root/radiance/ray/src/cal/total.c
Fri Jan 29 17:21:43 2010 UTC (14 years, 3 months ago) by greg
CVS Tags: rad4R0, rad4R1
Changes since 1.6: +14 -6 lines
Diff to previous 1.6 , to selected 1.5
Fixed -p for negative inputs
Fri Apr 18 16:32:27 2008 UTC (16 years ago) by greg
Diff to previous 1.5
Changed maximum number of input columns to more generous 2K
Sat Oct 8 04:18:16 2005 UTC (18 years, 7 months ago) by greg
Diff to previous 1.4
Bug fix in combination of -p and -m options in total that broke compamb
Thu Jun 2 04:47:27 2005 UTC (18 years, 11 months ago) by greg
Changes since 1.3: +154 -44 lines
Mon Jul 21 22:30:17 2003 UTC (20 years, 9 months ago) by schorsch
Changes since 1.2: +3 -2 lines
Sun Jun 8 12:03:09 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 1.1: +11 -6 lines
Sat Feb 22 02:07:20 2003 UTC (21 years, 2 months ago) by greg
Diff to selected 1.5
