root/radiance/ray/src/cal/total.c
Revision: 1.3
Committed: Mon Jul 21 22:30:17 2003 UTC (20 years, 2 months ago) by schorsch
Changes since 1.2: +3 -2 lines
# User Rev Content
1 greg 1.1 #ifndef lint
2 schorsch 1.3 static const char RCSid[] = "$Id: total.c,v 1.2 2003/06/08 12:03:09 schorsch Exp $";
3 greg 1.1 #endif
4     /*
5     * total.c - program to reduce columns of data.
6     *
7     * 5/18/88
8     */
9
10     #include <stdio.h>
11     #include <stdlib.h>
12     #include <ctype.h>
13     #include <math.h>
14
15     #define MAXCOL 256 /* maximum number of columns */
16
17     #define ADD 0 /* add numbers */
18     #define MULT 1 /* multiply numbers */
19     #define MAX 2 /* maximum */
20     #define MIN 3 /* minimum */
21
22     double init_val[] = {0., 1., -1e12, 1e12}; /* initial values */
23
24     int func = ADD; /* default function */
25     double power = 0.0; /* power for sum */
26     int mean = 0; /* compute mean */
27     int count = 0; /* number to sum */
28     int tabc = '\t'; /* default separator */
29     int subtotal = 0; /* produce subtotals? */
30
31 schorsch 1.2 static int execute(char *fname);
32 greg 1.1
33 schorsch 1.2 int
34     main(
35     int argc,
36     char *argv[]
37     )
38 greg 1.1 {
39     int status;
40     int a;
41
42     for (a = 1; a < argc; a++)
43     if (argv[a][0] == '-')
44     if (argv[a][1] >= '0' && argv[a][1] <= '9')
45     count = atoi(argv[a]+1);
46     else
47     switch (argv[a][1]) {
48     case 'm':
49     mean = !mean;
50     break;
51     case 'p':
52     func = MULT;
53     break;
54     case 's':
55     func = ADD;
56     power = atof(argv[a]+2);
57     break;
58     case 'u':
59     func = MAX;
60     break;
61     case 'l':
62     func = MIN;
63     break;
64     case 't':
65     tabc = argv[a][2];
66     break;
67     case 'r':
68     subtotal = !subtotal;
69     break;
70     default:
71     fprintf(stderr,
72     "Usage: %s [-m][-sE|p|u|l][-tC][-count [-r]] [file..]\n",
73     argv[0]);
74     exit(1);
75     }
76     else
77     break;
78     if (mean) {
79     if (func == MAX) {
80     fprintf(stderr, "%s: average maximum?!\n", argv[0]);
81     exit(1);
82     }
83     if (func == MIN) {
84     fprintf(stderr, "%s: average minimum?!\n", argv[0]);
85     exit(1);
86     }
87     }
88     status = 0;
89     if (a >= argc)
90     status = execute(NULL) == -1 ? 1 : status;
91     else
92     for ( ; a < argc; a++)
93     status = execute(argv[a]) == -1 ? 2 : status;
94     exit(status);
95     }
96
97
98 schorsch 1.2 static int
99     execute( /* compute result */
100     char *fname
101     )
102 greg 1.1 {
103     double result[MAXCOL];
104     char buf[16*MAXCOL];
105     register char *cp, *num;
106     register int n;
107     double d;
108     int ncol;
109     long nlin, ltotal;
110     FILE *fp;
111     /* open file */
112     if (fname == NULL)
113     fp = stdin;
114     else if ((fp = fopen(fname, "r")) == NULL) {
115     fprintf(stderr, "%s: cannot open\n", fname);
116     return(-1);
117     }
118     ltotal = 0;
119     while (!feof(fp)) {
120 schorsch 1.3 if (ltotal == 0) { /* initialize */
121 greg 1.1 if (func == MULT) /* special case */
122     for (n = 0; n < MAXCOL; n++)
123     result[n] = 0.0;
124     else
125     for (n = 0; n < MAXCOL; n++)
126     result[n] = init_val[func];
127 schorsch 1.3 }
128 greg 1.1 ncol = 0;
129     for (nlin = 0; (count <= 0 || nlin < count) &&
130     (cp = fgets(buf, sizeof(buf), fp)) != NULL;
131     nlin++) {
132     /* compute */
133     for (n = 0; n < MAXCOL; n++) {
134     while (isspace(*cp))
135     cp++;
136     if (!*cp)
137     break;
138     num = cp;
139     while (*cp && !(isspace(tabc)?isspace(*cp):*cp==tabc))
140     cp++;
141     if (*cp)
142     *cp++ = '\0';
143     if (!*num || isspace(*num))
144     d = init_val[func];
145     else
146     d = atof(num);
147     switch (func) {
148     case ADD:
149     if (d == 0.0)
150     break;
151     if (power != 0.0)
152     result[n] += pow(fabs(d),power);
153     else
154     result[n] += d;
155     break;
156     case MULT:
157     if (d == 0.0)
158     break;
159     result[n] += log(fabs(d));
160     break;
161     case MAX:
162     if (d > result[n])
163     result[n] = d;
164     break;
165     case MIN:
166     if (d < result[n])
167     result[n] = d;
168     break;
169     }
170     }
171     if (n > ncol)
172     ncol = n;
173     }
174     if (nlin == 0)
175     break;
176     /* compute and print */
177     ltotal += nlin;
178     for (n = 0; n < ncol; n++) {
179     d = result[n];
180     if (mean) {
181     d /= (double)ltotal;
182     if (func == ADD && power != 0.0 && d != 0.0)
183     d = pow(d, 1.0/power);
184     }
185     if (func == MULT)
186     d = exp(d);
187     printf("%.9g%c", d, tabc);
188     }
189     putchar('\n');
190     if (!subtotal)
191     ltotal = 0;
192     }
193     /* close file */
194     return(fclose(fp));
195     }
