root/radiance/ray/src/cal/total.c
Revision 1.16 - (view) (download) (annotate) - [selected]
Thu Mar 24 22:26:50 2022 UTC (2 years, 1 month ago) by greg
CVS Tags: HEAD, rad5R4
Changes since 1.15: +12 -5 lines
Diff to previous 1.15
fix(total): Improved option error checking
Tue Nov 16 03:30:45 2021 UTC (2 years, 6 months ago) by greg
Changes since 1.14: +4 -2 lines
Diff to previous 1.14 , to selected 1.16
feat(total): added automatic output flushing unless -r option is present
Sat Dec 28 18:05:13 2019 UTC (4 years, 4 months ago) by greg
Changes since 1.13: +1 -2 lines
Diff to previous 1.13 , to selected 1.16
Thu Aug 18 00:52:47 2016 UTC (7 years, 8 months ago) by greg
CVS Tags: rad5R1, rad5R2
Changes since 1.12: +6 -5 lines
Diff to previous 1.12 , to selected 1.16
Thu Mar 24 19:00:54 2016 UTC (8 years, 1 month ago) by greg
Changes since 1.11: +3 -1 lines
Diff to previous 1.11 , to selected 1.16
I guess I can't count...
Thu Mar 24 18:48:28 2016 UTC (8 years, 1 month ago) by greg
Changes since 1.10: +16 -2 lines
Diff to previous 1.10 , to selected 1.16
Added -in options to commands for manual EOF specification
Tue Mar 25 05:36:22 2014 UTC (10 years, 1 month ago) by greg
Changes since 1.9: +5 -3 lines
Diff to previous 1.9 , to selected 1.16
Changed to leave off final tab character to make consistent with other tools
Sun Mar 9 20:07:27 2014 UTC (10 years, 2 months ago) by greg
Changes since 1.8: +5 -1 lines
Diff to previous 1.8 , to selected 1.16
Added flockfile calls and fixed SET_FILE_BINARY usage for consistency
Fri Jun 7 18:49:30 2013 UTC (10 years, 11 months ago) by greg
Diff to previous 1.7 , to selected 1.16
Increased maximum number of input columns to 8192
Fri Jan 29 17:21:43 2010 UTC (14 years, 3 months ago) by greg
CVS Tags: rad4R0, rad4R1
Changes since 1.6: +14 -6 lines
Diff to previous 1.6 , to selected 1.16
Fixed -p for negative inputs
Fri Apr 18 16:32:27 2008 UTC (16 years, 1 month ago) by greg
Diff to previous 1.5 , to selected 1.16
Changed maximum number of input columns to more generous 2K
Sat Oct 8 04:18:16 2005 UTC (18 years, 7 months ago) by greg
Diff to previous 1.4 , to selected 1.16
Bug fix in combination of -p and -m options in total that broke compamb
Thu Jun 2 04:47:27 2005 UTC (18 years, 11 months ago) by greg
Changes since 1.3: +154 -44 lines
Diff to previous 1.3 , to selected 1.16
Mon Jul 21 22:30:17 2003 UTC (20 years, 10 months ago) by schorsch
Changes since 1.2: +3 -2 lines
Diff to previous 1.2 , to selected 1.16
Sun Jun 8 12:03:09 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 1.1: +11 -6 lines
Diff to previous 1.1 , to selected 1.16
Sat Feb 22 02:07:20 2003 UTC (21 years, 2 months ago) by greg
Diff to selected 1.16
