1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: rsplit.c,v 1.16 2024/06/07 18:19:22 greg Exp $"; |
3 |
#endif |
4 |
5 |
* rsplit.c - split input into multiple output streams |
6 |
7 |
* 7/4/19 Greg Ward |
8 |
9 |
10 |
#include <ctype.h> |
11 |
12 |
#include "rtio.h" |
13 |
#include "platform.h" |
14 |
#include "paths.h" |
15 |
#include "resolu.h" |
16 |
17 |
#define DOHEADER 1 |
18 |
#define DORESOLU 2 |
19 |
20 |
int swapped = 0; /* input is byte-swapped */ |
21 |
22 |
struct outstream { /* structure to hold output stream info */ |
23 |
const char *outspec; /* output specification */ |
24 |
FILE *output; /* output stream */ |
25 |
int ncomp; /* component count */ |
26 |
int bytsiz; /* bytes/component if binary */ |
27 |
int hdrflags; /* header output flags */ |
28 |
int termc; /* data separation character */ |
29 |
const char *format; /* data format */ |
30 |
} *rofile = NULL; |
31 |
32 |
int nfiles = 0; /* output file count */ |
33 |
34 |
RESOLU ourres = {PIXSTANDARD, 0, 0}; |
35 |
36 |
char buf[16384]; /* input buffer used in scanOK() */ |
37 |
38 |
39 |
/* process header line */ |
40 |
int |
41 |
headline(char *s, void *p) |
42 |
43 |
extern const char FMTSTR[]; |
44 |
int i; |
45 |
46 |
if (strstr(s, FMTSTR) == s) |
47 |
return(0); /* don't copy format */ |
48 |
if (!strncmp(s, "NROWS=", 6)) |
49 |
return(0); |
50 |
if (!strncmp(s, "NCOLS=", 6)) |
51 |
return(0); |
52 |
if (!strncmp(s, "NCOMP=", 6)) |
53 |
return(0); |
54 |
if ((i = isbigendian(s)) >= 0) { |
55 |
swapped = (nativebigendian() != i); |
56 |
return(0); |
57 |
58 |
i = nfiles; |
59 |
while (i--) /* else copy line to output streams */ |
60 |
if (rofile[i].hdrflags & DOHEADER) |
61 |
fputs(s, rofile[i].output); |
62 |
return(1); |
63 |
64 |
65 |
66 |
/* scan field into buffer up to and including terminating byte */ |
67 |
int |
68 |
scanOK(int termc) |
69 |
70 |
int skip_white = (termc == ' '); |
71 |
char *cp = buf; |
72 |
int c; |
73 |
74 |
while ((c = getchar()) != EOF) { |
75 |
if (skip_white && isspace(c)) |
76 |
continue; |
77 |
skip_white = 0; |
78 |
if (c == '\n' && isspace(termc)) |
79 |
c = termc; /* forgiving assumption */ |
80 |
*cp++ = c; |
81 |
if (cp-buf >= sizeof(buf)) |
82 |
break; |
83 |
if ((termc == ' ') ? isspace(c) : (c == termc)) { |
84 |
*cp = '\0'; |
85 |
return(cp-buf); |
86 |
87 |
88 |
return(0); |
89 |
90 |
91 |
92 |
int |
93 |
main(int argc, char *argv[]) |
94 |
95 |
int inpflags = 0; |
96 |
int needres = 0; |
97 |
int force = 0; |
98 |
int append = 0; |
99 |
long outcnt = 0; |
100 |
int bininp = 0; |
101 |
int nstdoutcomp = 0; |
102 |
int curterm = '\n'; |
103 |
int curncomp = 1; |
104 |
int curbytes = 0; |
105 |
int curflags = 0; |
106 |
const char *curfmt = "ascii"; |
107 |
int i; |
108 |
109 |
rofile = (struct outstream *)calloc(argc-1, sizeof(struct outstream)); |
110 |
if (!rofile) { |
111 |
fputs(argv[0], stderr); |
112 |
fputs(": not enough memory\n", stderr); |
113 |
return(1); |
114 |
115 |
for (i = 1; i < argc; i++) { |
116 |
if (argv[i][0] == '-') { |
117 |
switch (argv[i][1]) { |
118 |
case 't': |
119 |
curterm = argv[i][2]; |
120 |
if (!curterm) curterm = '\n'; |
121 |
break; |
122 |
case 'i': |
123 |
switch (argv[i][2]) { |
124 |
case 'h': |
125 |
inpflags ^= DOHEADER; |
126 |
break; |
127 |
case 'H': |
128 |
inpflags ^= DORESOLU; |
129 |
break; |
130 |
default: |
131 |
goto badopt; |
132 |
133 |
break; |
134 |
case 'f': |
135 |
force = !force; |
136 |
break; |
137 |
case 'a': |
138 |
append = !append; |
139 |
break; |
140 |
case 'x': |
141 |
ourres.xr = atoi(argv[++i]); |
142 |
break; |
143 |
case 'y': |
144 |
ourres.yr = atoi(argv[++i]); |
145 |
break; |
146 |
case 'o': |
147 |
148 |
case 'n': |
149 |
outcnt = atol(argv[++i]); |
150 |
continue; |
151 |
case 'h': |
152 |
curflags ^= DOHEADER; |
153 |
continue; |
154 |
case 'H': |
155 |
curflags ^= DORESOLU; |
156 |
continue; |
157 |
case 'f': |
158 |
curfmt = "float"; |
159 |
curbytes = sizeof(float); |
160 |
break; |
161 |
case 'd': |
162 |
curfmt = "double"; |
163 |
curbytes = sizeof(double); |
164 |
break; |
165 |
case 'i': |
166 |
curfmt = "int"; |
167 |
curbytes = sizeof(int); |
168 |
break; |
169 |
case 'w': |
170 |
curfmt = "16-bit"; |
171 |
curbytes = 2; |
172 |
break; |
173 |
case 'b': |
174 |
curfmt = "byte"; |
175 |
curbytes = 1; |
176 |
break; |
177 |
case 'a': |
178 |
curfmt = "ascii"; |
179 |
curbytes = 0; |
180 |
break; |
181 |
default: |
182 |
goto badopt; |
183 |
184 |
curncomp = isdigit(argv[i][3]) ? |
185 |
atoi(argv[i]+3) : 1 ; |
186 |
if (curbytes*curncomp > (int)sizeof(buf)) { |
187 |
188 |
fputs(": output size too big\n", stderr); |
189 |
return(1); |
190 |
191 |
bininp += (curbytes > 0); |
192 |
break; |
193 |
case '\0': /* stdout */ |
194 |
if (!nstdoutcomp) { /* first use? */ |
195 |
needres |= (curflags & DORESOLU); |
196 |
rofile[nfiles].hdrflags = curflags; |
197 |
198 |
rofile[nfiles].output = stdout; |
199 |
if (curbytes > 0) |
200 |
SET_FILE_BINARY(rofile[nfiles].output); |
201 |
rofile[nfiles].termc = curterm; |
202 |
rofile[nfiles].format = curfmt; |
203 |
nstdoutcomp += |
204 |
rofile[nfiles].ncomp = curncomp; |
205 |
rofile[nfiles].bytsiz = curbytes; |
206 |
rofile[nfiles++].outspec = argv[i]; |
207 |
break; |
208 |
badopt:; |
209 |
default: |
210 |
211 |
fputs(": bad option\n", stderr); |
212 |
return(1); |
213 |
214 |
} else if (argv[i][0] == '.' && !argv[i][1]) { |
215 |
rofile[nfiles].output = NULL; /* discard data */ |
216 |
217 |
218 |
219 |
220 |
221 |
} else if (argv[i][0] == '!') { |
222 |
223 |
224 |
225 |
if ((rofile[nfiles].output = popen(argv[i]+1, "w")) == NULL) { |
226 |
fputs(argv[i], stderr); |
227 |
fputs(": cannot start command\n", stderr); |
228 |
return(1); |
229 |
230 |
if (curbytes > 0) |
231 |
232 |
233 |
234 |
235 |
236 |
} else { |
237 |
int j = nfiles; |
238 |
while (j--) /* check duplicates */ |
239 |
if (!strcmp(argv[i], rofile[j].outspec)) { |
240 |
241 |
fputs(": duplicate output: ", stderr); |
242 |
243 |
fputc('\n', stderr); |
244 |
return(1); |
245 |
246 |
if (append & (curflags != 0)) { |
247 |
248 |
fputs(": -a option incompatible with -oh and -oH\n", |
249 |
stderr); |
250 |
return(1); |
251 |
252 |
253 |
254 |
255 |
if (!append & !force && access(argv[i], F_OK) == 0) { |
256 |
257 |
fputs(": file exists -- use -f to overwrite\n", |
258 |
stderr); |
259 |
return(1); |
260 |
261 |
rofile[nfiles].output = fopen(argv[i], append ? "a" : "w"); |
262 |
if (!rofile[nfiles].output) { |
263 |
264 |
fputs(": cannot open for output\n", stderr); |
265 |
return(1); |
266 |
267 |
if (curbytes > 0) |
268 |
269 |
270 |
271 |
272 |
273 |
274 |
275 |
if (!nfiles) { |
276 |
277 |
fputs(": no output streams\n", stderr); |
278 |
return(1); |
279 |
} /* reduce array to size we need */ |
280 |
rofile = (struct outstream *)realloc(rofile, nfiles*sizeof(struct outstream)); |
281 |
if (!rofile) { |
282 |
283 |
fputs(": realloc() failed!\n", stderr); |
284 |
return(1); |
285 |
286 |
if (bininp) /* binary input? */ |
287 |
SET_FILE_BINARY(stdin); |
288 |
#ifdef getc_unlocked /* avoid lock/unlock overhead */ |
289 |
flockfile(stdin); |
290 |
for (i = nfiles; i--; ) |
291 |
if (rofile[i].output != NULL) |
292 |
ftrylockfile(rofile[i].output); |
293 |
#endif |
294 |
/* load/copy header */ |
295 |
if (inpflags & DOHEADER && getheader(stdin, headline, NULL) < 0) { |
296 |
297 |
fputs(": cannot read header from standard input\n", |
298 |
stderr); |
299 |
return(1); |
300 |
301 |
/* handle resolution string */ |
302 |
if (inpflags & DORESOLU && !fgetsresolu(&ourres, stdin)) { |
303 |
304 |
fputs(": bad resolution string on standard input\n", stderr); |
305 |
return(1); |
306 |
307 |
if (needres && (ourres.xr <= 0) | (ourres.yr <= 0)) { |
308 |
309 |
fputs(": -oH option requires -iH or -x and -y options\n", stderr); |
310 |
return(1); |
311 |
312 |
if ((ourres.xr > 0) & (ourres.yr > 0)) { |
313 |
if (outcnt <= 0) { |
314 |
outcnt = ourres.xr * ourres.yr; |
315 |
} else if (outcnt != ourres.xr*ourres.yr) { |
316 |
317 |
fputs(": warning: -on option does not agree with resolution\n", |
318 |
stderr); |
319 |
320 |
321 |
for (i = 0; i < nfiles; i++) { /* complete headers */ |
322 |
if (rofile[i].hdrflags & DOHEADER) { |
323 |
if (!(inpflags & DOHEADER)) |
324 |
newheader("RADIANCE", rofile[i].output); |
325 |
printargs(argc, argv, rofile[i].output); |
326 |
fprintf(rofile[i].output, "NCOMP=%d\n", rofile[i].output==stdout ? |
327 |
nstdoutcomp : rofile[i].ncomp); |
328 |
if (rofile[i].format != NULL) { |
329 |
extern const char BIGEND[]; |
330 |
if (rofile[i].bytsiz > 1) { |
331 |
fputs(BIGEND, rofile[i].output); |
332 |
fputs(nativebigendian() ^ swapped ? |
333 |
"1\n" : "0\n", rofile[i].output); |
334 |
335 |
fputformat(rofile[i].format, rofile[i].output); |
336 |
337 |
fputc('\n', rofile[i].output); |
338 |
339 |
if (rofile[i].hdrflags & DORESOLU) |
340 |
fputsresolu(&ourres, rofile[i].output); |
341 |
342 |
do { /* main loop */ |
343 |
for (i = 0; i < nfiles; i++) { |
344 |
if (rofile[i].bytsiz > 0) { /* binary output */ |
345 |
if (getbinary(buf, rofile[i].bytsiz, rofile[i].ncomp, |
346 |
stdin) != rofile[i].ncomp) |
347 |
break; |
348 |
if (rofile[i].output != NULL && |
349 |
putbinary(buf, rofile[i].bytsiz, rofile[i].ncomp, |
350 |
rofile[i].output) != rofile[i].ncomp) |
351 |
break; |
352 |
} else if (rofile[i].ncomp > 1) { /* N-field output */ |
353 |
int n = rofile[i].ncomp; |
354 |
while (n--) { |
355 |
if (!scanOK(rofile[i].termc)) |
356 |
break; |
357 |
358 |
fputs(buf, rofile[i].output) == EOF) |
359 |
break; |
360 |
361 |
if (n >= 0) /* fell short? */ |
362 |
break; |
363 |
if ((rofile[i].output != NULL) & /* add EOL if none */ |
364 |
(rofile[i].termc != '\n')) |
365 |
366 |
} else { /* 1-field output */ |
367 |
368 |
break; |
369 |
if (rofile[i].output != NULL) { |
370 |
if (fputs(buf, rofile[i].output) == EOF) |
371 |
break; |
372 |
if (rofile[i].termc != '\n') /* add EOL? */ |
373 |
374 |
375 |
376 |
/* skip input EOL? */ |
377 |
if (!bininp && rofile[nfiles-1].termc != '\n') { |
378 |
int c = getchar(); |
379 |
if ((c != '\n') & (c != EOF)) |
380 |
ungetc(c, stdin); |
381 |
382 |
383 |
if (i < nfiles) |
384 |
break; |
385 |
} while (--outcnt); |
386 |
/* check ending */ |
387 |
if (fflush(NULL) == EOF) { |
388 |
389 |
fputs(": write error on one or more outputs\n", stderr); |
390 |
return(1); |
391 |
392 |
if (outcnt > 0) { |
393 |
394 |
fputs(": warning: premature EOD\n", stderr); |
395 |
396 |
return(0); |
397 |
