root/radiance/ray/src/cal/tabfunc.c
Sat Nov 12 06:14:51 2005 UTC (19 years, 7 months ago) by greg
CVS Tags: rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2
Changes since 1.5: +4 -2 lines
Diff to previous 1.5
Improved default ordinal color scale in falsecolor
Sun Jul 27 22:12:01 2003 UTC (21 years, 11 months ago) by schorsch
Diff to previous 1.4
Mon Jul 14 20:02:29 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 1.3: +5 -9 lines
Thu Jun 26 00:58:09 2003 UTC (22 years ago) by schorsch
Changes since 1.2: +6 -7 lines
Sun Jun 8 12:03:09 2003 UTC (22 years, 1 month ago) by schorsch
Changes since 1.1: +39 -17 lines
Sat Feb 22 02:07:20 2003 UTC (22 years, 4 months ago) by greg
Diff to selected 1.5
