root/radiance/ray/src/cal/tabfunc.c
Wed Feb 28 03:17:23 2024 UTC (2 months, 1 week ago) by greg
Diff to previous 1.10 , to selected 1.9
fix(tabfunc): Better float format error detection
Thu Mar 18 03:09:34 2021 UTC (3 years, 1 month ago) by greg
Changes since 1.9: +9 -8 lines
Diff to previous 1.9
fix: repaired out-of-order function output for irregular abscissa
Revision 1.9 - (view) (download) (annotate) - [selected]
Mon Jun 29 21:25:36 2020 UTC (3 years, 10 months ago) by greg
Diff to previous 1.8
perf(tabfunc): changed function ordering for better constant reduction
Sat Dec 28 18:05:13 2019 UTC (4 years, 4 months ago) by greg
Changes since 1.7: +1 -4 lines
Diff to previous 1.7 , to selected 1.9
Sun Aug 11 17:04:09 2019 UTC (4 years, 9 months ago) by greg
Diff to previous 1.6 , to selected 1.9
Increased limits
Sat Nov 12 06:14:51 2005 UTC (18 years, 6 months ago) by greg
CVS Tags: rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2
Changes since 1.5: +4 -2 lines
Diff to previous 1.5 , to selected 1.9
Improved default ordinal color scale in falsecolor
Diff to previous 1.4 , to selected 1.9
Mon Jul 14 20:02:29 2003 UTC (20 years, 10 months ago) by schorsch
Changes since 1.3: +5 -9 lines
Diff to previous 1.3 , to selected 1.9
Changes since 1.2: +6 -7 lines
Diff to previous 1.2 , to selected 1.9
Sun Jun 8 12:03:09 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 1.1: +39 -17 lines
Diff to previous 1.1 , to selected 1.9
Sat Feb 22 02:07:20 2003 UTC (21 years, 2 months ago) by greg
Diff to selected 1.9
