--- ray/src/cal/rsplit.c 2019/07/19 17:37:55 1.6 +++ ray/src/cal/rsplit.c 2020/04/04 16:23:00 1.13 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rsplit.c,v 1.6 2019/07/19 17:37:55 greg Exp $"; +static const char RCSid[] = "$Id: rsplit.c,v 1.13 2020/04/04 16:23:00 greg Exp $"; #endif /* * rsplit.c - split input into multiple output streams @@ -7,11 +7,11 @@ static const char RCSid[] = "$Id: rsplit.c,v 1.6 2019/ * 7/4/19 Greg Ward */ -#include #include #include "rtio.h" #include "platform.h" +#include "paths.h" #include "resolu.h" #define DOHEADER 1 @@ -19,18 +19,19 @@ static const char RCSid[] = "$Id: rsplit.c,v 1.6 2019/ #define MAXFILE 512 /* maximum number of files */ -FILE *output[MAXFILE]; -int bytsiz[MAXFILE]; -short hdrflags[MAXFILE]; -const char *format[MAXFILE]; -int termc[MAXFILE]; -int nfiles = 0; +static int swapped = 0; /* input is byte-swapped */ -int outheader = 0; /* output header to each stream? */ +static FILE *output[MAXFILE]; +static int ncomp[MAXFILE]; +static int bytsiz[MAXFILE]; +static int hdrflags[MAXFILE]; +static const char *format[MAXFILE]; +static int termc[MAXFILE]; +static int nfiles = 0; -RESOLU ourres = {PIXSTANDARD, 0, 0}; +static RESOLU ourres = {PIXSTANDARD, 0, 0}; -char buf[16384]; +static char buf[16384]; /* input buffer used in scanOK() */ /* process header line */ @@ -38,7 +39,7 @@ static int headline(char *s, void *p) { extern const char FMTSTR[]; - int i = nfiles; + int i; if (strstr(s, FMTSTR) == s) return(0); /* don't copy format */ @@ -48,6 +49,11 @@ headline(char *s, void *p) return(0); if (!strncmp(s, "NCOMP=", 6)) return(0); + if ((i = isbigendian(s)) >= 0) { + swapped = (nativebigendian() != i); + return(0); + } + i = nfiles; while (i--) /* else copy line to output streams */ if (hdrflags[i] & DOHEADER) fputs(s, output[i]); @@ -59,14 +65,20 @@ headline(char *s, void *p) static int scanOK(int termc) { + int skip_white = (termc == ' '); char *cp = buf; int c; while ((c = getchar()) != EOF) { + if (skip_white && isspace(c)) + continue; + skip_white = 0; + if (c == '\n' && isspace(termc)) + c = termc; /* forgiving assumption */ *cp++ = c; if (cp-buf >= sizeof(buf)) break; - if (c == termc) { + if ((termc == ' ') ? isspace(c) : (c == termc)) { *cp = '\0'; return(cp-buf); } @@ -78,14 +90,14 @@ scanOK(int termc) int main(int argc, char *argv[]) { - int inpheader = 0; - int inpres = 0; - int outres = 0; + int inpflags = 0; + int needres = 0; int force = 0; int append = 0; long outcnt = 0; int bininp = 0; int curterm = '\n'; + int curncomp = 1; int curbytes = 0; int curflags = 0; const char *curfmt = "ascii"; @@ -101,35 +113,26 @@ main(int argc, char *argv[]) case 'i': switch (argv[i][2]) { case 'h': - inpheader = !inpheader; + inpflags ^= DOHEADER; break; case 'H': - inpres = !inpres; + inpflags ^= DORESOLU; break; default: goto badopt; } break; case 'f': - ++force; - append = 0; + force = !force; break; case 'a': - if (outheader | outres) { - fputs(argv[0], stderr); - fputs(": -a option incompatible with -oh and -oH\n", - stderr); - return(1); - } - append = 1; + append = !append; break; case 'x': ourres.xr = atoi(argv[++i]); - outres = 1; break; case 'y': ourres.yr = atoi(argv[++i]); - outres = 1; break; case 'o': switch (argv[i][2]) { @@ -164,32 +167,29 @@ main(int argc, char *argv[]) break; case 'a': curfmt = "ascii"; - curbytes = argv[i][3] ? -1 : 0; + curbytes = 0; break; default: goto badopt; } - if (isdigit(argv[i][3])) - curbytes *= atoi(argv[i]+3); - curbytes += (curbytes == -1); - if (curbytes > (int)sizeof(buf)) { + curncomp = isdigit(argv[i][3]) ? + atoi(argv[i]+3) : 1 ; + if (curbytes*curncomp > (int)sizeof(buf)) { fputs(argv[0], stderr); fputs(": output size too big\n", stderr); return(1); } - if (curbytes > 0) { - curterm = '\0'; - ++bininp; - } + bininp += (curbytes > 0); break; case '\0': - outres |= (curflags & DORESOLU); + needres |= (curflags & DORESOLU); termc[nfiles] = curterm; hdrflags[nfiles] = curflags; output[nfiles] = stdout; if (curbytes > 0) SET_FILE_BINARY(output[nfiles]); format[nfiles] = curfmt; + ncomp[nfiles] = curncomp; bytsiz[nfiles++] = curbytes; break; badopt:; @@ -198,8 +198,14 @@ main(int argc, char *argv[]) fputs(": bad option\n", stderr); return(1); } + } else if (argv[i][0] == '.' && !argv[i][1]) { + output[nfiles] = NULL; /* discard data */ + termc[nfiles] = curterm; + format[nfiles] = curfmt; + ncomp[nfiles] = curncomp; + bytsiz[nfiles++] = curbytes; } else if (argv[i][0] == '!') { - outres |= (curflags & DORESOLU); + needres |= (curflags & DORESOLU); termc[nfiles] = curterm; hdrflags[nfiles] = curflags; if ((output[nfiles] = popen(argv[i]+1, "w")) == NULL) { @@ -210,9 +216,16 @@ main(int argc, char *argv[]) if (curbytes > 0) SET_FILE_BINARY(output[nfiles]); format[nfiles] = curfmt; + ncomp[nfiles] = curncomp; bytsiz[nfiles++] = curbytes; } else { - outres |= (curflags & DORESOLU); + if (append & (curflags != 0)) { + fputs(argv[0], stderr); + fputs(": -a option incompatible with -oh and -oH\n", + stderr); + return(1); + } + needres |= (curflags & DORESOLU); termc[nfiles] = curterm; hdrflags[nfiles] = curflags; if (!append & !force && access(argv[i], F_OK) == 0) { @@ -230,6 +243,7 @@ main(int argc, char *argv[]) if (curbytes > 0) SET_FILE_BINARY(output[nfiles]); format[nfiles] = curfmt; + ncomp[nfiles] = curncomp; bytsiz[nfiles++] = curbytes; } if (nfiles >= MAXFILE) { @@ -248,23 +262,24 @@ main(int argc, char *argv[]) #ifdef getc_unlocked /* avoid lock/unlock overhead */ flockfile(stdin); for (i = nfiles; i--; ) - flockfile(output[i]); + if (output[i] != NULL) + flockfile(output[i]); #endif /* load/copy header */ - if (inpheader && getheader(stdin, headline, NULL) < 0) { + if (inpflags & DOHEADER && getheader(stdin, headline, NULL) < 0) { fputs(argv[0], stderr); fputs(": cannot get header from standard input\n", stderr); return(1); } /* handle resolution string */ - if (inpres && !fgetsresolu(&ourres, stdin)) { + if (inpflags & DORESOLU && !fgetsresolu(&ourres, stdin)) { fputs(argv[0], stderr); fputs(": cannot get resolution string from standard input\n", stderr); return(1); } - if (outres && (ourres.xr <= 0) | (ourres.yr <= 0)) { + if (needres && (ourres.xr <= 0) | (ourres.yr <= 0)) { fputs(argv[0], stderr); fputs(": -oH option requires -iH or -x and -y options\n", stderr); return(1); @@ -280,11 +295,20 @@ main(int argc, char *argv[]) } for (i = 0; i < nfiles; i++) { /* complete headers */ if (hdrflags[i] & DOHEADER) { - if (!inpheader) + if (!(inpflags & DOHEADER)) newheader("RADIANCE", output[i]); printargs(argc, argv, output[i]); - if (format[i] != NULL) + fprintf(output[i], "NCOMP=%d\n", ncomp[i]); + if (format[i] != NULL) { + extern const char BIGEND[]; + if ((format[i][0] == 'f') | + (format[i][0] == 'd')) { + fputs(BIGEND, output[i]); + fputs(nativebigendian() ^ swapped ? + "1\n" : "0\n", output[i]); + } fputformat(format[i], output[i]); + } fputc('\n', output[i]); } if (hdrflags[i] & DORESOLU) @@ -293,29 +317,42 @@ main(int argc, char *argv[]) do { /* main loop */ for (i = 0; i < nfiles; i++) { if (bytsiz[i] > 0) { /* binary output */ - if (getbinary(buf, bytsiz[i], 1, stdin) < 1) + if (getbinary(buf, bytsiz[i], ncomp[i], + stdin) < ncomp[i]) break; - if (putbinary(buf, bytsiz[i], 1, output[i]) != 1) + if (output[i] != NULL && + putbinary(buf, bytsiz[i], ncomp[i], + output[i]) < ncomp[i]) break; - } else if (bytsiz[i] < 0) { /* N-field output */ - int n = -bytsiz[i]; + } else if (ncomp[i] > 1) { /* N-field output */ + int n = ncomp[i]; while (n--) { if (!scanOK(termc[i])) break; - if (fputs(buf, output[i]) == EOF) + if (output[i] != NULL && + fputs(buf, output[i]) == EOF) break; } if (n >= 0) /* fell short? */ break; - if (termc[i] != '\n') /* add EOL if none */ + if ((output[i] != NULL) & /* add EOL if none */ + (termc[i] != '\n')) fputc('\n', output[i]); } else { /* 1-field output */ if (!scanOK(termc[i])) break; - if (fputs(buf, output[i]) == EOF) - break; - if (termc[i] != '\n') /* add EOL if none */ - fputc('\n', output[i]); + if (output[i] != NULL) { + if (fputs(buf, output[i]) == EOF) + break; + if (termc[i] != '\n') /* add EOL? */ + fputc('\n', output[i]); + } + } + /* skip input EOL? */ + if (!bininp && termc[nfiles-1] != '\n') { + int c = getchar(); + if ((c != '\n') & (c != EOF)) + ungetc(c, stdin); } } if (i < nfiles)
