root/radiance/ray/src/cal/rsplit.c
Fri Jun 7 20:26:53 2024 UTC (13 months, 4 weeks ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 1.16: +2 -4 lines
Diff to previous 1.16 , to selected 1.6
perf(rsplit): truly minor optimization (possible struct size reduction)
Fri Jun 7 18:19:22 2024 UTC (13 months, 4 weeks ago) by greg
Changes since 1.15: +99 -90 lines
Diff to previous 1.15 , to selected 1.6
feature(rsplit,rlam): Modified to allow any number of files up to system limit
Sun Apr 5 15:07:09 2020 UTC (5 years, 4 months ago) by greg
CVS Tags: rad5R3, rad5R4
Changes since 1.14: +22 -7 lines
Diff to previous 1.14 , to selected 1.6
Added check for duplicate output file(s)
Sun Apr 5 02:25:22 2020 UTC (5 years, 4 months ago) by greg
Changes since 1.13: +18 -15 lines
Diff to previous 1.13 , to selected 1.6
Fixed issue with duplicate, incorrect headers if '-' used more than once
Sat Apr 4 16:23:00 2020 UTC (5 years, 4 months ago) by greg
Changes since 1.12: +21 -9 lines
Diff to previous 1.12 , to selected 1.6
Added '.' for discarding output
Tue Mar 31 16:39:01 2020 UTC (5 years, 4 months ago) by greg
Changes since 1.11: +18 -11 lines
Diff to previous 1.11 , to selected 1.6
Added NCOMP= line to header output
Thu Nov 7 23:13:12 2019 UTC (5 years, 8 months ago) by greg
Changes since 1.10: +8 -2 lines
Diff to previous 1.10 , to selected 1.6
Made it so a space separator matches all white space
Wed Aug 14 21:00:14 2019 UTC (5 years, 11 months ago) by greg
Changes since 1.9: +18 -3 lines
Diff to previous 1.9 , to selected 1.6
Added byte order to gendaymtx, rsplit, dctimestep, rcode_depth, and rcode_normal
Tue Aug 13 16:31:35 2019 UTC (5 years, 11 months ago) by greg
Diff to previous 1.8 , to selected 1.6
Windows cleaning (thanks to Nathaniel Jones for pointing out errors)
Mon Jul 22 18:01:03 2019 UTC (6 years ago) by greg
Changes since 1.7: +20 -26 lines
Diff to previous 1.7 , to selected 1.6
Made option behavior more consistent
Sat Jul 20 23:12:53 2019 UTC (6 years ago) by greg
Changes since 1.6: +19 -16 lines
Diff to previous 1.6
Fixed issue with extra newline
Revision 1.6 - (view) (download) (annotate) - [selected]
Fri Jul 19 17:37:55 2019 UTC (6 years ago) by greg
Changes since 1.5: +2 -4 lines
Diff to previous 1.5
Tue Jul 16 15:59:49 2019 UTC (6 years ago) by greg
Changes since 1.4: +2 -1 lines
Diff to previous 1.4 , to selected 1.6
Made it so -t option sets newline if no character follows
Fri Jul 5 15:04:20 2019 UTC (6 years, 1 month ago) by greg
Changes since 1.3: +15 -8 lines
Diff to previous 1.3 , to selected 1.6
Improved error reporting and added newline after ASCII records
Fri Jul 5 02:26:16 2019 UTC (6 years, 1 month ago) by greg
Changes since 1.2: +6 -1 lines
Diff to previous 1.2 , to selected 1.6
Added check for write errors
Fri Jul 5 00:46:23 2019 UTC (6 years, 1 month ago) by greg
Changes since 1.1: +6 -1 lines
Diff to previous 1.1 , to selected 1.6
Added check for premature end-of-data
Fri Jul 5 00:20:57 2019 UTC (6 years, 1 month ago) by greg
Diff to selected 1.6
