| 1 |
greg |
1.1 |
LIBRARY ROUTINES AND HEADER FILES
| 2 |
greg |
2.8 |
SCCSid "@(#)README 2.7 6/9/98 LBL"
| 3 |
greg |
1.1 |
| 4 |
This directory contains library routines and common header files for
| 5 |
the RADIANCE programs in the directories on the same level.
| 6 |
| 7 |
calcomp.h header file for expression parser
| 8 |
color.h header for routines using pixel color values
| 9 |
cone.h header file for cones (cones, cylinders, rings, cups, tubes)
| 10 |
face.h header for routines using polygonal faces
| 11 |
greg |
2.2 |
font.h header for font handling rountines
| 12 |
greg |
1.1 |
fvect.h header file for floating point routines using vectors
| 13 |
linregr.h header file for linear regression calculation
| 14 |
mat4.h definitions for 4x4 matrix operations
| 15 |
object.h header file for routines using objects and object sets
| 16 |
octree.h header file for routines using octrees
| 17 |
otypes.h defines for object types
| 18 |
greg |
2.2 |
paths.h header file defining standard path names for this architecture
| 19 |
greg |
2.4 |
plocate.h header for 3D vector location
| 20 |
gwlarson |
2.7 |
radogl.h header for routines using OpenGL to display Radiance scenes
| 21 |
greg |
1.1 |
random.h header file for random(3) and urand() function
| 22 |
resolu.h definitions for resolution line in image file.
| 23 |
standard.h standard include file for most programs
| 24 |
targa.h header file for reading and writing Targa format files
| 25 |
greg |
2.6 |
tmerrmsg.h error messages for tone mapping routines
| 26 |
tmprivat.h private header file for tone mapping routines
| 27 |
tonemap.h header file for tone mapping routines
| 28 |
greg |
2.2 |
vfork.h header file for routines using vfork()
| 29 |
greg |
1.1 |
view.h header file for image generation
| 30 |
xraster.h header file for X routines using images
| 31 |
xtwind.h header for X text window routines
| 32 |
badarg.c check argument list against format string
| 33 |
bmalloc.c memory allocation without overhead (no free lists)
| 34 |
caldefn.c store variable definitions
| 35 |
calexpr.c compute data values using expression parser
| 36 |
calfunc.c routines for calcomp using functions
| 37 |
calprnt.c routines for printing calcomp expressions
| 38 |
greg |
2.4 |
clip.c routine to clip 3D line segments to a box
| 39 |
greg |
1.1 |
color.c routines for color calculations
| 40 |
colrops.c integer operations on COLR scanlines
| 41 |
cone.c routines for making cones
| 42 |
greg |
2.2 |
cputs.c default routine for command-line error output
| 43 |
greg |
1.1 |
ealloc.c memory routines which call quit on error
| 44 |
greg |
2.2 |
eputs.c default routine for error output
| 45 |
erf.c BSD implementation of erf() and erfc()
| 46 |
greg |
1.1 |
error.c standard error reporting function
| 47 |
greg |
2.3 |
expandarg.c expand command-line argument to read from environ or file
| 48 |
greg |
1.1 |
face.c routines dealing with polygonal faces
| 49 |
greg |
2.4 |
fdate.c return UNIX date in system-independent interface
| 50 |
greg |
1.1 |
fgetline.c read line with escaped newlines
| 51 |
greg |
2.4 |
fgetval.c scanf replacement that skips # comments
| 52 |
greg |
1.1 |
fgetword.c read white space separated words from stream
| 53 |
greg |
2.4 |
fixargv0.c MS-DOS compatibility routine to fix program name + arg. list
| 54 |
greg |
2.2 |
font.c library routines for font handling
| 55 |
fropen.c find and open a Radiance library file
| 56 |
greg |
1.1 |
fvect.c routines for float vector calculations
| 57 |
greg |
2.4 |
getlibpath.c return standard library path from RAYLIB (or default)
| 58 |
greg |
1.1 |
getpath.c function to search for file in a list of directories
| 59 |
header.c routines for reading and writing information headers
| 60 |
image.c routines for image generation / pixel mapping
| 61 |
instance.c routines for octree objects
| 62 |
greg |
2.4 |
invmat4.c compute inverse of 4x4 matrix
| 63 |
greg |
1.1 |
lamps.c load lamp data
| 64 |
linregr.c basic linear regression calculation
| 65 |
greg |
2.4 |
lookup.c hash table lookup routines
| 66 |
greg |
1.1 |
mat4.c routines dealing with 4 X 4 homogeneous matrices
| 67 |
modobject.c routines for tracking object modifiers
| 68 |
multisamp.c binary space partitioning curve for multidimensional sampling
| 69 |
greg |
2.5 |
myhostname.c system-independent host name call
| 70 |
greg |
1.1 |
objset.c routines for maintaining object sets
| 71 |
octree.c routines dealing with octrees and cubes
| 72 |
otypes.c object type lookup and error reporting
| 73 |
greg |
2.4 |
plocate.c routine to locate 3D vector w.r.t. box
| 74 |
greg |
2.2 |
portio.c routines for portable binary input and output
| 75 |
greg |
1.1 |
process.c routines to communicate with separate process via dual pipes
| 76 |
greg |
2.2 |
quit.c default quit() routine, calles exit()
| 77 |
greg |
1.1 |
readfargs.c allocate, read and free object arguments (RADIANCE parser)
| 78 |
readobj.c routines for reading in object descriptions
| 79 |
readoct.c routines to read octree information
| 80 |
resolu.c read and write image resolutions
| 81 |
rexpr.c regular expression parser (ala grep)
| 82 |
gwlarson |
2.7 |
rgldomat.c set OpenGL material
| 83 |
rglfile.c process Radiance scene files into OpenGL display lists
| 84 |
rglinst.c convert Radiance octrees and instances into OpenGL
| 85 |
rglmat.c convert Radiance materials into OpenGL
| 86 |
rglsrc.c convert Radiance light sources into OpenGL
| 87 |
rglsurf.c convert Radiance surfaces into OpenGL
| 88 |
greg |
1.1 |
savestr.c routines for efficient string storage
| 89 |
savqstr.c quick and dirty string saver
| 90 |
spec_rgb.c convert colors and spectral ranges
| 91 |
greg |
2.2 |
strcmp.c more efficient standard lib replacement for use with savestr()
| 92 |
greg |
2.6 |
tmapcolrs.c routines for applying tone mapping to COLR scanlines
| 93 |
tonemap.c basic tone mapping routines
| 94 |
greg |
1.1 |
urand.c anticorrelated random function due to Christophe Schlick
| 95 |
urind.c compute pseudo-asyncronous entry point for urand(3)
| 96 |
greg |
2.2 |
wordfile.c open and read a file of whitespace-separated words
| 97 |
greg |
1.1 |
words.c routines for recognizing and moving about words in strings
| 98 |
greg |
2.2 |
wputs.c default warning message output function
| 99 |
greg |
1.1 |
x11findwind.c find a window by its name under X
| 100 |
xf.c routines to convert transform arguments into 4X4 matrix
| 101 |
greg |
2.2 |
xraster.c X10R4 raster handling routines
| 102 |
xtwind.c X10R4 text window routines
