root/radiance/ray/src/cal/tabfunc.c
Revision: 1.3
Committed: Thu Jun 26 00:58:09 2003 UTC (21 years, 1 month ago) by schorsch
Changes since 1.2: +6 -7 lines
2 static const char RCSid[] = "$Id: tabfunc.c,v 1.2 2003/06/08 12:03:09 schorsch Exp $";
5 * Put tabular data into functions suitable for cal programs.
6 *
7 * 2/2/95 Greg Ward
8 */
9
10 #include <stdio.h>
11 #include <stdlib.h>
12 #include <string.h>
13 #include <math.h>
14 #include <ctype.h>
15 #ifdef _WIN32
16 #include <process.h> /* getpid() */
17 #else
18 #include <sys/types.h>
19 #include <unistd.h>
20 #endif
21
22 #include "standard.h"
23 #include "platform.h"
24
25 #define isdelim(c) (isspace(c) || (c)==',')
26
27 #define MAXTAB 1024 /* maximum number of data rows */
28 #define MAXLINE 4096 /* maximum line width (characters) */
29 #define OUTFMT "%.7g" /* output format conversion string */
30
31 int interpolate = 0;
32 char *progname;
33 char **func;
34 int nfuncs;
35
36 RREAL abscissa[MAXTAB]; /* independent values (first column) */
37 RREAL (*ordinate)[MAXTAB]; /* dependent values (other columns) */
38 int tabsize = 0; /* final table size (number of rows) */
39 char locID[16]; /* local identifier (for uniqueness) */
40
41 /*extern char *fgets(), *fskip(), *absc_exp();*/
42
43 static void load_data(FILE *fp);
44 static void print_funcs(char *xe);
45 static void putlist(register RREAL *av, int al, register int pos);
46 static char * absc_exp(void);
47
48 int
49 main(
50 int argc,
51 char **argv
52 )
53 {
54 progname = argv[0];
55 argv++;
56 argc--;
57 if (argc && !strcmp(argv[0], "-i")) {
58 interpolate++;
59 puts("interp_arr2`(i,x,f):(i+1-x)*f(i)+(x-i)*f(i+1);");
60 puts("interp_arr`(x,f):if(x-1,if(f(0)-x,interp_arr2`(floor(x),x,f),f(f(0))),f(1));");
61 argv++;
62 argc--;
63 }
64 if (!argc || argv[0][0] == '-') {
65 fprintf(stderr, "Usage: %s [-i] func1 [func2 ..]\n", progname);
66 exit(1);
67 }
68 func = argv;
69 nfuncs = argc;
70 ordinate = (RREAL (*)[MAXTAB])malloc(nfuncs*MAXTAB*sizeof(RREAL));
71 if (ordinate == NULL) {
72 fprintf(stderr, "%s: not enough memory\n", progname);
73 exit(1);
74 }
75 sprintf(locID, "p%d", getpid());
76 load_data(stdin);
77 print_funcs(absc_exp());
78 exit(0);
79 }
80
81
82 static void
83 load_data( /* load tabular data from fp */
84 FILE *fp
85 )
86 {
87 int lineno;
88 char *err;
89 char inpbuf[MAXLINE];
90 register char *cp;
91 register int i;
92
93 tabsize = lineno = 0;
94 inpbuf[MAXLINE-2] = '\n';
95 while (fgets(inpbuf, MAXLINE, fp) != NULL) {
96 lineno++;
97 if (inpbuf[MAXLINE-2] != '\n') {
98 err = "line too long";
99 goto fatal;
100 }
101 if (tabsize >= MAXTAB-1) {
102 err = "too many rows";
103 goto fatal;
104 }
105 if ((cp = fskip(inpbuf)) == NULL)
106 continue; /* skip non-data lines */
107 abscissa[tabsize] = atof(inpbuf);
108 for (i = 0; i < nfuncs; i++) {
109 while (isdelim(*cp))
110 cp++;
111 if (!*cp) {
112 err = "too few columns";
113 goto fatal;
114 }
115 ordinate[i][tabsize] = atof(cp);
116 if ((cp = fskip(cp)) == NULL) {
117 err = "bad floating-point format";
118 goto fatal;
119 }
120 }
121 tabsize++;
122 }
123 return;
124 fatal:
125 fprintf(stderr, "%s: input line %d: %s\n", progname, lineno, err);
126 exit(1);
127 }
128
129
130 static char *
131 absc_exp(void) /* produce expression for abscissa */
132 {
133 static char ourexp[64];
134 double step, eps;
135 int uniform, increasing;
136 register int i;
137
138 if (tabsize < 2)
139 return("1");
140 step = abscissa[1] - abscissa[0];
141 eps = ((increasing = (step > 0)) ? 1e-3 : -1e-3) * step;
142 uniform = 1;
143 for (i = 2; i < tabsize; i++) {
144 if (uniform && fabs((abscissa[i]-abscissa[i-1]) - step) > eps)
145 uniform = 0;
146 if (!uniform && (abscissa[i-1] < abscissa[i]) != increasing) {
147 fprintf(stderr, "%s: input not a function\n",
148 progname);
149 exit(1);
150 }
151 }
152 if (uniform) {
153 if (increasing && fabs(step - 1) < eps) {
154 if (fabs(abscissa[0] - 1) < eps)
155 strcpy(ourexp, "x");
156 else
157 sprintf(ourexp, "x-%g", abscissa[0]-1);
158 } else
159 sprintf(ourexp, "(x-%g)/%g+1", abscissa[0], step);
160 } else {
161 printf("X`%s(i):select(i,", locID);
162 putlist(abscissa, tabsize, 20);
163 puts(");");
164 if (increasing) {
165 printf("fx`%s(x):if(x-%g,if(%g-x,fx2`%s(x,%d),%d),1);\n",
166 locID, abscissa[0], abscissa[tabsize-1],
167 locID, tabsize, tabsize);
168 printf("fx2`%s(x,i):if(x-X`%s(i),\n", locID, locID);
169 } else {
170 printf("fx`%s(x):if(%g-x,if(x-%g,fx2`%s(x,%d),%d),1);\n",
171 locID, abscissa[0], abscissa[tabsize-1],
172 locID, tabsize, tabsize);
173 printf("fx2`%s(x,i):if(X`%s(i)-x,\n", locID, locID);
174 }
175 printf("\ti+(x-X`%s(i))/(X`%s(i+1)-X`%s(i)),\n",
176 locID, locID, locID);
177 printf("\tfx2`%s(x,i-1));\n", locID);
178 sprintf(ourexp, "fx`%s(x)", locID);
179 }
180 return(ourexp);
181 }
182
183
184 static void
185 print_funcs( /* print functions */
186 char *xe
187 )
188 {
189 int xelen;
190 register int i;
191
192 xelen = strlen(xe);
193 for (i = 0; i < nfuncs; i++) {
194 if (func[i][0] == '\0' | func[i][0] == '0')
195 continue;
196 if (interpolate) {
197 printf("%s`%s(i):select(i,", func[i], locID);
198 putlist(ordinate[i], tabsize,
199 27+strlen(func[i]));
200 puts(");");
201 printf("%s(x):interp_arr`(%s,%s`%s);\n",
202 func[i], xe, func[i], locID);
203 } else {
204 printf("%s(x):select(%s,", func[i], xe);
205 putlist(ordinate[i], tabsize, strlen(func[i])+xelen+12);
206 puts(");");
207 }
208 }
209 }
210
211
212 static void
213 putlist( /* put out array of values */
214 register RREAL *av,
215 int al,
216 register int pos
217 )
218 {
219 char obuf[32];
220 int len;
221
222 while (al--) {
223 sprintf(obuf, OUTFMT, *av++);
224 pos += (len = strlen(obuf)+1);
225 if (pos >= 64) {
226 putchar('\n');
227 pos = len;
228 }
229 fputs(obuf, stdout);
230 if (al)
231 putchar(',');
232 }
233 }
