--- ray/src/common/README 1991/11/11 14:04:09 1.1 +++ ray/src/common/README 1992/09/30 11:29:23 2.2 @@ -8,6 +8,7 @@ calcomp.h header file for expression parser color.h header for routines using pixel color values cone.h header file for cones (cones, cylinders, rings, cups, tubes) face.h header for routines using polygonal faces +font.h header for font handling rountines fvect.h header file for floating point routines using vectors instance.h header file for routines using octree objects linregr.h header file for linear regression calculation @@ -15,11 +16,12 @@ mat4.h definitions for 4x4 matrix operations object.h header file for routines using objects and object sets octree.h header file for routines using octrees otypes.h defines for object types +paths.h header file defining standard path names for this architecture random.h header file for random(3) and urand() function -rasterfile.h description of header for files containing raster images resolu.h definitions for resolution line in image file. standard.h standard include file for most programs targa.h header file for reading and writing Targa format files +vfork.h header file for routines using vfork() view.h header file for image generation xraster.h header file for X routines using images xtwind.h header for X text window routines @@ -33,13 +35,19 @@ calprnt.c routines for printing calcomp expressions color.c routines for color calculations colrops.c integer operations on COLR scanlines cone.c routines for making cones +cputs.c default routine for command-line error output ealloc.c memory routines which call quit on error +eputs.c default routine for error output +erf.c BSD implementation of erf() and erfc() error.c standard error reporting function face.c routines dealing with polygonal faces fgetline.c read line with escaped newlines fgetword.c read white space separated words from stream -frexp.c find and open a Radiance library file +font.c library routines for font handling +frexp.c free exponent +fropen.c find and open a Radiance library file fvect.c routines for float vector calculations +fwrite.c standard lib replacement getpagesize.c return system page size for non-BSD machine getpath.c function to search for file in a list of directories header.c routines for reading and writing information headers @@ -49,14 +57,16 @@ lamps.c load lamp data linregr.c basic linear regression calculation malloc.c fast malloc for memory hogs and VM environments mat4.c routines dealing with 4 X 4 homogeneous matrices -misc.c miscellaneous routines used by most programs modobject.c routines for tracking object modifiers multisamp.c binary space partitioning curve for multidimensional sampling objset.c routines for maintaining object sets octree.c routines dealing with octrees and cubes otypes.c object type lookup and error reporting peano.c generate an N-dimensional Peano space-filling curve +portio.c routines for portable binary input and output process.c routines to communicate with separate process via dual pipes +quit.c default quit() routine, calles exit() +random.c BSD random number generator readfargs.c allocate, read and free object arguments (RADIANCE parser) readobj.c routines for reading in object descriptions readoct.c routines to read octree information @@ -65,8 +75,13 @@ rexpr.c regular expression parser (ala grep) savestr.c routines for efficient string storage savqstr.c quick and dirty string saver spec_rgb.c convert colors and spectral ranges +strcmp.c more efficient standard lib replacement for use with savestr() urand.c anticorrelated random function due to Christophe Schlick urind.c compute pseudo-asyncronous entry point for urand(3) +wordfile.c open and read a file of whitespace-separated words words.c routines for recognizing and moving about words in strings +wputs.c default warning message output function x11findwind.c find a window by its name under X xf.c routines to convert transform arguments into 4X4 matrix +xraster.c X10R4 raster handling routines +xtwind.c X10R4 text window routines
