1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: rsplit.c,v 1.3 2019/07/05 02:26:16 greg Exp $"; |
3 |
#endif |
4 |
5 |
* rsplit.c - split input into multiple output streams |
6 |
7 |
* 7/4/19 Greg Ward |
8 |
9 |
10 |
#include <stdlib.h> |
11 |
#include <string.h> |
12 |
#include <stdio.h> |
13 |
#include <ctype.h> |
14 |
15 |
#include "platform.h" |
16 |
#include "resolu.h" |
17 |
#include "rtio.h" |
18 |
19 |
#define DOHEADER 1 |
20 |
#define DORESOLU 2 |
21 |
22 |
#define MAXFILE 512 /* maximum number of files */ |
23 |
24 |
FILE *output[MAXFILE]; |
25 |
int bytsiz[MAXFILE]; |
26 |
short hdrflags[MAXFILE]; |
27 |
const char *format[MAXFILE]; |
28 |
int termc[MAXFILE]; |
29 |
int nfiles = 0; |
30 |
31 |
int outheader = 0; /* output header to each stream? */ |
32 |
33 |
RESOLU ourres = {PIXSTANDARD, 0, 0}; |
34 |
35 |
char buf[16384]; |
36 |
37 |
38 |
/* process header line */ |
39 |
static int |
40 |
headline(char *s, void *p) |
41 |
42 |
extern const char FMTSTR[]; |
43 |
int i = nfiles; |
44 |
45 |
if (strstr(s, FMTSTR) == s) |
46 |
return(0); /* don't copy format */ |
47 |
if (!strncmp(s, "NROWS=", 6)) |
48 |
return(0); |
49 |
if (!strncmp(s, "NCOLS=", 6)) |
50 |
return(0); |
51 |
if (!strncmp(s, "NCOMP=", 6)) |
52 |
return(0); |
53 |
while (i--) /* else copy line to output streams */ |
54 |
if (hdrflags[i] & DOHEADER) |
55 |
fputs(s, output[i]); |
56 |
return(1); |
57 |
58 |
59 |
60 |
/* scan field into buffer up to and including terminating byte */ |
61 |
static int |
62 |
scanOK(int termc) |
63 |
64 |
char *cp = buf; |
65 |
int c; |
66 |
67 |
while ((c = getchar()) != EOF) { |
68 |
*cp++ = c; |
69 |
if (cp-buf >= sizeof(buf)) |
70 |
break; |
71 |
if (c == termc) { |
72 |
*cp = '\0'; |
73 |
return(cp-buf); |
74 |
75 |
76 |
return(0); |
77 |
78 |
79 |
80 |
int |
81 |
main(int argc, char *argv[]) |
82 |
83 |
int inpheader = 0; |
84 |
int inpres = 0; |
85 |
int outres = 0; |
86 |
int force = 0; |
87 |
int append = 0; |
88 |
long outcnt = 0; |
89 |
int bininp = 0; |
90 |
int curterm = '\n'; |
91 |
int curbytes = 0; |
92 |
int curflags = 0; |
93 |
const char *curfmt = "ascii"; |
94 |
int i; |
95 |
96 |
for (i = 1; i < argc; i++) { |
97 |
if (argv[i][0] == '-') { |
98 |
switch (argv[i][1]) { |
99 |
case 't': |
100 |
curterm = argv[i][2]; |
101 |
break; |
102 |
case 'i': |
103 |
switch (argv[i][2]) { |
104 |
case 'h': |
105 |
inpheader = !inpheader; |
106 |
break; |
107 |
case 'H': |
108 |
inpres = !inpres; |
109 |
break; |
110 |
default: |
111 |
goto badopt; |
112 |
113 |
break; |
114 |
case 'f': |
115 |
++force; |
116 |
append = 0; |
117 |
break; |
118 |
case 'a': |
119 |
if (outheader | outres) { |
120 |
fputs(argv[0], stderr); |
121 |
fputs(": -a option incompatible with -oh and -oH\n", |
122 |
stderr); |
123 |
return(1); |
124 |
125 |
append = 1; |
126 |
break; |
127 |
case 'x': |
128 |
ourres.xr = atoi(argv[++i]); |
129 |
outres = 1; |
130 |
break; |
131 |
case 'y': |
132 |
ourres.yr = atoi(argv[++i]); |
133 |
outres = 1; |
134 |
break; |
135 |
case 'o': |
136 |
137 |
case 'n': |
138 |
outcnt = atol(argv[++i]); |
139 |
continue; |
140 |
case 'h': |
141 |
curflags ^= DOHEADER; |
142 |
continue; |
143 |
case 'H': |
144 |
curflags ^= DORESOLU; |
145 |
continue; |
146 |
case 'f': |
147 |
curfmt = "float"; |
148 |
curbytes = sizeof(float); |
149 |
break; |
150 |
case 'd': |
151 |
curfmt = "double"; |
152 |
curbytes = sizeof(double); |
153 |
break; |
154 |
case 'i': |
155 |
curfmt = "int"; |
156 |
curbytes = sizeof(int); |
157 |
break; |
158 |
case 'w': |
159 |
curfmt = "16-bit"; |
160 |
curbytes = 2; |
161 |
break; |
162 |
case 'b': |
163 |
curfmt = "byte"; |
164 |
curbytes = 1; |
165 |
break; |
166 |
case 'a': |
167 |
curfmt = "ascii"; |
168 |
curbytes = argv[i][3] ? -1 : 0; |
169 |
break; |
170 |
default: |
171 |
goto badopt; |
172 |
173 |
if (isdigit(argv[i][3])) |
174 |
curbytes *= atoi(argv[i]+3); |
175 |
curbytes += (curbytes == -1); |
176 |
if (curbytes > (int)sizeof(buf)) { |
177 |
178 |
fputs(": output size too big\n", stderr); |
179 |
return(1); |
180 |
181 |
if (curbytes > 0) { |
182 |
curterm = '\0'; |
183 |
++bininp; |
184 |
185 |
break; |
186 |
case '\0': |
187 |
outres |= (curflags & DORESOLU); |
188 |
termc[nfiles] = curterm; |
189 |
hdrflags[nfiles] = curflags; |
190 |
output[nfiles] = stdout; |
191 |
if (curbytes > 0) |
192 |
SET_FILE_BINARY(output[nfiles]); |
193 |
format[nfiles] = curfmt; |
194 |
bytsiz[nfiles++] = curbytes; |
195 |
break; |
196 |
badopt:; |
197 |
default: |
198 |
199 |
fputs(": bad option\n", stderr); |
200 |
return(1); |
201 |
202 |
} else if (argv[i][0] == '!') { |
203 |
204 |
205 |
206 |
if ((output[nfiles] = popen(argv[i]+1, "w")) == NULL) { |
207 |
fputs(argv[i], stderr); |
208 |
fputs(": cannot start command\n", stderr); |
209 |
return(1); |
210 |
211 |
if (curbytes > 0) |
212 |
213 |
214 |
215 |
} else { |
216 |
217 |
218 |
219 |
if (!append & !force && access(argv[i], F_OK) == 0) { |
220 |
221 |
fputs(": file exists -- use -f to overwrite\n", |
222 |
stderr); |
223 |
return(1); |
224 |
225 |
output[nfiles] = fopen(argv[i], append ? "a" : "w"); |
226 |
if (output[nfiles] == NULL) { |
227 |
228 |
fputs(": cannot open for output\n", stderr); |
229 |
return(1); |
230 |
231 |
if (curbytes > 0) |
232 |
233 |
234 |
235 |
236 |
if (nfiles >= MAXFILE) { |
237 |
238 |
fputs(": too many output streams\n", stderr); |
239 |
return(1); |
240 |
241 |
242 |
if (!nfiles) { |
243 |
244 |
fputs(": no output streams\n", stderr); |
245 |
return(1); |
246 |
247 |
if (bininp) /* binary input? */ |
248 |
SET_FILE_BINARY(stdin); |
249 |
#ifdef getc_unlocked /* avoid lock/unlock overhead */ |
250 |
flockfile(stdin); |
251 |
for (i = nfiles; i--; ) |
252 |
flockfile(output[i]); |
253 |
#endif |
254 |
/* load/copy header */ |
255 |
if (inpheader && getheader(stdin, headline, NULL) < 0) { |
256 |
257 |
fputs(": cannot get header from standard input\n", |
258 |
stderr); |
259 |
return(1); |
260 |
261 |
/* handle resolution string */ |
262 |
if (inpres && !fgetsresolu(&ourres, stdin)) { |
263 |
264 |
fputs(": cannot get resolution string from standard input\n", |
265 |
stderr); |
266 |
return(1); |
267 |
268 |
if (outres && (ourres.xr <= 0) | (ourres.yr <= 0)) { |
269 |
270 |
fputs(": -oH option requires -iH or -x and -y options\n", stderr); |
271 |
return(1); |
272 |
273 |
if ((ourres.xr > 0) & (ourres.yr > 0)) { |
274 |
if (outcnt <= 0) { |
275 |
outcnt = ourres.xr * ourres.yr; |
276 |
} else if (outcnt != ourres.xr*ourres.yr) { |
277 |
278 |
fputs(": warning: -on option does not agree with resolution\n", |
279 |
stderr); |
280 |
281 |
282 |
for (i = 0; i < nfiles; i++) { /* complete headers */ |
283 |
if (hdrflags[i] & DOHEADER) { |
284 |
if (!inpheader) |
285 |
newheader("RADIANCE", output[i]); |
286 |
printargs(argc, argv, output[i]); |
287 |
if (format[i] != NULL) |
288 |
fputformat(format[i], output[i]); |
289 |
fputc('\n', output[i]); |
290 |
291 |
if (hdrflags[i] & DORESOLU) |
292 |
fputsresolu(&ourres, output[i]); |
293 |
294 |
do { /* main loop */ |
295 |
for (i = 0; i < nfiles; i++) { |
296 |
if (bytsiz[i] > 0) { /* binary output */ |
297 |
if (getbinary(buf, bytsiz[i], 1, stdin) < 1) |
298 |
break; |
299 |
if (putbinary(buf, bytsiz[i], 1, output[i]) != 1) |
300 |
break; |
301 |
} else if (bytsiz[i] < 0) { /* N-field output */ |
302 |
int n = -bytsiz[i]; |
303 |
while (n--) { |
304 |
if (!scanOK(termc[i])) |
305 |
break; |
306 |
if (fputs(buf, output[i]) == EOF) |
307 |
break; |
308 |
309 |
if (n >= 0) /* fell short? */ |
310 |
break; |
311 |
if (termc[i] != '\n') /* add EOL if none */ |
312 |
313 |
} else { /* 1-field output */ |
314 |
315 |
break; |
316 |
317 |
break; |
318 |
319 |
320 |
321 |
322 |
if (i < nfiles) |
323 |
break; |
324 |
} while (--outcnt); |
325 |
/* check ending */ |
326 |
if (fflush(NULL) == EOF) { |
327 |
328 |
fputs(": write error on one or more outputs\n", stderr); |
329 |
return(1); |
330 |
331 |
if (outcnt > 0) { |
332 |
333 |
fputs(": warning: premature EOD\n", stderr); |
334 |
335 |
return(0); |
336 |
