1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: rcalc.c,v 1.12 2004/03/28 20:33:12 schorsch Exp $"; |
3 |
#endif |
4 |
5 |
* rcalc.c - record calculator program. |
6 |
7 |
* 9/11/87 |
8 |
9 |
10 |
#include <stdlib.h> |
11 |
#include <fcntl.h> |
12 |
#include <stdio.h> |
13 |
#include <string.h> |
14 |
#include <math.h> |
15 |
#include <ctype.h> |
16 |
17 |
#include "platform.h" |
18 |
#include "rterror.h" |
19 |
#include "rtmisc.h" |
20 |
#include "rtio.h" |
21 |
#include "calcomp.h" |
22 |
23 |
#define isnum(c) (isdigit(c) || (c)=='-' || (c)=='.' \ |
24 |
|| (c)=='+' || (c)=='e' || (c)=='E') |
25 |
26 |
#define isblnk(c) (igneol ? isspace(c) : (c)==' '||(c)=='\t') |
27 |
28 |
#define INBSIZ 4096 /* longest record */ |
29 |
#define MAXCOL 32 /* number of columns recorded */ |
30 |
31 |
/* field type specifications */ |
32 |
#define F_NUL 0 /* empty */ |
33 |
#define F_TYP 0x7000 /* mask for type */ |
34 |
#define F_WID 0x0fff /* mask for width */ |
35 |
#define T_LIT 0x1000 /* string literal */ |
36 |
#define T_STR 0x2000 /* string variable */ |
37 |
#define T_NUM 0x3000 /* numeric value */ |
38 |
39 |
struct strvar { /* string variable */ |
40 |
char *name; |
41 |
char *val; |
42 |
char *preset; |
43 |
struct strvar *next; |
44 |
45 |
46 |
struct field { /* record format structure */ |
47 |
int type; /* type of field (& width) */ |
48 |
union { |
49 |
char *sl; /* string literal */ |
50 |
struct strvar *sv; /* string variable */ |
51 |
char *nv; /* numeric variable */ |
52 |
EPNODE *ne; /* numeric expression */ |
53 |
} f; /* field contents */ |
54 |
struct field *next; /* next field in record */ |
55 |
56 |
57 |
#define savqstr(s) strcpy(emalloc(strlen(s)+1),s) |
58 |
#define freqstr(s) efree(s) |
59 |
60 |
static int getinputrec(FILE *fp); |
61 |
static void scaninp(void), advinp(void), resetinp(void); |
62 |
static void putrec(void), putout(void), nbsynch(void); |
63 |
static int getrec(void); |
64 |
static void execute(char *file); |
65 |
static void initinp(FILE *fp); |
66 |
static void svpreset(char *eqn); |
67 |
static void readfmt(char *spec, int output); |
68 |
static int readfield(char **pp); |
69 |
static int getfield(struct field *f); |
70 |
static void chanset(int n, double v); |
71 |
static void bchanset(int n, double v); |
72 |
static struct strvar* getsvar(char *svname); |
73 |
static double l_in(char *); |
74 |
75 |
struct field *inpfmt = NULL; /* input record format */ |
76 |
struct field *outfmt = NULL; /* output record structure */ |
77 |
struct strvar *svhead = NULL; /* string variables */ |
78 |
79 |
int blnkeq = 1; /* blanks compare equal? */ |
80 |
int igneol = 0; /* ignore end of line? */ |
81 |
int passive = 0; /* passive mode (transmit unmatched input) */ |
82 |
char sepchar = '\t'; /* input/output separator */ |
83 |
int noinput = 0; /* no input records? */ |
84 |
int nbicols = 0; /* number of binary input columns */ |
85 |
int bocols = 0; /* produce binary output columns */ |
86 |
char inpbuf[INBSIZ]; /* input buffer */ |
87 |
double colval[MAXCOL]; /* input column values */ |
88 |
unsigned long colflg = 0; /* column retrieved flags */ |
89 |
int colpos; /* output column position */ |
90 |
91 |
int nowarn = 0; /* non-fatal diagnostic output */ |
92 |
int unbuff = 0; /* unbuffered output (flush each record) */ |
93 |
94 |
struct { |
95 |
FILE *fin; /* input file */ |
96 |
int chr; /* next character */ |
97 |
char *beg; /* home position */ |
98 |
char *pos; /* scan position */ |
99 |
char *end; /* read position */ |
100 |
} ipb; /* circular lookahead buffer */ |
101 |
102 |
103 |
int |
104 |
main( |
105 |
int argc, |
106 |
char *argv[] |
107 |
108 |
109 |
int i; |
110 |
111 |
esupport |= E_VARIABLE|E_FUNCTION|E_INCHAN|E_OUTCHAN|E_RCONST; |
112 |
esupport &= ~(E_REDEFW); |
113 |
114 |
#ifdef BIGGERLIB |
115 |
biggerlib(); |
116 |
#endif |
117 |
varset("PI", ':', 3.14159265358979323846); |
118 |
funset("in", 1, '=', &l_in); |
119 |
120 |
for (i = 1; i < argc && argv[i][0] == '-'; i++) |
121 |
switch (argv[i][1]) { |
122 |
case 'b': |
123 |
blnkeq = !blnkeq; |
124 |
break; |
125 |
case 'l': |
126 |
igneol = !igneol; |
127 |
break; |
128 |
case 'p': |
129 |
passive = !passive; |
130 |
break; |
131 |
case 't': |
132 |
sepchar = argv[i][2]; |
133 |
break; |
134 |
case 's': |
135 |
svpreset(argv[++i]); |
136 |
break; |
137 |
case 'f': |
138 |
fcompile(argv[++i]); |
139 |
break; |
140 |
case 'e': |
141 |
scompile(argv[++i], NULL, 0); |
142 |
break; |
143 |
case 'n': |
144 |
noinput = 1; |
145 |
break; |
146 |
case 'i': |
147 |
switch (argv[i][2]) { |
148 |
case '\0': |
149 |
nbicols = 0; |
150 |
readfmt(argv[++i], 0); |
151 |
break; |
152 |
case 'a': |
153 |
nbicols = 0; |
154 |
break; |
155 |
case 'd': |
156 |
if (isdigit(argv[i][3])) |
157 |
nbicols = atoi(argv[i]+3); |
158 |
else |
159 |
nbicols = 1; |
160 |
if (nbicols*sizeof(double) > INBSIZ) { |
161 |
eputs(argv[0]); |
162 |
eputs(": too many input columns\n"); |
163 |
quit(1); |
164 |
165 |
break; |
166 |
case 'f': |
167 |
168 |
nbicols = -atoi(argv[i]+3); |
169 |
else |
170 |
nbicols = -1; |
171 |
if (-nbicols*sizeof(float) > INBSIZ) { |
172 |
eputs(argv[0]); |
173 |
174 |
quit(1); |
175 |
176 |
break; |
177 |
default: |
178 |
goto userr; |
179 |
180 |
break; |
181 |
case 'o': |
182 |
183 |
case '\0': |
184 |
bocols = 0; |
185 |
readfmt(argv[++i], 1); |
186 |
break; |
187 |
case 'a': |
188 |
bocols = 0; |
189 |
break; |
190 |
case 'd': |
191 |
bocols = 1; |
192 |
break; |
193 |
case 'f': |
194 |
bocols = -1; |
195 |
break; |
196 |
197 |
break; |
198 |
case 'w': |
199 |
nowarn = !nowarn; |
200 |
break; |
201 |
case 'u': |
202 |
unbuff = !unbuff; |
203 |
break; |
204 |
default:; |
205 |
userr: |
206 |
eputs("Usage: "); |
207 |
eputs(argv[0]); |
208 |
eputs(" [-b][-l][-n][-p][-w][-u][-tS][-s svar=sval][-e expr][-f source][-i infmt][-o outfmt] [file]\n"); |
209 |
quit(1); |
210 |
211 |
212 |
if (noinput) { /* produce a single output record */ |
213 |
eclock++; |
214 |
putout(); |
215 |
quit(0); |
216 |
217 |
218 |
if (blnkeq) /* for efficiency */ |
219 |
nbsynch(); |
220 |
221 |
if (i == argc) /* from stdin */ |
222 |
execute(NULL); |
223 |
else /* from one or more files */ |
224 |
for ( ; i < argc; i++) |
225 |
execute(argv[i]); |
226 |
227 |
quit(0); |
228 |
return 0; /* pro forma return */ |
229 |
230 |
231 |
232 |
static void |
233 |
nbsynch(void) /* non-blank starting synch character */ |
234 |
235 |
if (inpfmt == NULL || (inpfmt->type & F_TYP) != T_LIT) |
236 |
return; |
237 |
while (isblnk(*inpfmt->f.sl)) |
238 |
inpfmt->f.sl++; |
239 |
if (!*inpfmt->f.sl) |
240 |
inpfmt = inpfmt->next; |
241 |
242 |
243 |
244 |
static int |
245 |
getinputrec( /* get next input record */ |
246 |
FILE *fp |
247 |
248 |
249 |
if (inpfmt != NULL) |
250 |
return(getrec()); |
251 |
if (nbicols > 0) |
252 |
return(fread(inpbuf, sizeof(double), |
253 |
nbicols, fp) == nbicols); |
254 |
if (nbicols < 0) |
255 |
return(fread(inpbuf, sizeof(float), |
256 |
-nbicols, fp) == -nbicols); |
257 |
return(fgets(inpbuf, INBSIZ, fp) != NULL); |
258 |
259 |
260 |
261 |
static void |
262 |
execute( /* process a file */ |
263 |
char *file |
264 |
265 |
266 |
int conditional = vardefined("cond"); |
267 |
long nrecs = 0; |
268 |
long nout = 0; |
269 |
FILE *fp; |
270 |
271 |
if (file == NULL) |
272 |
fp = stdin; |
273 |
else if ((fp = fopen(file, "r")) == NULL) { |
274 |
eputs(file); |
275 |
eputs(": cannot open\n"); |
276 |
quit(1); |
277 |
278 |
279 |
initinp(fp); |
280 |
281 |
while (getinputrec(fp)) { |
282 |
varset("recno", '=', (double)++nrecs); |
283 |
colflg = 0; |
284 |
eclock++; |
285 |
if (!conditional || varvalue("cond") > 0.0) { |
286 |
varset("outno", '=', (double)++nout); |
287 |
putout(); |
288 |
289 |
290 |
fclose(fp); |
291 |
292 |
293 |
294 |
static void |
295 |
putout(void) /* produce an output record */ |
296 |
297 |
298 |
colpos = 0; |
299 |
if (outfmt != NULL) |
300 |
putrec(); |
301 |
else if (bocols) |
302 |
chanout(bchanset); |
303 |
else |
304 |
chanout(chanset); |
305 |
if (colpos && !bocols) |
306 |
putchar('\n'); |
307 |
if (unbuff) |
308 |
fflush(stdout); |
309 |
310 |
311 |
312 |
static double |
313 |
l_in(char *funame) /* function call for $channel */ |
314 |
315 |
int n; |
316 |
register char *cp; |
317 |
/* get argument as integer */ |
318 |
n = (int)(argument(1) + .5); |
319 |
if (n != 0) /* return channel value */ |
320 |
return(chanvalue(n)); |
321 |
/* determine number of channels */ |
322 |
if (noinput || inpfmt != NULL) |
323 |
return(0); |
324 |
if (nbicols > 0) |
325 |
return(nbicols); |
326 |
if (nbicols < 0) |
327 |
return(-nbicols); |
328 |
cp = inpbuf; /* need to count */ |
329 |
for (n = 0; *cp; ) |
330 |
if (blnkeq && isspace(sepchar)) { |
331 |
while (isspace(*cp)) |
332 |
cp++; |
333 |
n += *cp != '\0'; |
334 |
while (*cp && !isspace(*cp)) |
335 |
cp++; |
336 |
} else { |
337 |
n += *cp != '\n'; |
338 |
while (*cp && *cp++ != sepchar) |
339 |
340 |
341 |
return(n); |
342 |
343 |
344 |
double |
345 |
chanvalue( /* return value for column n */ |
346 |
int n |
347 |
348 |
349 |
int i; |
350 |
351 |
352 |
if (noinput || inpfmt != NULL) { |
353 |
eputs("no column input\n"); |
354 |
quit(1); |
355 |
356 |
if (n < 1) { |
357 |
eputs("illegal channel number\n"); |
358 |
quit(1); |
359 |
360 |
if (nbicols > 0) { |
361 |
if (n > nbicols) |
362 |
return(0.0); |
363 |
cp = inpbuf + (n-1)*sizeof(double); |
364 |
return(*(double *)cp); |
365 |
366 |
if (nbicols < 0) { |
367 |
if (n > -nbicols) |
368 |
return(0.0); |
369 |
cp = inpbuf + (n-1)*sizeof(float); |
370 |
return(*(float *)cp); |
371 |
372 |
if (n <= MAXCOL && colflg & 1L<<(n-1)) |
373 |
return(colval[n-1]); |
374 |
375 |
cp = inpbuf; |
376 |
for (i = 1; i < n; i++) |
377 |
378 |
379 |
cp++; |
380 |
381 |
cp++; |
382 |
} else |
383 |
384 |
385 |
386 |
while (isspace(*cp)) /* some atof()'s don't like tabs */ |
387 |
cp++; |
388 |
389 |
if (n <= MAXCOL) { |
390 |
colflg |= 1L<<(n-1); |
391 |
return(colval[n-1] = atof(cp)); |
392 |
} else |
393 |
return(atof(cp)); |
394 |
395 |
396 |
397 |
void |
398 |
chanset( /* output column n */ |
399 |
int n, |
400 |
double v |
401 |
402 |
403 |
if (colpos == 0) /* no leading separator */ |
404 |
colpos = 1; |
405 |
while (colpos < n) { |
406 |
putchar(sepchar); |
407 |
colpos++; |
408 |
409 |
printf("%.9g", v); |
410 |
411 |
412 |
413 |
void |
414 |
bchanset( /* output binary channel n */ |
415 |
int n, |
416 |
double v |
417 |
418 |
419 |
static char zerobuf[sizeof(double)]; |
420 |
421 |
while (++colpos < n) |
422 |
fwrite(zerobuf, |
423 |
bocols>0 ? sizeof(double) : sizeof(float), |
424 |
1, stdout); |
425 |
if (bocols > 0) |
426 |
fwrite(&v, sizeof(double), 1, stdout); |
427 |
else { |
428 |
float fval = v; |
429 |
fwrite(&fval, sizeof(float), 1, stdout); |
430 |
431 |
432 |
433 |
434 |
static void |
435 |
readfmt( /* read record format */ |
436 |
char *spec, |
437 |
int output |
438 |
439 |
440 |
int fd; |
441 |
char *inptr; |
442 |
struct field fmt; |
443 |
int res; |
444 |
register struct field *f; |
445 |
/* check for inline format */ |
446 |
for (inptr = spec; *inptr; inptr++) |
447 |
if (*inptr == '$') |
448 |
break; |
449 |
if (*inptr) /* inline */ |
450 |
inptr = spec; |
451 |
else { /* from file */ |
452 |
if ((fd = open(spec, 0)) == -1) { |
453 |
eputs(spec); |
454 |
455 |
quit(1); |
456 |
457 |
res = read(fd, inpbuf+1, INBSIZ-1); |
458 |
if (res <= 0 || res >= INBSIZ-1) { |
459 |
eputs(spec); |
460 |
if (res < 0) |
461 |
eputs(": read error\n"); |
462 |
else if (res == 0) |
463 |
eputs(": empty file\n"); |
464 |
else if (res >= INBSIZ-1) |
465 |
eputs(": format too long\n"); |
466 |
quit(1); |
467 |
468 |
close(fd); |
469 |
(inptr=inpbuf+1)[res] = '\0'; |
470 |
471 |
f = &fmt; /* get fields */ |
472 |
while ((res = readfield(&inptr)) != F_NUL) { |
473 |
f->next = (struct field *)emalloc(sizeof(struct field)); |
474 |
f = f->next; |
475 |
f->type = res; |
476 |
switch (res & F_TYP) { |
477 |
case T_LIT: |
478 |
f->f.sl = savqstr(inpbuf); |
479 |
break; |
480 |
case T_STR: |
481 |
f->f.sv = getsvar(inpbuf); |
482 |
break; |
483 |
case T_NUM: |
484 |
if (output) |
485 |
f->f.ne = eparse(inpbuf); |
486 |
else |
487 |
f->f.nv = savestr(inpbuf); |
488 |
break; |
489 |
490 |
/* add final newline if necessary */ |
491 |
if (!igneol && *inptr == '\0' && inptr[-1] != '\n') |
492 |
inptr = "\n"; |
493 |
494 |
f->next = NULL; |
495 |
if (output) |
496 |
outfmt = fmt.next; |
497 |
else |
498 |
inpfmt = fmt.next; |
499 |
500 |
501 |
502 |
static int |
503 |
readfield( /* get next field in format */ |
504 |
register char **pp |
505 |
506 |
507 |
int type = F_NUL; |
508 |
int width = 0; |
509 |
510 |
511 |
cp = inpbuf; |
512 |
while (cp < &inpbuf[INBSIZ-1] && **pp != '\0') { |
513 |
width++; |
514 |
switch (type) { |
515 |
case F_NUL: |
516 |
if (**pp == '$') { |
517 |
(*pp)++; |
518 |
width++; |
519 |
if (**pp == '{') { |
520 |
type = T_NUM; |
521 |
(*pp)++; |
522 |
continue; |
523 |
} else if (**pp == '(') { |
524 |
type = T_STR; |
525 |
(*pp)++; |
526 |
continue; |
527 |
} else if (**pp != '$') { |
528 |
eputs("format error\n"); |
529 |
quit(1); |
530 |
531 |
width--; |
532 |
533 |
type = T_LIT; |
534 |
*cp++ = *(*pp)++; |
535 |
continue; |
536 |
case T_LIT: |
537 |
538 |
width--; |
539 |
break; |
540 |
541 |
*cp++ = *(*pp)++; |
542 |
continue; |
543 |
case T_NUM: |
544 |
if (**pp == '}') { |
545 |
(*pp)++; |
546 |
break; |
547 |
548 |
if (!isspace(**pp)) |
549 |
*cp++ = **pp; |
550 |
(*pp)++; |
551 |
continue; |
552 |
case T_STR: |
553 |
if (**pp == ')') { |
554 |
(*pp)++; |
555 |
break; |
556 |
557 |
558 |
*cp++ = **pp; |
559 |
(*pp)++; |
560 |
continue; |
561 |
562 |
break; |
563 |
564 |
*cp = '\0'; |
565 |
return(type | width); |
566 |
567 |
568 |
569 |
struct strvar * |
570 |
getsvar( /* get string variable */ |
571 |
char *svname |
572 |
573 |
574 |
register struct strvar *sv; |
575 |
576 |
for (sv = svhead; sv != NULL; sv = sv->next) |
577 |
if (!strcmp(sv->name, svname)) |
578 |
return(sv); |
579 |
sv = (struct strvar *)emalloc(sizeof(struct strvar)); |
580 |
sv->name = savqstr(svname); |
581 |
sv->val = sv->preset = NULL; |
582 |
sv->next = svhead; |
583 |
svhead = sv; |
584 |
return(sv); |
585 |
586 |
587 |
588 |
static void |
589 |
svpreset( /* preset a string variable */ |
590 |
char *eqn |
591 |
592 |
593 |
594 |
register char *val; |
595 |
596 |
for (val = eqn; *val != '='; val++) |
597 |
if (!*val) |
598 |
return; |
599 |
*val++ = '\0'; |
600 |
sv = getsvar(eqn); |
601 |
if (sv->preset != NULL) |
602 |
freqstr(sv->preset); |
603 |
if (sv->val != NULL) |
604 |
freqstr(sv->val); |
605 |
sv->val = sv->preset = savqstr(val); |
606 |
*--val = '='; |
607 |
608 |
609 |
610 |
static void |
611 |
clearrec(void) /* clear input record variables */ |
612 |
613 |
614 |
615 |
for (f = inpfmt; f != NULL; f = f->next) |
616 |
switch (f->type & F_TYP) { |
617 |
case T_NUM: |
618 |
dremove(f->f.nv); |
619 |
break; |
620 |
case T_STR: |
621 |
if (f->f.sv->val != f->f.sv->preset) { |
622 |
freqstr(f->f.sv->val); |
623 |
f->f.sv->val = f->f.sv->preset; |
624 |
625 |
break; |
626 |
627 |
628 |
629 |
630 |
static int |
631 |
getrec(void) /* get next record from file */ |
632 |
633 |
int eatline; |
634 |
635 |
636 |
while (ipb.chr != EOF) { |
637 |
eatline = !igneol && ipb.chr != '\n'; |
638 |
if (blnkeq) /* beware of nbsynch() */ |
639 |
while (isblnk(ipb.chr)) |
640 |
resetinp(); |
641 |
clearrec(); /* start with fresh record */ |
642 |
643 |
if (getfield(f) == -1) |
644 |
break; |
645 |
if (f == NULL) { |
646 |
advinp(); /* got one! */ |
647 |
return(1); |
648 |
649 |
resetinp(); /* eat false start */ |
650 |
if (eatline) { /* eat rest of line */ |
651 |
while (ipb.chr != '\n') { |
652 |
if (ipb.chr == EOF) |
653 |
return(0); |
654 |
resetinp(); |
655 |
656 |
resetinp(); |
657 |
658 |
659 |
return(0); |
660 |
661 |
662 |
663 |
static int |
664 |
getfield( /* get next field */ |
665 |
register struct field *f |
666 |
667 |
668 |
static char buf[RMAXWORD+1]; /* no recursion! */ |
669 |
int delim, inword; |
670 |
double d; |
671 |
char *np; |
672 |
673 |
674 |
675 |
case T_LIT: |
676 |
cp = f->f.sl; |
677 |
do { |
678 |
if (blnkeq && isblnk(*cp)) { |
679 |
if (!isblnk(ipb.chr)) |
680 |
return(-1); |
681 |
do |
682 |
cp++; |
683 |
while (isblnk(*cp)); |
684 |
do |
685 |
scaninp(); |
686 |
while (isblnk(ipb.chr)); |
687 |
} else if (*cp == ipb.chr) { |
688 |
cp++; |
689 |
scaninp(); |
690 |
} else |
691 |
return(-1); |
692 |
} while (*cp); |
693 |
return(0); |
694 |
case T_STR: |
695 |
if (f->next == NULL || (f->next->type & F_TYP) != T_LIT) |
696 |
delim = EOF; |
697 |
else |
698 |
delim = f->next->f.sl[0]; |
699 |
cp = buf; |
700 |
do { |
701 |
if (ipb.chr == EOF || ipb.chr == '\n') |
702 |
inword = 0; |
703 |
else if (blnkeq && delim != EOF) |
704 |
inword = isblnk(delim) ? |
705 |
!isblnk(ipb.chr) |
706 |
: ipb.chr != delim; |
707 |
else |
708 |
inword = cp-buf < (f->type & F_WID); |
709 |
if (inword) { |
710 |
*cp++ = ipb.chr; |
711 |
scaninp(); |
712 |
713 |
} while (inword && cp < &buf[RMAXWORD]); |
714 |
*cp = '\0'; |
715 |
if (f->f.sv->val == NULL) |
716 |
f->f.sv->val = savqstr(buf); /* first setting */ |
717 |
else if (strcmp(f->f.sv->val, buf)) |
718 |
return(-1); /* doesn't match! */ |
719 |
return(0); |
720 |
case T_NUM: |
721 |
722 |
delim = EOF; |
723 |
else |
724 |
725 |
np = NULL; |
726 |
cp = buf; |
727 |
do { |
728 |
if (!((np==NULL&&isblnk(ipb.chr)) || isnum(ipb.chr))) |
729 |
inword = 0; |
730 |
731 |
732 |
!isblnk(ipb.chr) |
733 |
734 |
else |
735 |
736 |
if (inword) { |
737 |
if (np==NULL && !isblnk(ipb.chr)) |
738 |
np = cp; |
739 |
*cp++ = ipb.chr; |
740 |
scaninp(); |
741 |
742 |
743 |
*cp = '\0'; |
744 |
d = np==NULL ? 0. : atof(np); |
745 |
if (!vardefined(f->f.nv)) |
746 |
varset(f->f.nv, '=', d); /* first setting */ |
747 |
else if ((d = (varvalue(f->f.nv)-d)/(d==0.?1.:d)) > .001 |
748 |
|| d < -.001) |
749 |
750 |
return(0); |
751 |
752 |
return -1; /* pro forma return */ |
753 |
754 |
755 |
756 |
static void |
757 |
putrec(void) /* output a record */ |
758 |
759 |
char fmt[32]; |
760 |
register int n; |
761 |
762 |
int adlast, adnext; |
763 |
764 |
adlast = 0; |
765 |
for (f = outfmt; f != NULL; f = f->next) { |
766 |
adnext = blnkeq && |
767 |
f->next != NULL && |
768 |
!( (f->next->type&F_TYP) == T_LIT && |
769 |
f->next->f.sl[0] == ' ' ); |
770 |
771 |
case T_LIT: |
772 |
fputs(f->f.sl, stdout); |
773 |
adlast = f->f.sl[(f->type&F_WID)-1] != ' '; |
774 |
break; |
775 |
case T_STR: |
776 |
if (f->f.sv->val == NULL) { |
777 |
eputs(f->f.sv->name); |
778 |
eputs(": undefined string\n"); |
779 |
quit(1); |
780 |
781 |
n = (int)(f->type & F_WID) - strlen(f->f.sv->val); |
782 |
if (adlast) |
783 |
fputs(f->f.sv->val, stdout); |
784 |
if (!(adlast && adnext)) |
785 |
while (n-- > 0) |
786 |
putchar(' '); |
787 |
if (!adlast) |
788 |
789 |
adlast = 1; |
790 |
break; |
791 |
case T_NUM: |
792 |
n = f->type & F_WID; |
793 |
if (adlast && adnext) |
794 |
strcpy(fmt, "%g"); |
795 |
else if (adlast) |
796 |
sprintf(fmt, "%%-%dg", n); |
797 |
else |
798 |
sprintf(fmt, "%%%dg", n); |
799 |
printf(fmt, evalue(f->f.ne)); |
800 |
adlast = 1; |
801 |
break; |
802 |
803 |
804 |
805 |
806 |
807 |
static void |
808 |
initinp(FILE *fp) /* prepare lookahead buffer */ |
809 |
810 |
811 |
ipb.fin = fp; |
812 |
ipb.beg = ipb.end = inpbuf; |
813 |
ipb.pos = inpbuf-1; /* position before beginning */ |
814 |
ipb.chr = '\0'; |
815 |
scaninp(); |
816 |
817 |
818 |
819 |
static void |
820 |
scaninp(void) /* scan next character */ |
821 |
822 |
823 |
return; |
824 |
if (++ipb.pos >= &inpbuf[INBSIZ]) |
825 |
ipb.pos = inpbuf; |
826 |
if (ipb.pos == ipb.end) { /* new character */ |
827 |
if ((ipb.chr = getc(ipb.fin)) != EOF) { |
828 |
*ipb.end = ipb.chr; |
829 |
if (++ipb.end >= &inpbuf[INBSIZ]) |
830 |
ipb.end = inpbuf; |
831 |
if (ipb.end == ipb.beg) |
832 |
ipb.beg = NULL; |
833 |
834 |
} else |
835 |
ipb.chr = *ipb.pos; |
836 |
837 |
838 |
839 |
static void |
840 |
advinp(void) /* move home to current position */ |
841 |
842 |
ipb.beg = ipb.pos; |
843 |
844 |
845 |
846 |
static void |
847 |
resetinp(void) /* rewind position and advance 1 */ |
848 |
849 |
if (ipb.beg == NULL) /* full */ |
850 |
ipb.beg = ipb.end; |
851 |
ipb.pos = ipb.beg; |
852 |
853 |
if (passive) /* transmit unmatched character? */ |
854 |
fputc(ipb.chr, stdout); |
855 |
if (++ipb.beg >= &inpbuf[INBSIZ]) |
856 |
ipb.beg = inpbuf; |
857 |
scaninp(); |
858 |
859 |
860 |
861 |
void |
862 |
eputs(char *msg) |
863 |
864 |
fputs(msg, stderr); |
865 |
866 |
867 |
868 |
void |
869 |
wputs(char *msg) |
870 |
871 |
if (!nowarn) |
872 |
eputs(msg); |
873 |
874 |
875 |
876 |
void |
877 |
quit(int code) |
878 |
879 |
exit(code); |
880 |
