--- ray/src/cal/rcalc.c 2003/05/25 05:27:16 1.4 +++ ray/src/cal/rcalc.c 2003/06/08 12:03:09 1.5 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rcalc.c,v 1.4 2003/05/25 05:27:16 greg Exp $"; +static const char RCSid[] = "$Id: rcalc.c,v 1.5 2003/06/08 12:03:09 schorsch Exp $"; #endif /* * rcalc.c - record calculator program. @@ -7,14 +7,13 @@ static const char RCSid[] = "$Id: rcalc.c,v 1.4 2003/0 * 9/11/87 */ -#include - #include - +#include +#include #include - #include +#include "platform.h" #include "calcomp.h" #ifdef CPM @@ -58,8 +57,18 @@ struct field { /* record format struc #define savqstr(s) strcpy(emalloc(strlen(s)+1),s) #define freqstr(s) efree(s) -extern char *strcpy(), *emalloc(), *savestr(); -struct strvar *getsvar(); +static void scaninp(void), advinp(void), resetinp(void); +static void putrec(void), putout(void), nbsynch(void); +static int getrec(void); +static void execute(char *file); +static void initinp(FILE *fp); +static void svpreset(char *eqn); +static void readfmt(char *spec, int output); +static int readfield(char **pp); +static int getfield(struct field *f); +static void chanset(int n, double v); +static void bchanset(int n, double v); +static struct strvar* getsvar(char *svname); struct field *inpfmt = NULL; /* input record format */ struct field *outfmt = NULL; /* output record structure */ @@ -88,9 +97,11 @@ struct { } ipb; /* circular lookahead buffer */ -main(argc, argv) -int argc; -char *argv[]; +int +main( +int argc, +char *argv[] +) { int i; @@ -200,7 +211,8 @@ eputs(" [-b][-l][-n][-w][-u][-tS][-s svar=sval][-e exp } -nbsynch() /* non-blank starting synch character */ +static void +nbsynch(void) /* non-blank starting synch character */ { if (inpfmt == NULL || (inpfmt->type & F_TYP) != T_LIT) return; @@ -212,8 +224,9 @@ nbsynch() /* non-blank starting synch ch int -getinputrec(fp) /* get next input record */ -FILE *fp; +getinputrec( /* get next input record */ +FILE *fp +) { if (inpfmt != NULL) return(getrec()); @@ -227,8 +240,10 @@ FILE *fp; } -execute(file) /* process a file */ -char *file; +static void +execute( /* process a file */ +char *file +) { int conditional = vardefined("cond"); long nrecs = 0; @@ -258,9 +273,9 @@ char *file; } -putout() /* produce an output record */ +static void +putout(void) /* produce an output record */ { - extern void chanset(), bchanset(); colpos = 0; if (outfmt != NULL) @@ -277,8 +292,9 @@ putout() /* produce an output record */ double -chanvalue(n) /* return value for column n */ -int n; +chanvalue( /* return value for column n */ +int n +) { int i; register char *cp; @@ -329,9 +345,10 @@ int n; void -chanset(n, v) /* output column n */ -int n; -double v; +chanset( /* output column n */ +int n, +double v +) { if (colpos == 0) /* no leading separator */ colpos = 1; @@ -344,9 +361,10 @@ double v; void -bchanset(n, v) /* output binary channel n */ -int n; -double v; +bchanset( /* output binary channel n */ +int n, +double v +) { static char zerobuf[sizeof(double)]; @@ -363,9 +381,11 @@ double v; } -readfmt(spec, output) /* read record format */ -char *spec; -int output; +static void +readfmt( /* read record format */ +char *spec, +int output +) { int fd; char *inptr; @@ -429,9 +449,10 @@ int output; } -int -readfield(pp) /* get next field in format */ -register char **pp; +static int +readfield( /* get next field in format */ +register char **pp +) { int type = F_NUL; int width = 0; @@ -496,8 +517,9 @@ register char **pp; struct strvar * -getsvar(svname) /* get string variable */ -char *svname; +getsvar( /* get string variable */ +char *svname +) { register struct strvar *sv; @@ -513,8 +535,10 @@ char *svname; } -svpreset(eqn) /* preset a string variable */ -char *eqn; +static void +svpreset( /* preset a string variable */ +char *eqn +) { register struct strvar *sv; register char *val; @@ -533,7 +557,8 @@ char *eqn; } -clearrec() /* clear input record variables */ +static void +clearrec(void) /* clear input record variables */ { register struct field *f; @@ -552,7 +577,8 @@ clearrec() /* clear input record variables */ } -getrec() /* get next record from file */ +static int +getrec(void) /* get next record from file */ { int eatline; register struct field *f; @@ -585,8 +611,10 @@ getrec() /* get next re } -getfield(f) /* get next field */ -register struct field *f; +static int +getfield( /* get next field */ +register struct field *f +) { static char buf[MAXWORD+1]; /* no recursion! */ int delim, inword; @@ -672,10 +700,12 @@ register struct field *f; return(-1); /* doesn't match! */ return(0); } + return -1; /* pro forma return */ } -putrec() /* output a record */ +static void +putrec(void) /* output a record */ { char fmt[32]; register int n; @@ -725,8 +755,9 @@ putrec() /* output a re } -initinp(fp) /* prepare lookahead buffer */ -FILE *fp; +static void +initinp(FILE *fp) /* prepare lookahead buffer */ + { ipb.fin = fp; ipb.beg = ipb.end = inpbuf; @@ -736,7 +767,8 @@ FILE *fp; } -scaninp() /* scan next character */ +static void +scaninp(void) /* scan next character */ { if (ipb.chr == EOF) return; @@ -755,13 +787,15 @@ scaninp() /* scan next character } -advinp() /* move home to current position */ +static void +advinp(void) /* move home to current position */ { ipb.beg = ipb.pos; } -resetinp() /* rewind position and advance 1 */ +static void +resetinp(void) /* rewind position and advance 1 */ { if (ipb.beg == NULL) /* full */ ipb.beg = ipb.end; @@ -774,16 +808,14 @@ resetinp() /* rewind position and void -eputs(msg) -char *msg; +eputs(char *msg) { fputs(msg, stderr); } void -wputs(msg) -char *msg; +wputs(char *msg) { if (!nowarn) eputs(msg); @@ -791,8 +823,7 @@ char *msg; void -quit(code) -int code; +quit(int code) { exit(code); }
