root/radiance/ray/src/cal/total.c
Tue Mar 25 05:36:22 2014 UTC (10 years, 1 month ago) by greg
Changes since 1.9: +5 -3 lines
Diff to previous 1.9
Changed to leave off final tab character to make consistent with other tools
Sun Mar 9 20:07:27 2014 UTC (10 years, 1 month ago) by greg
Changes since 1.8: +5 -1 lines
Diff to previous 1.8
Added flockfile calls and fixed SET_FILE_BINARY usage for consistency
Fri Jun 7 18:49:30 2013 UTC (10 years, 10 months ago) by greg
Diff to previous 1.7
Increased maximum number of input columns to 8192
Fri Jan 29 17:21:43 2010 UTC (14 years, 3 months ago) by greg
CVS Tags: rad4R0, rad4R1
Changes since 1.6: +14 -6 lines
Diff to previous 1.6
Fixed -p for negative inputs
Fri Apr 18 16:32:27 2008 UTC (16 years ago) by greg
Diff to previous 1.5
Changed maximum number of input columns to more generous 2K
Sat Oct 8 04:18:16 2005 UTC (18 years, 6 months ago) by greg
Diff to previous 1.4
Bug fix in combination of -p and -m options in total that broke compamb
Thu Jun 2 04:47:27 2005 UTC (18 years, 11 months ago) by greg
Changes since 1.3: +154 -44 lines
Diff to previous 1.3
Mon Jul 21 22:30:17 2003 UTC (20 years, 9 months ago) by schorsch
Changes since 1.2: +3 -2 lines
Diff to previous 1.2
Sun Jun 8 12:03:09 2003 UTC (20 years, 10 months ago) by schorsch
Changes since 1.1: +11 -6 lines
Diff to previous 1.1
Sat Feb 22 02:07:20 2003 UTC (21 years, 2 months ago) by greg
