| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: tabfunc.c,v 1.2 2003/06/08 12:03:09 schorsch Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Put tabular data into functions suitable for cal programs.
| 6 |
| 7 |
* 2/2/95 Greg Ward
| 8 |
| 9 |
| 10 |
#include <stdio.h>
| 11 |
#include <stdlib.h>
| 12 |
#include <string.h>
| 13 |
#include <math.h>
| 14 |
#include <ctype.h>
| 15 |
#ifdef _WIN32
| 16 |
#include <process.h> /* getpid() */
| 17 |
#else
| 18 |
#include <sys/types.h>
| 19 |
#include <unistd.h>
| 20 |
#endif
| 21 |
| 22 |
#include "standard.h"
| 23 |
#include "platform.h"
| 24 |
| 25 |
#define isdelim(c) (isspace(c) || (c)==',')
| 26 |
| 27 |
#define MAXTAB 1024 /* maximum number of data rows */
| 28 |
#define MAXLINE 4096 /* maximum line width (characters) */
| 29 |
#define OUTFMT "%.7g" /* output format conversion string */
| 30 |
| 31 |
int interpolate = 0;
| 32 |
char *progname;
| 33 |
char **func;
| 34 |
int nfuncs;
| 35 |
| 36 |
RREAL abscissa[MAXTAB]; /* independent values (first column) */
| 37 |
RREAL (*ordinate)[MAXTAB]; /* dependent values (other columns) */
| 38 |
int tabsize = 0; /* final table size (number of rows) */
| 39 |
char locID[16]; /* local identifier (for uniqueness) */
| 40 |
| 41 |
/*extern char *fgets(), *fskip(), *absc_exp();*/
| 42 |
| 43 |
static void load_data(FILE *fp);
| 44 |
static void print_funcs(char *xe);
| 45 |
static void putlist(register RREAL *av, int al, register int pos);
| 46 |
static char * absc_exp(void);
| 47 |
| 48 |
int
| 49 |
main(
| 50 |
int argc,
| 51 |
char **argv
| 52 |
| 53 |
| 54 |
progname = argv[0];
| 55 |
argv++;
| 56 |
argc--;
| 57 |
if (argc && !strcmp(argv[0], "-i")) {
| 58 |
interpolate++;
| 59 |
puts("interp_arr2`(i,x,f):(i+1-x)*f(i)+(x-i)*f(i+1);");
| 60 |
puts("interp_arr`(x,f):if(x-1,if(f(0)-x,interp_arr2`(floor(x),x,f),f(f(0))),f(1));");
| 61 |
argv++;
| 62 |
argc--;
| 63 |
| 64 |
if (!argc || argv[0][0] == '-') {
| 65 |
fprintf(stderr, "Usage: %s [-i] func1 [func2 ..]\n", progname);
| 66 |
exit(1);
| 67 |
| 68 |
func = argv;
| 69 |
nfuncs = argc;
| 70 |
ordinate = (RREAL (*)[MAXTAB])malloc(nfuncs*MAXTAB*sizeof(RREAL));
| 71 |
if (ordinate == NULL) {
| 72 |
fprintf(stderr, "%s: not enough memory\n", progname);
| 73 |
exit(1);
| 74 |
| 75 |
sprintf(locID, "p%d", getpid());
| 76 |
load_data(stdin);
| 77 |
print_funcs(absc_exp());
| 78 |
exit(0);
| 79 |
| 80 |
| 81 |
| 82 |
static void
| 83 |
load_data( /* load tabular data from fp */
| 84 |
FILE *fp
| 85 |
| 86 |
| 87 |
int lineno;
| 88 |
char *err;
| 89 |
char inpbuf[MAXLINE];
| 90 |
register char *cp;
| 91 |
register int i;
| 92 |
| 93 |
tabsize = lineno = 0;
| 94 |
inpbuf[MAXLINE-2] = '\n';
| 95 |
while (fgets(inpbuf, MAXLINE, fp) != NULL) {
| 96 |
lineno++;
| 97 |
if (inpbuf[MAXLINE-2] != '\n') {
| 98 |
err = "line too long";
| 99 |
goto fatal;
| 100 |
| 101 |
if (tabsize >= MAXTAB-1) {
| 102 |
err = "too many rows";
| 103 |
goto fatal;
| 104 |
| 105 |
if ((cp = fskip(inpbuf)) == NULL)
| 106 |
continue; /* skip non-data lines */
| 107 |
abscissa[tabsize] = atof(inpbuf);
| 108 |
for (i = 0; i < nfuncs; i++) {
| 109 |
while (isdelim(*cp))
| 110 |
cp++;
| 111 |
if (!*cp) {
| 112 |
err = "too few columns";
| 113 |
goto fatal;
| 114 |
| 115 |
ordinate[i][tabsize] = atof(cp);
| 116 |
if ((cp = fskip(cp)) == NULL) {
| 117 |
err = "bad floating-point format";
| 118 |
goto fatal;
| 119 |
| 120 |
| 121 |
tabsize++;
| 122 |
| 123 |
return;
| 124 |
fatal:
| 125 |
fprintf(stderr, "%s: input line %d: %s\n", progname, lineno, err);
| 126 |
exit(1);
| 127 |
| 128 |
| 129 |
| 130 |
static char *
| 131 |
absc_exp(void) /* produce expression for abscissa */
| 132 |
| 133 |
static char ourexp[64];
| 134 |
double step, eps;
| 135 |
int uniform, increasing;
| 136 |
register int i;
| 137 |
| 138 |
if (tabsize < 2)
| 139 |
return("1");
| 140 |
step = abscissa[1] - abscissa[0];
| 141 |
eps = ((increasing = (step > 0)) ? 1e-3 : -1e-3) * step;
| 142 |
uniform = 1;
| 143 |
for (i = 2; i < tabsize; i++) {
| 144 |
if (uniform && fabs((abscissa[i]-abscissa[i-1]) - step) > eps)
| 145 |
uniform = 0;
| 146 |
if (!uniform && (abscissa[i-1] < abscissa[i]) != increasing) {
| 147 |
fprintf(stderr, "%s: input not a function\n",
| 148 |
progname);
| 149 |
exit(1);
| 150 |
| 151 |
| 152 |
if (uniform) {
| 153 |
if (increasing && fabs(step - 1) < eps) {
| 154 |
if (fabs(abscissa[0] - 1) < eps)
| 155 |
strcpy(ourexp, "x");
| 156 |
else
| 157 |
sprintf(ourexp, "x-%g", abscissa[0]-1);
| 158 |
} else
| 159 |
sprintf(ourexp, "(x-%g)/%g+1", abscissa[0], step);
| 160 |
} else {
| 161 |
printf("X`%s(i):select(i,", locID);
| 162 |
putlist(abscissa, tabsize, 20);
| 163 |
puts(");");
| 164 |
if (increasing) {
| 165 |
printf("fx`%s(x):if(x-%g,if(%g-x,fx2`%s(x,%d),%d),1);\n",
| 166 |
locID, abscissa[0], abscissa[tabsize-1],
| 167 |
locID, tabsize, tabsize);
| 168 |
printf("fx2`%s(x,i):if(x-X`%s(i),\n", locID, locID);
| 169 |
} else {
| 170 |
printf("fx`%s(x):if(%g-x,if(x-%g,fx2`%s(x,%d),%d),1);\n",
| 171 |
| 172 |
| 173 |
printf("fx2`%s(x,i):if(X`%s(i)-x,\n", locID, locID);
| 174 |
| 175 |
printf("\ti+(x-X`%s(i))/(X`%s(i+1)-X`%s(i)),\n",
| 176 |
locID, locID, locID);
| 177 |
printf("\tfx2`%s(x,i-1));\n", locID);
| 178 |
sprintf(ourexp, "fx`%s(x)", locID);
| 179 |
| 180 |
return(ourexp);
| 181 |
| 182 |
| 183 |
| 184 |
static void
| 185 |
print_funcs( /* print functions */
| 186 |
char *xe
| 187 |
| 188 |
| 189 |
int xelen;
| 190 |
register int i;
| 191 |
| 192 |
xelen = strlen(xe);
| 193 |
| 194 |
if (func[i][0] == '\0' | func[i][0] == '0')
| 195 |
continue;
| 196 |
if (interpolate) {
| 197 |
printf("%s`%s(i):select(i,", func[i], locID);
| 198 |
putlist(ordinate[i], tabsize,
| 199 |
27+strlen(func[i]));
| 200 |
puts(");");
| 201 |
printf("%s(x):interp_arr`(%s,%s`%s);\n",
| 202 |
func[i], xe, func[i], locID);
| 203 |
} else {
| 204 |
printf("%s(x):select(%s,", func[i], xe);
| 205 |
putlist(ordinate[i], tabsize, strlen(func[i])+xelen+12);
| 206 |
puts(");");
| 207 |
| 208 |
| 209 |
| 210 |
| 211 |
| 212 |
static void
| 213 |
putlist( /* put out array of values */
| 214 |
register RREAL *av,
| 215 |
int al,
| 216 |
register int pos
| 217 |
| 218 |
| 219 |
char obuf[32];
| 220 |
int len;
| 221 |
| 222 |
while (al--) {
| 223 |
sprintf(obuf, OUTFMT, *av++);
| 224 |
pos += (len = strlen(obuf)+1);
| 225 |
if (pos >= 64) {
| 226 |
putchar('\n');
| 227 |
pos = len;
| 228 |
| 229 |
fputs(obuf, stdout);
| 230 |
if (al)
| 231 |
putchar(',');
| 232 |
| 233 |
