1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id$"; |
3 |
#endif |
4 |
5 |
* rcalc.c - record calculator program. |
6 |
7 |
* 9/11/87 |
8 |
9 |
10 |
#include <stdio.h> |
11 |
12 |
#include <stdlib.h> |
13 |
14 |
#include <math.h> |
15 |
16 |
#include <ctype.h> |
17 |
18 |
#include "calcomp.h" |
19 |
20 |
#ifdef CPM |
21 |
#define getc agetc /* text files only, right? */ |
22 |
#endif |
23 |
24 |
#define isnum(c) (isdigit(c) || (c)=='-' || (c)=='.' \ |
25 |
|| (c)=='+' || (c)=='e' || (c)=='E') |
26 |
27 |
#define isblnk(c) (igneol ? isspace(c) : (c)==' '||(c)=='\t') |
28 |
29 |
#define INBSIZ 4096 /* longest record */ |
30 |
#define MAXCOL 32 /* number of columns recorded */ |
31 |
32 |
/* field type specifications */ |
33 |
#define F_NUL 0 /* empty */ |
34 |
#define F_TYP 0x7000 /* mask for type */ |
35 |
#define F_WID 0x0fff /* mask for width */ |
36 |
#define T_LIT 0x1000 /* string literal */ |
37 |
#define T_STR 0x2000 /* string variable */ |
38 |
#define T_NUM 0x3000 /* numeric value */ |
39 |
40 |
struct strvar { /* string variable */ |
41 |
char *name; |
42 |
char *val; |
43 |
char *preset; |
44 |
struct strvar *next; |
45 |
46 |
47 |
struct field { /* record format structure */ |
48 |
int type; /* type of field (& width) */ |
49 |
union { |
50 |
char *sl; /* string literal */ |
51 |
struct strvar *sv; /* string variable */ |
52 |
char *nv; /* numeric variable */ |
53 |
EPNODE *ne; /* numeric expression */ |
54 |
} f; /* field contents */ |
55 |
struct field *next; /* next field in record */ |
56 |
57 |
58 |
#define savqstr(s) strcpy(emalloc(strlen(s)+1),s) |
59 |
#define freqstr(s) efree(s) |
60 |
61 |
extern char *strcpy(), *emalloc(), *savestr(); |
62 |
struct strvar *getsvar(); |
63 |
64 |
struct field *inpfmt = NULL; /* input record format */ |
65 |
struct field *outfmt = NULL; /* output record structure */ |
66 |
struct strvar *svhead = NULL; /* string variables */ |
67 |
68 |
int blnkeq = 1; /* blanks compare equal? */ |
69 |
int igneol = 0; /* ignore end of line? */ |
70 |
char sepchar = '\t'; /* input/output separator */ |
71 |
int noinput = 0; /* no input records? */ |
72 |
int nbicols = 0; /* number of binary input columns */ |
73 |
int bocols = 0; /* produce binary output columns */ |
74 |
char inpbuf[INBSIZ]; /* input buffer */ |
75 |
double colval[MAXCOL]; /* input column values */ |
76 |
unsigned long colflg = 0; /* column retrieved flags */ |
77 |
int colpos; /* output column position */ |
78 |
79 |
int nowarn = 0; /* non-fatal diagnostic output */ |
80 |
int unbuff = 0; /* unbuffered output (flush each record) */ |
81 |
82 |
struct { |
83 |
FILE *fin; /* input file */ |
84 |
int chr; /* next character */ |
85 |
char *beg; /* home position */ |
86 |
char *pos; /* scan position */ |
87 |
char *end; /* read position */ |
88 |
} ipb; /* circular lookahead buffer */ |
89 |
90 |
91 |
main(argc, argv) |
92 |
int argc; |
93 |
char *argv[]; |
94 |
95 |
int i; |
96 |
97 |
esupport |= E_VARIABLE|E_FUNCTION|E_INCHAN|E_OUTCHAN|E_RCONST; |
98 |
esupport &= ~(E_REDEFW); |
99 |
100 |
#ifdef BIGGERLIB |
101 |
biggerlib(); |
102 |
#endif |
103 |
varset("PI", ':', 3.14159265358979323846); |
104 |
105 |
for (i = 1; i < argc && argv[i][0] == '-'; i++) |
106 |
switch (argv[i][1]) { |
107 |
case 'b': |
108 |
blnkeq = !blnkeq; |
109 |
break; |
110 |
case 'l': |
111 |
igneol = !igneol; |
112 |
break; |
113 |
case 't': |
114 |
sepchar = argv[i][2]; |
115 |
break; |
116 |
case 's': |
117 |
svpreset(argv[++i]); |
118 |
break; |
119 |
case 'f': |
120 |
fcompile(argv[++i]); |
121 |
break; |
122 |
case 'e': |
123 |
scompile(argv[++i], NULL, 0); |
124 |
break; |
125 |
case 'n': |
126 |
noinput = 1; |
127 |
break; |
128 |
case 'i': |
129 |
switch (argv[i][2]) { |
130 |
case '\0': |
131 |
nbicols = 0; |
132 |
readfmt(argv[++i], 0); |
133 |
break; |
134 |
case 'a': |
135 |
nbicols = 0; |
136 |
break; |
137 |
case 'd': |
138 |
if (isdigit(argv[i][3])) |
139 |
nbicols = atoi(argv[i]+3); |
140 |
else |
141 |
nbicols = 1; |
142 |
break; |
143 |
case 'f': |
144 |
145 |
nbicols = -atoi(argv[i]+3); |
146 |
else |
147 |
nbicols = -1; |
148 |
break; |
149 |
default: |
150 |
goto userr; |
151 |
152 |
break; |
153 |
case 'o': |
154 |
155 |
case '\0': |
156 |
bocols = 0; |
157 |
readfmt(argv[++i], 1); |
158 |
break; |
159 |
case 'a': |
160 |
bocols = 0; |
161 |
break; |
162 |
case 'd': |
163 |
bocols = 1; |
164 |
break; |
165 |
case 'f': |
166 |
bocols = -1; |
167 |
break; |
168 |
169 |
break; |
170 |
case 'w': |
171 |
nowarn = !nowarn; |
172 |
break; |
173 |
case 'u': |
174 |
unbuff = !unbuff; |
175 |
break; |
176 |
default:; |
177 |
userr: |
178 |
eputs("Usage: "); |
179 |
eputs(argv[0]); |
180 |
eputs(" [-b][-l][-n][-w][-u][-tS][-s svar=sval][-e expr][-f source][-i infmt][-o outfmt] [file]\n"); |
181 |
quit(1); |
182 |
183 |
184 |
if (noinput) { /* produce a single output record */ |
185 |
eclock++; |
186 |
putout(); |
187 |
quit(0); |
188 |
189 |
190 |
if (blnkeq) /* for efficiency */ |
191 |
nbsynch(); |
192 |
193 |
if (i == argc) /* from stdin */ |
194 |
execute(NULL); |
195 |
else /* from one or more files */ |
196 |
for ( ; i < argc; i++) |
197 |
execute(argv[i]); |
198 |
199 |
quit(0); |
200 |
201 |
202 |
203 |
nbsynch() /* non-blank starting synch character */ |
204 |
205 |
if (inpfmt == NULL || (inpfmt->type & F_TYP) != T_LIT) |
206 |
return; |
207 |
while (isblnk(*inpfmt->f.sl)) |
208 |
inpfmt->f.sl++; |
209 |
if (!*inpfmt->f.sl) |
210 |
inpfmt = inpfmt->next; |
211 |
212 |
213 |
214 |
int |
215 |
getinputrec(fp) /* get next input record */ |
216 |
FILE *fp; |
217 |
218 |
if (inpfmt != NULL) |
219 |
return(getrec()); |
220 |
if (nbicols > 0) |
221 |
return(fread(inpbuf, sizeof(double), |
222 |
nbicols, fp) == nbicols); |
223 |
if (nbicols < 0) |
224 |
return(fread(inpbuf, sizeof(float), |
225 |
-nbicols, fp) == -nbicols); |
226 |
return(fgets(inpbuf, INBSIZ, fp) != NULL); |
227 |
228 |
229 |
230 |
execute(file) /* process a file */ |
231 |
char *file; |
232 |
233 |
int conditional = vardefined("cond"); |
234 |
long nrecs = 0; |
235 |
long nout = 0; |
236 |
FILE *fp; |
237 |
238 |
if (file == NULL) |
239 |
fp = stdin; |
240 |
else if ((fp = fopen(file, "r")) == NULL) { |
241 |
eputs(file); |
242 |
eputs(": cannot open\n"); |
243 |
quit(1); |
244 |
245 |
246 |
initinp(fp); |
247 |
248 |
while (getinputrec(fp)) { |
249 |
varset("recno", '=', (double)++nrecs); |
250 |
colflg = 0; |
251 |
eclock++; |
252 |
if (!conditional || varvalue("cond") > 0.0) { |
253 |
varset("outno", '=', (double)++nout); |
254 |
putout(); |
255 |
256 |
257 |
fclose(fp); |
258 |
259 |
260 |
261 |
putout() /* produce an output record */ |
262 |
263 |
extern void chanset(), bchanset(); |
264 |
265 |
colpos = 0; |
266 |
if (outfmt != NULL) |
267 |
putrec(); |
268 |
else if (bocols) |
269 |
chanout(bchanset); |
270 |
else |
271 |
chanout(chanset); |
272 |
if (colpos && !bocols) |
273 |
putchar('\n'); |
274 |
if (unbuff) |
275 |
fflush(stdout); |
276 |
277 |
278 |
279 |
double |
280 |
chanvalue(n) /* return value for column n */ |
281 |
int n; |
282 |
283 |
int i; |
284 |
register char *cp; |
285 |
286 |
if (noinput || inpfmt != NULL) { |
287 |
eputs("no column input\n"); |
288 |
quit(1); |
289 |
290 |
if (n < 1) { |
291 |
eputs("illegal channel number\n"); |
292 |
quit(1); |
293 |
294 |
if (nbicols > 0) { |
295 |
if (n > nbicols) |
296 |
return(0.0); |
297 |
cp = inpbuf + (n-1)*sizeof(double); |
298 |
return(*(double *)cp); |
299 |
300 |
if (nbicols < 0) { |
301 |
if (n > -nbicols) |
302 |
return(0.0); |
303 |
cp = inpbuf + (n-1)*sizeof(float); |
304 |
return(*(float *)cp); |
305 |
306 |
if (n <= MAXCOL && colflg & 1L<<(n-1)) |
307 |
return(colval[n-1]); |
308 |
309 |
cp = inpbuf; |
310 |
for (i = 1; i < n; i++) |
311 |
if (blnkeq && isspace(sepchar)) { |
312 |
while (isspace(*cp)) |
313 |
cp++; |
314 |
while (*cp && !isspace(*cp)) |
315 |
cp++; |
316 |
} else |
317 |
while (*cp && *cp++ != sepchar) |
318 |
319 |
320 |
while (isspace(*cp)) /* some atof()'s don't like tabs */ |
321 |
cp++; |
322 |
323 |
if (n <= MAXCOL) { |
324 |
colflg |= 1L<<(n-1); |
325 |
return(colval[n-1] = atof(cp)); |
326 |
} else |
327 |
return(atof(cp)); |
328 |
329 |
330 |
331 |
void |
332 |
chanset(n, v) /* output column n */ |
333 |
int n; |
334 |
double v; |
335 |
336 |
if (colpos == 0) /* no leading separator */ |
337 |
colpos = 1; |
338 |
while (colpos < n) { |
339 |
putchar(sepchar); |
340 |
colpos++; |
341 |
342 |
printf("%.9g", v); |
343 |
344 |
345 |
346 |
void |
347 |
bchanset(n, v) /* output binary channel n */ |
348 |
int n; |
349 |
double v; |
350 |
351 |
static char zerobuf[sizeof(double)]; |
352 |
353 |
while (++colpos < n) |
354 |
fwrite(zerobuf, |
355 |
bocols>0 ? sizeof(double) : sizeof(float), |
356 |
1, stdout); |
357 |
if (bocols > 0) |
358 |
fwrite(&v, sizeof(double), 1, stdout); |
359 |
else { |
360 |
float fval = v; |
361 |
fwrite(&fval, sizeof(float), 1, stdout); |
362 |
363 |
364 |
365 |
366 |
readfmt(spec, output) /* read record format */ |
367 |
char *spec; |
368 |
int output; |
369 |
370 |
int fd; |
371 |
char *inptr; |
372 |
struct field fmt; |
373 |
int res; |
374 |
register struct field *f; |
375 |
/* check for inline format */ |
376 |
for (inptr = spec; *inptr; inptr++) |
377 |
if (*inptr == '$') |
378 |
break; |
379 |
if (*inptr) /* inline */ |
380 |
inptr = spec; |
381 |
else { /* from file */ |
382 |
if ((fd = open(spec, 0)) == -1) { |
383 |
eputs(spec); |
384 |
385 |
quit(1); |
386 |
387 |
res = read(fd, inpbuf+1, INBSIZ-1); |
388 |
if (res <= 0 || res >= INBSIZ-1) { |
389 |
eputs(spec); |
390 |
if (res < 0) |
391 |
eputs(": read error\n"); |
392 |
else if (res == 0) |
393 |
eputs(": empty file\n"); |
394 |
else if (res >= INBSIZ-1) |
395 |
eputs(": format too long\n"); |
396 |
quit(1); |
397 |
398 |
close(fd); |
399 |
(inptr=inpbuf+1)[res] = '\0'; |
400 |
401 |
f = &fmt; /* get fields */ |
402 |
while ((res = readfield(&inptr)) != F_NUL) { |
403 |
f->next = (struct field *)emalloc(sizeof(struct field)); |
404 |
f = f->next; |
405 |
f->type = res; |
406 |
switch (res & F_TYP) { |
407 |
case T_LIT: |
408 |
f->f.sl = savqstr(inpbuf); |
409 |
break; |
410 |
case T_STR: |
411 |
f->f.sv = getsvar(inpbuf); |
412 |
break; |
413 |
case T_NUM: |
414 |
if (output) |
415 |
f->f.ne = eparse(inpbuf); |
416 |
else |
417 |
f->f.nv = savestr(inpbuf); |
418 |
break; |
419 |
420 |
/* add final newline if necessary */ |
421 |
if (!igneol && *inptr == '\0' && inptr[-1] != '\n') |
422 |
inptr = "\n"; |
423 |
424 |
f->next = NULL; |
425 |
if (output) |
426 |
outfmt = fmt.next; |
427 |
else |
428 |
inpfmt = fmt.next; |
429 |
430 |
431 |
432 |
int |
433 |
readfield(pp) /* get next field in format */ |
434 |
register char **pp; |
435 |
436 |
int type = F_NUL; |
437 |
int width = 0; |
438 |
439 |
440 |
cp = inpbuf; |
441 |
while (cp < &inpbuf[INBSIZ-1] && **pp != '\0') { |
442 |
width++; |
443 |
switch (type) { |
444 |
case F_NUL: |
445 |
if (**pp == '$') { |
446 |
(*pp)++; |
447 |
width++; |
448 |
if (**pp == '{') { |
449 |
type = T_NUM; |
450 |
(*pp)++; |
451 |
continue; |
452 |
} else if (**pp == '(') { |
453 |
type = T_STR; |
454 |
(*pp)++; |
455 |
continue; |
456 |
} else if (**pp != '$') { |
457 |
eputs("format error\n"); |
458 |
quit(1); |
459 |
460 |
width--; |
461 |
462 |
type = T_LIT; |
463 |
*cp++ = *(*pp)++; |
464 |
continue; |
465 |
case T_LIT: |
466 |
467 |
width--; |
468 |
break; |
469 |
470 |
*cp++ = *(*pp)++; |
471 |
continue; |
472 |
case T_NUM: |
473 |
if (**pp == '}') { |
474 |
(*pp)++; |
475 |
break; |
476 |
477 |
if (!isspace(**pp)) |
478 |
*cp++ = **pp; |
479 |
(*pp)++; |
480 |
continue; |
481 |
case T_STR: |
482 |
if (**pp == ')') { |
483 |
(*pp)++; |
484 |
break; |
485 |
486 |
487 |
*cp++ = **pp; |
488 |
(*pp)++; |
489 |
continue; |
490 |
491 |
break; |
492 |
493 |
*cp = '\0'; |
494 |
return(type | width); |
495 |
496 |
497 |
498 |
struct strvar * |
499 |
getsvar(svname) /* get string variable */ |
500 |
char *svname; |
501 |
502 |
register struct strvar *sv; |
503 |
504 |
for (sv = svhead; sv != NULL; sv = sv->next) |
505 |
if (!strcmp(sv->name, svname)) |
506 |
return(sv); |
507 |
sv = (struct strvar *)emalloc(sizeof(struct strvar)); |
508 |
sv->name = savqstr(svname); |
509 |
sv->val = sv->preset = NULL; |
510 |
sv->next = svhead; |
511 |
svhead = sv; |
512 |
return(sv); |
513 |
514 |
515 |
516 |
svpreset(eqn) /* preset a string variable */ |
517 |
char *eqn; |
518 |
519 |
520 |
register char *val; |
521 |
522 |
for (val = eqn; *val != '='; val++) |
523 |
if (!*val) |
524 |
return; |
525 |
*val++ = '\0'; |
526 |
sv = getsvar(eqn); |
527 |
if (sv->preset != NULL) |
528 |
freqstr(sv->preset); |
529 |
if (sv->val != NULL) |
530 |
freqstr(sv->val); |
531 |
sv->val = sv->preset = savqstr(val); |
532 |
*--val = '='; |
533 |
534 |
535 |
536 |
clearrec() /* clear input record variables */ |
537 |
538 |
539 |
540 |
for (f = inpfmt; f != NULL; f = f->next) |
541 |
switch (f->type & F_TYP) { |
542 |
case T_NUM: |
543 |
dremove(f->f.nv); |
544 |
break; |
545 |
case T_STR: |
546 |
if (f->f.sv->val != f->f.sv->preset) { |
547 |
freqstr(f->f.sv->val); |
548 |
f->f.sv->val = f->f.sv->preset; |
549 |
550 |
break; |
551 |
552 |
553 |
554 |
555 |
getrec() /* get next record from file */ |
556 |
557 |
int eatline; |
558 |
559 |
560 |
while (ipb.chr != EOF) { |
561 |
eatline = !igneol && ipb.chr != '\n'; |
562 |
if (blnkeq) /* beware of nbsynch() */ |
563 |
while (isblnk(ipb.chr)) |
564 |
scaninp(); |
565 |
clearrec(); /* start with fresh record */ |
566 |
567 |
if (getfield(f) == -1) |
568 |
break; |
569 |
if (f == NULL) { |
570 |
advinp(); |
571 |
return(1); |
572 |
573 |
resetinp(); |
574 |
if (eatline) { /* eat rest of line */ |
575 |
while (ipb.chr != '\n') { |
576 |
if (ipb.chr == EOF) |
577 |
return(0); |
578 |
scaninp(); |
579 |
580 |
scaninp(); |
581 |
advinp(); |
582 |
583 |
584 |
return(0); |
585 |
586 |
587 |
588 |
getfield(f) /* get next field */ |
589 |
590 |
591 |
static char buf[MAXWORD+1]; /* no recursion! */ |
592 |
int delim, inword; |
593 |
double d; |
594 |
char *np; |
595 |
596 |
597 |
598 |
case T_LIT: |
599 |
cp = f->f.sl; |
600 |
do { |
601 |
if (blnkeq && isblnk(*cp)) { |
602 |
if (!isblnk(ipb.chr)) |
603 |
return(-1); |
604 |
do |
605 |
cp++; |
606 |
while (isblnk(*cp)); |
607 |
do |
608 |
scaninp(); |
609 |
while (isblnk(ipb.chr)); |
610 |
} else if (*cp == ipb.chr) { |
611 |
cp++; |
612 |
scaninp(); |
613 |
} else |
614 |
return(-1); |
615 |
} while (*cp); |
616 |
return(0); |
617 |
case T_STR: |
618 |
if (f->next == NULL || (f->next->type & F_TYP) != T_LIT) |
619 |
delim = EOF; |
620 |
else |
621 |
delim = f->next->f.sl[0]; |
622 |
cp = buf; |
623 |
do { |
624 |
625 |
inword = 0; |
626 |
else if (blnkeq && delim != EOF) |
627 |
inword = isblnk(delim) ? |
628 |
!isblnk(ipb.chr) |
629 |
: ipb.chr != delim; |
630 |
else |
631 |
inword = cp-buf < (f->type & F_WID); |
632 |
if (inword) { |
633 |
*cp++ = ipb.chr; |
634 |
scaninp(); |
635 |
636 |
} while (inword && cp < &buf[MAXWORD]); |
637 |
*cp = '\0'; |
638 |
if (f->f.sv->val == NULL) |
639 |
f->f.sv->val = savqstr(buf); /* first setting */ |
640 |
else if (strcmp(f->f.sv->val, buf)) |
641 |
return(-1); /* doesn't match! */ |
642 |
return(0); |
643 |
case T_NUM: |
644 |
645 |
delim = EOF; |
646 |
else |
647 |
648 |
np = NULL; |
649 |
cp = buf; |
650 |
do { |
651 |
if (!((np==NULL&&isblnk(ipb.chr)) || isnum(ipb.chr))) |
652 |
inword = 0; |
653 |
654 |
655 |
!isblnk(ipb.chr) |
656 |
657 |
else |
658 |
659 |
if (inword) { |
660 |
if (np==NULL && !isblnk(ipb.chr)) |
661 |
np = cp; |
662 |
*cp++ = ipb.chr; |
663 |
scaninp(); |
664 |
665 |
666 |
*cp = '\0'; |
667 |
d = np==NULL ? 0. : atof(np); |
668 |
if (!vardefined(f->f.nv)) |
669 |
varset(f->f.nv, '=', d); /* first setting */ |
670 |
else if ((d = (varvalue(f->f.nv)-d)/(d==0.?1.:d)) > .001 |
671 |
|| d < -.001) |
672 |
673 |
return(0); |
674 |
675 |
676 |
677 |
678 |
putrec() /* output a record */ |
679 |
680 |
char fmt[32]; |
681 |
register int n; |
682 |
683 |
int adlast, adnext; |
684 |
685 |
adlast = 0; |
686 |
for (f = outfmt; f != NULL; f = f->next) { |
687 |
adnext = blnkeq && |
688 |
f->next != NULL && |
689 |
!( (f->next->type&F_TYP) == T_LIT && |
690 |
f->next->f.sl[0] == ' ' ); |
691 |
692 |
case T_LIT: |
693 |
fputs(f->f.sl, stdout); |
694 |
adlast = f->f.sl[(f->type&F_WID)-1] != ' '; |
695 |
break; |
696 |
case T_STR: |
697 |
if (f->f.sv->val == NULL) { |
698 |
eputs(f->f.sv->name); |
699 |
eputs(": undefined string\n"); |
700 |
quit(1); |
701 |
702 |
n = (int)(f->type & F_WID) - strlen(f->f.sv->val); |
703 |
if (adlast) |
704 |
fputs(f->f.sv->val, stdout); |
705 |
if (!(adlast && adnext)) |
706 |
while (n-- > 0) |
707 |
putchar(' '); |
708 |
if (!adlast) |
709 |
710 |
adlast = 1; |
711 |
break; |
712 |
case T_NUM: |
713 |
n = f->type & F_WID; |
714 |
if (adlast && adnext) |
715 |
strcpy(fmt, "%g"); |
716 |
else if (adlast) |
717 |
sprintf(fmt, "%%-%dg", n); |
718 |
else |
719 |
sprintf(fmt, "%%%dg", n); |
720 |
printf(fmt, evalue(f->f.ne)); |
721 |
adlast = 1; |
722 |
break; |
723 |
724 |
725 |
726 |
727 |
728 |
initinp(fp) /* prepare lookahead buffer */ |
729 |
FILE *fp; |
730 |
731 |
ipb.fin = fp; |
732 |
ipb.beg = ipb.end = inpbuf; |
733 |
ipb.pos = inpbuf-1; /* position before beginning */ |
734 |
ipb.chr = '\0'; |
735 |
scaninp(); |
736 |
737 |
738 |
739 |
scaninp() /* scan next character */ |
740 |
741 |
742 |
return; |
743 |
if (++ipb.pos >= &inpbuf[INBSIZ]) |
744 |
ipb.pos = inpbuf; |
745 |
if (ipb.pos == ipb.end) { /* new character */ |
746 |
if ((ipb.chr = getc(ipb.fin)) != EOF) { |
747 |
*ipb.end = ipb.chr; |
748 |
if (++ipb.end >= &inpbuf[INBSIZ]) |
749 |
ipb.end = inpbuf; |
750 |
if (ipb.end == ipb.beg) |
751 |
ipb.beg = NULL; |
752 |
753 |
} else |
754 |
ipb.chr = *ipb.pos; |
755 |
756 |
757 |
758 |
advinp() /* move home to current position */ |
759 |
760 |
ipb.beg = ipb.pos; |
761 |
762 |
763 |
764 |
resetinp() /* rewind position and advance 1 */ |
765 |
766 |
if (ipb.beg == NULL) /* full */ |
767 |
ipb.beg = ipb.end; |
768 |
ipb.pos = ipb.beg; |
769 |
770 |
if (++ipb.beg >= &inpbuf[INBSIZ]) |
771 |
ipb.beg = inpbuf; |
772 |
scaninp(); |
773 |
774 |
775 |
776 |
void |
777 |
eputs(msg) |
778 |
char *msg; |
779 |
780 |
fputs(msg, stderr); |
781 |
782 |
783 |
784 |
void |
785 |
wputs(msg) |
786 |
char *msg; |
787 |
788 |
if (!nowarn) |
789 |
eputs(msg); |
790 |
791 |
792 |
793 |
void |
794 |
quit(code) |
795 |
int code; |
796 |
797 |
exit(code); |
798 |
