1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: rsplit.c,v 1.13 2020/04/04 16:23:00 greg Exp $"; |
3 |
#endif |
4 |
5 |
* rsplit.c - split input into multiple output streams |
6 |
7 |
* 7/4/19 Greg Ward |
8 |
9 |
10 |
#include <ctype.h> |
11 |
12 |
#include "rtio.h" |
13 |
#include "platform.h" |
14 |
#include "paths.h" |
15 |
#include "resolu.h" |
16 |
17 |
#define DOHEADER 1 |
18 |
#define DORESOLU 2 |
19 |
20 |
#define MAXFILE 512 /* maximum number of files */ |
21 |
22 |
static int swapped = 0; /* input is byte-swapped */ |
23 |
24 |
static FILE *output[MAXFILE]; |
25 |
static int ncomp[MAXFILE]; |
26 |
static int bytsiz[MAXFILE]; |
27 |
static int hdrflags[MAXFILE]; |
28 |
static const char *format[MAXFILE]; |
29 |
static int termc[MAXFILE]; |
30 |
static int nfiles = 0; |
31 |
32 |
static RESOLU ourres = {PIXSTANDARD, 0, 0}; |
33 |
34 |
static char buf[16384]; /* input buffer used in scanOK() */ |
35 |
36 |
37 |
/* process header line */ |
38 |
static int |
39 |
headline(char *s, void *p) |
40 |
41 |
extern const char FMTSTR[]; |
42 |
int i; |
43 |
44 |
if (strstr(s, FMTSTR) == s) |
45 |
return(0); /* don't copy format */ |
46 |
if (!strncmp(s, "NROWS=", 6)) |
47 |
return(0); |
48 |
if (!strncmp(s, "NCOLS=", 6)) |
49 |
return(0); |
50 |
if (!strncmp(s, "NCOMP=", 6)) |
51 |
return(0); |
52 |
if ((i = isbigendian(s)) >= 0) { |
53 |
swapped = (nativebigendian() != i); |
54 |
return(0); |
55 |
56 |
i = nfiles; |
57 |
while (i--) /* else copy line to output streams */ |
58 |
if (hdrflags[i] & DOHEADER) |
59 |
fputs(s, output[i]); |
60 |
return(1); |
61 |
62 |
63 |
64 |
/* scan field into buffer up to and including terminating byte */ |
65 |
static int |
66 |
scanOK(int termc) |
67 |
68 |
int skip_white = (termc == ' '); |
69 |
char *cp = buf; |
70 |
int c; |
71 |
72 |
while ((c = getchar()) != EOF) { |
73 |
if (skip_white && isspace(c)) |
74 |
continue; |
75 |
skip_white = 0; |
76 |
if (c == '\n' && isspace(termc)) |
77 |
c = termc; /* forgiving assumption */ |
78 |
*cp++ = c; |
79 |
if (cp-buf >= sizeof(buf)) |
80 |
break; |
81 |
if ((termc == ' ') ? isspace(c) : (c == termc)) { |
82 |
*cp = '\0'; |
83 |
return(cp-buf); |
84 |
85 |
86 |
return(0); |
87 |
88 |
89 |
90 |
int |
91 |
main(int argc, char *argv[]) |
92 |
93 |
int inpflags = 0; |
94 |
int needres = 0; |
95 |
int force = 0; |
96 |
int append = 0; |
97 |
long outcnt = 0; |
98 |
int bininp = 0; |
99 |
int nstdoutcomp = 0; |
100 |
int curterm = '\n'; |
101 |
int curncomp = 1; |
102 |
int curbytes = 0; |
103 |
int curflags = 0; |
104 |
const char *curfmt = "ascii"; |
105 |
int i; |
106 |
107 |
for (i = 1; i < argc; i++) { |
108 |
if (argv[i][0] == '-') { |
109 |
switch (argv[i][1]) { |
110 |
case 't': |
111 |
curterm = argv[i][2]; |
112 |
if (!curterm) curterm = '\n'; |
113 |
break; |
114 |
case 'i': |
115 |
switch (argv[i][2]) { |
116 |
case 'h': |
117 |
inpflags ^= DOHEADER; |
118 |
break; |
119 |
case 'H': |
120 |
inpflags ^= DORESOLU; |
121 |
break; |
122 |
default: |
123 |
goto badopt; |
124 |
125 |
break; |
126 |
case 'f': |
127 |
force = !force; |
128 |
break; |
129 |
case 'a': |
130 |
append = !append; |
131 |
break; |
132 |
case 'x': |
133 |
ourres.xr = atoi(argv[++i]); |
134 |
break; |
135 |
case 'y': |
136 |
ourres.yr = atoi(argv[++i]); |
137 |
break; |
138 |
case 'o': |
139 |
140 |
case 'n': |
141 |
outcnt = atol(argv[++i]); |
142 |
continue; |
143 |
case 'h': |
144 |
curflags ^= DOHEADER; |
145 |
continue; |
146 |
case 'H': |
147 |
curflags ^= DORESOLU; |
148 |
continue; |
149 |
case 'f': |
150 |
curfmt = "float"; |
151 |
curbytes = sizeof(float); |
152 |
break; |
153 |
case 'd': |
154 |
curfmt = "double"; |
155 |
curbytes = sizeof(double); |
156 |
break; |
157 |
case 'i': |
158 |
curfmt = "int"; |
159 |
curbytes = sizeof(int); |
160 |
break; |
161 |
case 'w': |
162 |
curfmt = "16-bit"; |
163 |
curbytes = 2; |
164 |
break; |
165 |
case 'b': |
166 |
curfmt = "byte"; |
167 |
curbytes = 1; |
168 |
break; |
169 |
case 'a': |
170 |
curfmt = "ascii"; |
171 |
curbytes = 0; |
172 |
break; |
173 |
default: |
174 |
goto badopt; |
175 |
176 |
curncomp = isdigit(argv[i][3]) ? |
177 |
atoi(argv[i]+3) : 1 ; |
178 |
if (curbytes*curncomp > (int)sizeof(buf)) { |
179 |
fputs(argv[0], stderr); |
180 |
fputs(": output size too big\n", stderr); |
181 |
return(1); |
182 |
183 |
bininp += (curbytes > 0); |
184 |
break; |
185 |
case '\0': /* stdout */ |
186 |
if (!nstdoutcomp) { /* first use? */ |
187 |
needres |= (curflags & DORESOLU); |
188 |
hdrflags[nfiles] = curflags; |
189 |
190 |
output[nfiles] = stdout; |
191 |
if (curbytes > 0) |
192 |
SET_FILE_BINARY(output[nfiles]); |
193 |
termc[nfiles] = curterm; |
194 |
format[nfiles] = curfmt; |
195 |
nstdoutcomp += |
196 |
ncomp[nfiles] = curncomp; |
197 |
bytsiz[nfiles++] = curbytes; |
198 |
break; |
199 |
badopt:; |
200 |
default: |
201 |
202 |
fputs(": bad option\n", stderr); |
203 |
return(1); |
204 |
205 |
} else if (argv[i][0] == '.' && !argv[i][1]) { |
206 |
output[nfiles] = NULL; /* discard data */ |
207 |
208 |
209 |
210 |
211 |
} else if (argv[i][0] == '!') { |
212 |
213 |
214 |
215 |
if ((output[nfiles] = popen(argv[i]+1, "w")) == NULL) { |
216 |
fputs(argv[i], stderr); |
217 |
fputs(": cannot start command\n", stderr); |
218 |
return(1); |
219 |
220 |
if (curbytes > 0) |
221 |
222 |
223 |
224 |
225 |
} else { |
226 |
if (append & (curflags != 0)) { |
227 |
228 |
fputs(": -a option incompatible with -oh and -oH\n", |
229 |
stderr); |
230 |
return(1); |
231 |
232 |
233 |
234 |
235 |
if (!append & !force && access(argv[i], F_OK) == 0) { |
236 |
237 |
fputs(": file exists -- use -f to overwrite\n", |
238 |
stderr); |
239 |
return(1); |
240 |
241 |
output[nfiles] = fopen(argv[i], append ? "a" : "w"); |
242 |
if (output[nfiles] == NULL) { |
243 |
244 |
fputs(": cannot open for output\n", stderr); |
245 |
return(1); |
246 |
247 |
if (curbytes > 0) |
248 |
249 |
250 |
251 |
252 |
253 |
if (nfiles >= MAXFILE) { |
254 |
255 |
fputs(": too many output streams\n", stderr); |
256 |
return(1); |
257 |
258 |
259 |
if (!nfiles) { |
260 |
261 |
fputs(": no output streams\n", stderr); |
262 |
return(1); |
263 |
264 |
if (bininp) /* binary input? */ |
265 |
SET_FILE_BINARY(stdin); |
266 |
#ifdef getc_unlocked /* avoid lock/unlock overhead */ |
267 |
flockfile(stdin); |
268 |
for (i = nfiles; i--; ) |
269 |
if (output[i] != NULL) |
270 |
ftrylockfile(output[i]); |
271 |
#endif |
272 |
/* load/copy header */ |
273 |
if (inpflags & DOHEADER && getheader(stdin, headline, NULL) < 0) { |
274 |
275 |
fputs(": cannot read header from standard input\n", |
276 |
stderr); |
277 |
return(1); |
278 |
279 |
/* handle resolution string */ |
280 |
if (inpflags & DORESOLU && !fgetsresolu(&ourres, stdin)) { |
281 |
282 |
fputs(": bad resolution string on standard input\n", stderr); |
283 |
return(1); |
284 |
285 |
if (needres && (ourres.xr <= 0) | (ourres.yr <= 0)) { |
286 |
287 |
fputs(": -oH option requires -iH or -x and -y options\n", stderr); |
288 |
return(1); |
289 |
290 |
if ((ourres.xr > 0) & (ourres.yr > 0)) { |
291 |
if (outcnt <= 0) { |
292 |
outcnt = ourres.xr * ourres.yr; |
293 |
} else if (outcnt != ourres.xr*ourres.yr) { |
294 |
295 |
fputs(": warning: -on option does not agree with resolution\n", |
296 |
stderr); |
297 |
298 |
299 |
for (i = 0; i < nfiles; i++) { /* complete headers */ |
300 |
if (hdrflags[i] & DOHEADER) { |
301 |
if (!(inpflags & DOHEADER)) |
302 |
newheader("RADIANCE", output[i]); |
303 |
printargs(argc, argv, output[i]); |
304 |
fprintf(output[i], "NCOMP=%d\n", output[i]==stdout ? |
305 |
nstdoutcomp : ncomp[i]); |
306 |
if (format[i] != NULL) { |
307 |
extern const char BIGEND[]; |
308 |
if (format[i][0] != 'a') { |
309 |
fputs(BIGEND, output[i]); |
310 |
fputs(nativebigendian() ^ swapped ? |
311 |
"1\n" : "0\n", output[i]); |
312 |
313 |
fputformat(format[i], output[i]); |
314 |
315 |
fputc('\n', output[i]); |
316 |
317 |
if (hdrflags[i] & DORESOLU) |
318 |
fputsresolu(&ourres, output[i]); |
319 |
320 |
do { /* main loop */ |
321 |
for (i = 0; i < nfiles; i++) { |
322 |
if (bytsiz[i] > 0) { /* binary output */ |
323 |
if (getbinary(buf, bytsiz[i], ncomp[i], |
324 |
stdin) < ncomp[i]) |
325 |
break; |
326 |
if (output[i] != NULL && |
327 |
putbinary(buf, bytsiz[i], ncomp[i], |
328 |
output[i]) < ncomp[i]) |
329 |
break; |
330 |
} else if (ncomp[i] > 1) { /* N-field output */ |
331 |
int n = ncomp[i]; |
332 |
while (n--) { |
333 |
if (!scanOK(termc[i])) |
334 |
break; |
335 |
336 |
fputs(buf, output[i]) == EOF) |
337 |
break; |
338 |
339 |
if (n >= 0) /* fell short? */ |
340 |
break; |
341 |
if ((output[i] != NULL) & /* add EOL if none */ |
342 |
(termc[i] != '\n')) |
343 |
344 |
} else { /* 1-field output */ |
345 |
346 |
break; |
347 |
if (output[i] != NULL) { |
348 |
if (fputs(buf, output[i]) == EOF) |
349 |
break; |
350 |
if (termc[i] != '\n') /* add EOL? */ |
351 |
352 |
353 |
354 |
/* skip input EOL? */ |
355 |
if (!bininp && termc[nfiles-1] != '\n') { |
356 |
int c = getchar(); |
357 |
if ((c != '\n') & (c != EOF)) |
358 |
ungetc(c, stdin); |
359 |
360 |
361 |
if (i < nfiles) |
362 |
break; |
363 |
} while (--outcnt); |
364 |
/* check ending */ |
365 |
if (fflush(NULL) == EOF) { |
366 |
367 |
fputs(": write error on one or more outputs\n", stderr); |
368 |
return(1); |
369 |
370 |
if (outcnt > 0) { |
371 |
372 |
fputs(": warning: premature EOD\n", stderr); |
373 |
374 |
return(0); |
375 |
