines
104 xtwind.c X10R4 text window routines
