root/radiance/ray/src/common/README
Revision: 2.3
Committed: Tue Nov 10 13:53:01 1992 UTC (32 years, 8 months ago) by greg
added expandarg.c
1 LIBRARY ROUTINES AND HEADER FILES
2 SCCSid "$SunId$ LBL"
3
4 This directory contains library routines and common header files for
5 the RADIANCE programs in the directories on the same level.
6
7 calcomp.h header file for expression parser
8 color.h header for routines using pixel color values
9 cone.h header file for cones (cones, cylinders, rings, cups, tubes)
10 face.h header for routines using polygonal faces
11 font.h header for font handling rountines
12 fvect.h header file for floating point routines using vectors
13 instance.h header file for routines using octree objects
14 linregr.h header file for linear regression calculation
15 mat4.h definitions for 4x4 matrix operations
16 object.h header file for routines using objects and object sets
17 octree.h header file for routines using octrees
18 otypes.h defines for object types
19 paths.h header file defining standard path names for this architecture
20 random.h header file for random(3) and urand() function
21 resolu.h definitions for resolution line in image file.
22 standard.h standard include file for most programs
23 targa.h header file for reading and writing Targa format files
24 vfork.h header file for routines using vfork()
25 view.h header file for image generation
26 xraster.h header file for X routines using images
27 xtwind.h header for X text window routines
28 badarg.c check argument list against format string
29 bcopy.c substitutes for library routines
30 bmalloc.c memory allocation without overhead (no free lists)
31 caldefn.c store variable definitions
32 calexpr.c compute data values using expression parser
33 calfunc.c routines for calcomp using functions
34 calprnt.c routines for printing calcomp expressions
35 color.c routines for color calculations
36 colrops.c integer operations on COLR scanlines
37 cone.c routines for making cones
38 cputs.c default routine for command-line error output
39 ealloc.c memory routines which call quit on error
40 eputs.c default routine for error output
41 erf.c BSD implementation of erf() and erfc()
42 error.c standard error reporting function
43 expandarg.c expand command-line argument to read from environ or file
44 face.c routines dealing with polygonal faces
45 fgetline.c read line with escaped newlines
46 fgetword.c read white space separated words from stream
47 font.c library routines for font handling
48 frexp.c free exponent
49 fropen.c find and open a Radiance library file
50 fvect.c routines for float vector calculations
51 fwrite.c standard lib replacement
52 getpagesize.c return system page size for non-BSD machine
53 getpath.c function to search for file in a list of directories
54 header.c routines for reading and writing information headers
55 image.c routines for image generation / pixel mapping
56 instance.c routines for octree objects
57 lamps.c load lamp data
58 linregr.c basic linear regression calculation
59 malloc.c fast malloc for memory hogs and VM environments
60 mat4.c routines dealing with 4 X 4 homogeneous matrices
61 modobject.c routines for tracking object modifiers
62 multisamp.c binary space partitioning curve for multidimensional sampling
63 objset.c routines for maintaining object sets
64 octree.c routines dealing with octrees and cubes
65 otypes.c object type lookup and error reporting
66 peano.c generate an N-dimensional Peano space-filling curve
67 portio.c routines for portable binary input and output
68 process.c routines to communicate with separate process via dual pipes
69 quit.c default quit() routine, calles exit()
70 random.c BSD random number generator
71 readfargs.c allocate, read and free object arguments (RADIANCE parser)
72 readobj.c routines for reading in object descriptions
73 readoct.c routines to read octree information
74 resolu.c read and write image resolutions
75 rexpr.c regular expression parser (ala grep)
76 savestr.c routines for efficient string storage
77 savqstr.c quick and dirty string saver
78 spec_rgb.c convert colors and spectral ranges
79 strcmp.c more efficient standard lib replacement for use with savestr()
80 urand.c anticorrelated random function due to Christophe Schlick
81 urind.c compute pseudo-asyncronous entry point for urand(3)
82 wordfile.c open and read a file of whitespace-separated words
83 words.c routines for recognizing and moving about words in strings
84 wputs.c default warning message output function
85 x11findwind.c find a window by its name under X
86 xf.c routines to convert transform arguments into 4X4 matrix
87 xraster.c X10R4 raster handling routines
88 xtwind.c X10R4 text window routines
