--- ray/src/cal/total.c 2003/06/08 12:03:09 1.2 +++ ray/src/cal/total.c 2016/03/24 18:48:28 1.11 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: total.c,v 1.2 2003/06/08 12:03:09 schorsch Exp $"; +static const char RCSid[] = "$Id: total.c,v 1.11 2016/03/24 18:48:28 greg Exp $"; #endif /* * total.c - program to reduce columns of data. @@ -11,8 +11,9 @@ static const char RCSid[] = "$Id: total.c,v 1.2 2003/0 #include #include #include +#include "platform.h" -#define MAXCOL 256 /* maximum number of columns */ +#define MAXCOL 8192 /* maximum number of columns */ #define ADD 0 /* add numbers */ #define MULT 1 /* multiply numbers */ @@ -21,12 +22,18 @@ static const char RCSid[] = "$Id: total.c,v 1.2 2003/0 double init_val[] = {0., 1., -1e12, 1e12}; /* initial values */ +long incnt = 0; /* limit number of input records? */ +long outcnt = 0; /* limit number of output records? */ + int func = ADD; /* default function */ double power = 0.0; /* power for sum */ int mean = 0; /* compute mean */ int count = 0; /* number to sum */ +int nbicols = 0; /* number of binary input columns */ +int bocols = 0; /* produce binary output columns */ int tabc = '\t'; /* default separator */ int subtotal = 0; /* produce subtotals? */ +int nrecsout = 0; /* number of records produced */ static int execute(char *fname); @@ -67,9 +74,64 @@ char *argv[] case 'r': subtotal = !subtotal; break; - default: + case 'i': + switch (argv[a][2]) { + case 'n': + incnt = atol(argv[++a]); + break; + case 'a': + nbicols = 0; + break; + case 'd': + if (isdigit(argv[a][3])) + nbicols = atoi(argv[a]+3); + else + nbicols = 1; + if (nbicols > MAXCOL) { + fprintf(stderr, + "%s: too many input columns\n", + argv[0]); + exit(1); + } + break; + case 'f': + if (isdigit(argv[a][3])) + nbicols = -atoi(argv[a]+3); + else + nbicols = -1; + if (-nbicols > MAXCOL) { + fprintf(stderr, + "%s: too many input columns\n", + argv[0]); + exit(1); + } + break; + default: + goto userr; + } + break; + case 'o': + switch (argv[a][2]) { + case 'n': + outcnt = atol(argv[++a]); + break; + case 'a': + bocols = 0; + break; + case 'd': + bocols = 1; + break; + case 'f': + bocols = -1; + break; + default: + goto userr; + } + break; + default:; + userr: fprintf(stderr, - "Usage: %s [-m][-sE|p|u|l][-tC][-count [-r]] [file..]\n", +"Usage: %s [-m][-sE|p|u|l][-tC][-i{f|d}[N]][-o{f|d}][-count [-r]] [file..]\n", argv[0]); exit(1); } @@ -85,27 +147,101 @@ char *argv[] exit(1); } } + if (bocols) + SET_FILE_BINARY(stdout); status = 0; if (a >= argc) status = execute(NULL) == -1 ? 1 : status; else - for ( ; a < argc; a++) + for ( ; a < argc && (outcnt <= 0 || nrecsout < outcnt); a++) status = execute(argv[a]) == -1 ? 2 : status; exit(status); } static int +getrecord( /* read next input record */ + double field[MAXCOL], + FILE *fp +) +{ + char buf[16*MAXCOL]; + char *cp, *num; + int nf; + /* reading binary input? */ + if (nbicols > 0) + return(fread(field, sizeof(double), nbicols, fp)); + if (nbicols < 0) { + float *fbuf = (float *)buf; + int i; + nf = fread(fbuf, sizeof(float), -nbicols, fp); + for (i = nf; i-- > 0; ) + field[i] = fbuf[i]; + return(nf); + } + /* reading ASCII input */ + cp = fgets(buf, sizeof(buf), fp); + if (cp == NULL) + return(0); + for (nf = 0; nf < MAXCOL; nf++) { + while (isspace(*cp)) + cp++; + if (!*cp) + break; + num = cp; + while (*cp && !(isspace(tabc)?isspace(*cp):*cp==tabc)) + cp++; + if (*cp) + *cp++ = '\0'; + if (!*num || isspace(*num)) + field[nf] = init_val[func]; + else + field[nf] = atof(num); + } + return(nf); +} + + +static void +putrecord( /* write out results record */ + const double *field, + int n, + FILE *fp +) +{ + /* binary output? */ + if (bocols > 0) { + fwrite(field, sizeof(double), n, fp); + return; + } + if (bocols < 0) { + float fv; + while (n-- > 0) { + fv = *field++; + fwrite(&fv, sizeof(float), 1, fp); + } + return; + } + /* ASCII output */ + while (n-- > 0) { + fprintf(fp, "%.9g", *field++); + if (n) fputc(tabc, fp); + } + fputc('\n', fp); +} + + +static int execute( /* compute result */ char *fname ) { + double inpval[MAXCOL]; + double tally[MAXCOL]; + short rsign[MAXCOL]; double result[MAXCOL]; - char buf[16*MAXCOL]; - register char *cp, *num; - register int n; - double d; - int ncol; + int n; + int nread, ncol; long nlin, ltotal; FILE *fp; /* open file */ @@ -115,80 +251,83 @@ char *fname fprintf(stderr, "%s: cannot open\n", fname); return(-1); } + if (nbicols) + SET_FILE_BINARY(fp); +#ifdef getc_unlocked /* avoid lock/unlock overhead */ + flockfile(fp); +#endif + ltotal = 0; while (!feof(fp)) { - if (ltotal == 0) /* initialize */ + if (ltotal == 0) { /* initialize */ if (func == MULT) /* special case */ - for (n = 0; n < MAXCOL; n++) - result[n] = 0.0; + for (n = 0; n < MAXCOL; n++) { + tally[n] = 0.0; + rsign[n] = 1; + } else for (n = 0; n < MAXCOL; n++) - result[n] = init_val[func]; + tally[n] = init_val[func]; + } ncol = 0; for (nlin = 0; (count <= 0 || nlin < count) && - (cp = fgets(buf, sizeof(buf), fp)) != NULL; + (incnt <= 0 || nlin < incnt) && + (nread = getrecord(inpval, fp)) > 0; nlin++) { /* compute */ - for (n = 0; n < MAXCOL; n++) { - while (isspace(*cp)) - cp++; - if (!*cp) - break; - num = cp; - while (*cp && !(isspace(tabc)?isspace(*cp):*cp==tabc)) - cp++; - if (*cp) - *cp++ = '\0'; - if (!*num || isspace(*num)) - d = init_val[func]; - else - d = atof(num); + for (n = 0; n < nread; n++) switch (func) { case ADD: - if (d == 0.0) + if (inpval[n] == 0.0) break; if (power != 0.0) - result[n] += pow(fabs(d),power); + tally[n] += pow(fabs(inpval[n]),power); else - result[n] += d; + tally[n] += inpval[n]; break; case MULT: - if (d == 0.0) - break; - result[n] += log(fabs(d)); + if (inpval[n] == 0.0) + rsign[n] = 0; + else if (inpval[n] < 0.0) { + rsign[n] = -rsign[n]; + inpval[n] = -inpval[n]; + } + if (rsign[n]) + tally[n] += log(inpval[n]); break; case MAX: - if (d > result[n]) - result[n] = d; + if (inpval[n] > tally[n]) + tally[n] = inpval[n]; break; case MIN: - if (d < result[n]) - result[n] = d; + if (inpval[n] < tally[n]) + tally[n] = inpval[n]; break; } - } - if (n > ncol) - ncol = n; + if (nread > ncol) + ncol = nread; } if (nlin == 0) break; /* compute and print */ ltotal += nlin; for (n = 0; n < ncol; n++) { - d = result[n]; + result[n] = tally[n]; if (mean) { - d /= (double)ltotal; - if (func == ADD && power != 0.0 && d != 0.0) - d = pow(d, 1.0/power); + result[n] /= (double)ltotal; + if (func == ADD && power != 0.0 && result[n] != 0.0) + result[n] = pow(result[n], 1.0/power); } if (func == MULT) - d = exp(d); - printf("%.9g%c", d, tabc); + result[n] = rsign[n] * exp(result[n]); } - putchar('\n'); + putrecord(result, ncol, stdout); + ++nrecsout; + if (outcnt > 0 && nrecsout >= outcnt) + break; if (!subtotal) ltotal = 0; } - /* close file */ + /* close input */ return(fclose(fp)); }
