--- ray/src/cal/tabfunc.c 2003/02/22 02:07:20 1.1 +++ ray/src/cal/tabfunc.c 2003/06/08 12:03:09 1.2 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: tabfunc.c,v 1.1 2003/02/22 02:07:20 greg Exp $"; +static const char RCSid[] = "$Id: tabfunc.c,v 1.2 2003/06/08 12:03:09 schorsch Exp $"; #endif /* * Put tabular data into functions suitable for cal programs. @@ -9,14 +9,24 @@ static const char RCSid[] = "$Id: tabfunc.c,v 1.1 2003 #include #include +#include #include #include +#ifdef _WIN32 + #include /* getpid() */ +#else + #include + #include +#endif +#include "standard.h" +#include "platform.h" + #define isdelim(c) (isspace(c) || (c)==',') #define MAXTAB 1024 /* maximum number of data rows */ #define MAXLINE 4096 /* maximum line width (characters) */ -#define FLOAT float /* real type (precision) */ +/*#define FLOAT float */ /* real type (precision) */ #define OUTFMT "%.7g" /* output format conversion string */ int interpolate = 0; @@ -29,12 +39,18 @@ FLOAT (*ordinate)[MAXTAB]; /* dependent values (other int tabsize = 0; /* final table size (number of rows) */ char locID[16]; /* local identifier (for uniqueness) */ -extern char *fgets(), *fskip(), *absc_exp(); +/*extern char *fgets(), *fskip(), *absc_exp();*/ +static void load_data(FILE *fp); +static void print_funcs(char *xe); +static void putlist(register FLOAT *av, int al, register int pos); +static char * absc_exp(void); -main(argc, argv) -int argc; -char **argv; +int +main( +int argc, +char **argv +) { progname = argv[0]; argv++; @@ -64,8 +80,10 @@ char **argv; } -load_data(fp) /* load tabular data from fp */ -FILE *fp; +static void +load_data( /* load tabular data from fp */ +FILE *fp +) { int lineno; char *err; @@ -110,8 +128,8 @@ fatal: } -char * -absc_exp() /* produce expression for abscissa */ +static char * +absc_exp(void) /* produce expression for abscissa */ { static char ourexp[64]; double step, eps; @@ -164,8 +182,10 @@ absc_exp() /* produce expression for abscissa */ } -print_funcs(xe) /* print functions */ -char *xe; +static void +print_funcs( /* print functions */ +char *xe +) { int xelen; register int i; @@ -190,10 +210,12 @@ char *xe; } -putlist(av, al, pos) /* put out array of values */ -register FLOAT *av; -int al; -register int pos; +static void +putlist( /* put out array of values */ +register FLOAT *av, +int al, +register int pos +) { char obuf[32]; int len;
