root/Development/ray/src/common/README
Revision: 2.4
Committed: Fri Aug 25 20:03:42 1995 UTC (30 years, 3 months ago) by greg
Changes since 2.3: +12 -2 lines
Updated entries
1 LIBRARY ROUTINES AND HEADER FILES
2 SCCSid "$SunId$ LBL"
3
4 This directory contains library routines and common header files for
5 the RADIANCE programs in the directories on the same level.
6
7 calcomp.h header file for expression parser
8 color.h header for routines using pixel color values
9 cone.h header file for cones (cones, cylinders, rings, cups, tubes)
10 face.h header for routines using polygonal faces
11 font.h header for font handling rountines
12 fvect.h header file for floating point routines using vectors
13 linregr.h header file for linear regression calculation
14 mat4.h definitions for 4x4 matrix operations
15 object.h header file for routines using objects and object sets
16 octree.h header file for routines using octrees
17 otypes.h defines for object types
18 paths.h header file defining standard path names for this architecture
19 plocate.h header for 3D vector location
20 random.h header file for random(3) and urand() function
21 resolu.h definitions for resolution line in image file.
22 standard.h standard include file for most programs
23 targa.h header file for reading and writing Targa format files
24 vfork.h header file for routines using vfork()
25 view.h header file for image generation
26 xraster.h header file for X routines using images
27 xtwind.h header for X text window routines
28 badarg.c check argument list against format string
29 bcopy.c substitutes for library routines
30 bmalloc.c memory allocation without overhead (no free lists)
31 caldefn.c store variable definitions
32 calexpr.c compute data values using expression parser
33 calfunc.c routines for calcomp using functions
34 calprnt.c routines for printing calcomp expressions
35 clip.c routine to clip 3D line segments to a box
36 color.c routines for color calculations
37 colrops.c integer operations on COLR scanlines
38 cone.c routines for making cones
39 cputs.c default routine for command-line error output
40 ealloc.c memory routines which call quit on error
41 eputs.c default routine for error output
42 erf.c BSD implementation of erf() and erfc()
43 error.c standard error reporting function
44 expandarg.c expand command-line argument to read from environ or file
45 face.c routines dealing with polygonal faces
46 fdate.c return UNIX date in system-independent interface
47 fgetline.c read line with escaped newlines
48 fgetval.c scanf replacement that skips # comments
49 fgetword.c read white space separated words from stream
50 fixargv0.c MS-DOS compatibility routine to fix program name + arg. list
51 font.c library routines for font handling
52 frexp.c free exponent (library routine replacement)
53 fropen.c find and open a Radiance library file
54 fvect.c routines for float vector calculations
55 fwrite.c standard lib replacement
56 getlibpath.c return standard library path from RAYLIB (or default)
57 getpagesize.c return system page size for non-BSD machine
58 getpath.c function to search for file in a list of directories
59 header.c routines for reading and writing information headers
60 image.c routines for image generation / pixel mapping
61 instance.c routines for octree objects
62 invmat4.c compute inverse of 4x4 matrix
63 lamps.c load lamp data
64 linregr.c basic linear regression calculation
65 lookup.c hash table lookup routines
66 malloc.c fast malloc for memory hogs and VM environments
67 mat4.c routines dealing with 4 X 4 homogeneous matrices
68 mktemp.c make temporary file (system-independent replacement)
69 modobject.c routines for tracking object modifiers
70 multisamp.c binary space partitioning curve for multidimensional sampling
71 objset.c routines for maintaining object sets
72 octree.c routines dealing with octrees and cubes
73 otypes.c object type lookup and error reporting
74 peano.c generate an N-dimensional Peano space-filling curve
75 plocate.c routine to locate 3D vector w.r.t. box
76 popen.c system-independent replacement for popen(3) call
77 portio.c routines for portable binary input and output
78 process.c routines to communicate with separate process via dual pipes
79 quit.c default quit() routine, calles exit()
80 random.c BSD random number generator
81 readfargs.c allocate, read and free object arguments (RADIANCE parser)
82 readobj.c routines for reading in object descriptions
83 readoct.c routines to read octree information
84 resolu.c read and write image resolutions
85 rexpr.c regular expression parser (ala grep)
86 savestr.c routines for efficient string storage
87 savqstr.c quick and dirty string saver
88 spec_rgb.c convert colors and spectral ranges
89 strcmp.c more efficient standard lib replacement for use with savestr()
90 urand.c anticorrelated random function due to Christophe Schlick
91 urind.c compute pseudo-asyncronous entry point for urand(3)
92 wordfile.c open and read a file of whitespace-separated words
93 words.c routines for recognizing and moving about words in strings
94 wputs.c default warning message output function
95 x11findwind.c find a window by its name under X
96 xf.c routines to convert transform arguments into 4X4 matrix
97 xraster.c X10R4 raster handling routines
98 xtwind.c X10R4 text window routines
