--- ray/src/cal/rsplit.c 2020/04/05 02:25:22 1.14 +++ ray/src/cal/rsplit.c 2020/04/05 15:07:09 1.15 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rsplit.c,v 1.14 2020/04/05 02:25:22 greg Exp $"; +static const char RCSid[] = "$Id: rsplit.c,v 1.15 2020/04/05 15:07:09 greg Exp $"; #endif /* * rsplit.c - split input into multiple output streams @@ -102,8 +102,10 @@ main(int argc, char *argv[]) int curbytes = 0; int curflags = 0; const char *curfmt = "ascii"; - int i; + short outndx[MAXFILE]; + int i; + memset(outndx, 0, sizeof(outndx)); for (i = 1; i < argc; i++) { if (argv[i][0] == '-') { switch (argv[i][1]) { @@ -194,7 +196,8 @@ main(int argc, char *argv[]) format[nfiles] = curfmt; nstdoutcomp += ncomp[nfiles] = curncomp; - bytsiz[nfiles++] = curbytes; + bytsiz[nfiles] = curbytes; + outndx[nfiles++] = i; break; badopt:; default: @@ -207,7 +210,8 @@ main(int argc, char *argv[]) termc[nfiles] = curterm; format[nfiles] = curfmt; ncomp[nfiles] = curncomp; - bytsiz[nfiles++] = curbytes; + bytsiz[nfiles] = curbytes; + outndx[nfiles++] = i; } else if (argv[i][0] == '!') { needres |= (curflags & DORESOLU); hdrflags[nfiles] = curflags; @@ -221,8 +225,18 @@ main(int argc, char *argv[]) SET_FILE_BINARY(output[nfiles]); format[nfiles] = curfmt; ncomp[nfiles] = curncomp; - bytsiz[nfiles++] = curbytes; + bytsiz[nfiles] = curbytes; + outndx[nfiles++] = i; } else { + int j = nfiles; + while (j--) /* check duplicates */ + if (!strcmp(argv[i], argv[outndx[j]])) { + fputs(argv[0], stderr); + fputs(": duplicate output: ", stderr); + fputs(argv[i], stderr); + fputc('\n', stderr); + return(1); + } if (append & (curflags != 0)) { fputs(argv[0], stderr); fputs(": -a option incompatible with -oh and -oH\n", @@ -248,7 +262,8 @@ main(int argc, char *argv[]) SET_FILE_BINARY(output[nfiles]); format[nfiles] = curfmt; ncomp[nfiles] = curncomp; - bytsiz[nfiles++] = curbytes; + bytsiz[nfiles] = curbytes; + outndx[nfiles++] = i; } if (nfiles >= MAXFILE) { fputs(argv[0], stderr); @@ -305,7 +320,7 @@ main(int argc, char *argv[]) nstdoutcomp : ncomp[i]); if (format[i] != NULL) { extern const char BIGEND[]; - if (format[i][0] != 'a') { + if (bytsiz[i] > 1) { fputs(BIGEND, output[i]); fputs(nativebigendian() ^ swapped ? "1\n" : "0\n", output[i]);
