--- ray/src/cal/rcalc.c 2003/11/05 19:03:03 1.9 +++ ray/src/cal/rcalc.c 2003/11/06 05:39:33 1.10 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rcalc.c,v 1.9 2003/11/05 19:03:03 greg Exp $"; +static const char RCSid[] = "$Id: rcalc.c,v 1.10 2003/11/06 05:39:33 greg Exp $"; #endif /* * rcalc.c - record calculator program. @@ -54,6 +54,7 @@ struct field { /* record format struc #define savqstr(s) strcpy(emalloc(strlen(s)+1),s) #define freqstr(s) efree(s) +static int getinputrec(FILE *fp); static void scaninp(void), advinp(void), resetinp(void); static void putrec(void), putout(void), nbsynch(void); static int getrec(void); @@ -66,6 +67,7 @@ static int getfield(struct field *f); static void chanset(int n, double v); static void bchanset(int n, double v); static struct strvar* getsvar(char *svname); +static double l_in(char *); struct field *inpfmt = NULL; /* input record format */ struct field *outfmt = NULL; /* output record structure */ @@ -109,6 +111,7 @@ char *argv[] biggerlib(); #endif varset("PI", ':', 3.14159265358979323846); + funset("in", 1, '=', &l_in); for (i = 1; i < argc && argv[i][0] == '-'; i++) switch (argv[i][1]) { @@ -230,7 +233,7 @@ nbsynch(void) /* non-blank starting sync } -int +static int getinputrec( /* get next input record */ FILE *fp ) @@ -297,6 +300,38 @@ putout(void) /* produce an output recor fflush(stdout); } + +static double +l_in(char *funame) /* function call for $channel */ +{ + int n; + register char *cp; + /* get argument as integer */ + n = (int)(argument(1) + .5); + if (n != 0) /* return channel value */ + return(chanvalue(n)); + /* determine number of channels */ + if (noinput || inpfmt != NULL) + return(0); + if (nbicols > 0) + return(nbicols); + if (nbicols < 0) + return(-nbicols); + cp = inpbuf; /* need to count */ + for (n = 0; *cp; ) + if (blnkeq && isspace(sepchar)) { + while (isspace(*cp)) + cp++; + n += *cp != '\0'; + while (*cp && !isspace(*cp)) + cp++; + } else { + n += *cp != '\n'; + while (*cp && *cp++ != sepchar) + ; + } + return(n); +} double chanvalue( /* return value for column n */
