root/radiance/ray/src/cal/rcalc.c
Revision 1.39 - (view) (download) (annotate) - [selected]
Fri Feb 23 03:47:57 2024 UTC (14 months, 4 weeks ago) by greg
Changes since 1.38: +3 -1 lines
Diff to previous 1.38
Fri Mar 10 17:38:01 2023 UTC (2 years, 2 months ago) by greg
Changes since 1.37: +2 -1 lines
Diff to previous 1.37 , to selected 1.39
perf(rcalc): don't bother to reduce constant expressions with -n option
Mon Feb 6 22:40:21 2023 UTC (2 years, 3 months ago) by greg
Changes since 1.36: +3 -3 lines
Diff to previous 1.36 , to selected 1.39
Sun Mar 13 16:11:48 2022 UTC (3 years, 2 months ago) by greg
Changes since 1.35: +50 -47 lines
Diff to previous 1.35 , to selected 1.39
feat(rcalc): Added warning and embedded message when buffer overflows with -P
Sat Mar 12 19:20:11 2022 UTC (3 years, 2 months ago) by greg
Changes since 1.34: +20 -29 lines
Diff to previous 1.34 , to selected 1.39
refactor(rcalc): Simplified buffer interface a bit
Sat Mar 12 18:14:45 2022 UTC (3 years, 2 months ago) by greg
Changes since 1.33: +6 -4 lines
Diff to previous 1.33 , to selected 1.39
fix(rcalc): Slight improvement for buffer overflow in -P mode
Sat Mar 12 15:50:13 2022 UTC (3 years, 2 months ago) by greg
Changes since 1.32: +18 -10 lines
Diff to previous 1.32 , to selected 1.39
feat(rcalc): Added check for "cond" variable defined as constant
Fri Mar 11 22:50:13 2022 UTC (3 years, 2 months ago) by greg
Changes since 1.31: +54 -29 lines
Diff to previous 1.31 , to selected 1.39
feat(rcalc): Added -P option to pass records where cond evaluates <= 0
Mon Feb 21 23:00:55 2022 UTC (3 years, 2 months ago) by greg
Changes since 1.30: +157 -157 lines
Diff to previous 1.30 , to selected 1.39
refactor(rcalc): Replaced fputc() call with putchar() and tidied up tabs
Tue Dec 10 19:00:26 2019 UTC (5 years, 5 months ago) by greg
Changes since 1.29: +10 -10 lines
Diff to previous 1.29 , to selected 1.39
Minor logic improvement -- should not affect behavior
Sun May 19 21:15:25 2019 UTC (6 years ago) by greg
Changes since 1.28: +12 -12 lines
Diff to previous 1.28 , to selected 1.39
Further efficiency improvements and eliminated calls to tolower()
Sun May 19 20:02:27 2019 UTC (6 years ago) by greg
Changes since 1.27: +9 -4 lines
Diff to previous 1.27 , to selected 1.39
Minor optimization -- don't bother setting variables that aren't used
Thu Aug 18 00:52:47 2016 UTC (8 years, 9 months ago) by greg
CVS Tags: rad5R1, rad5R2
Changes since 1.26: +6 -6 lines
Diff to previous 1.26 , to selected 1.39
Thu Mar 24 18:48:28 2016 UTC (9 years, 2 months ago) by greg
Changes since 1.25: +14 -1 lines
Diff to previous 1.25 , to selected 1.39
Added -in options to commands for manual EOF specification
Sat May 10 01:48:14 2014 UTC (11 years ago) by greg
Changes since 1.24: +8 -5 lines
Diff to previous 1.24 , to selected 1.39
Improvement on last change for many-digit numbers
Sat May 10 01:27:14 2014 UTC (11 years ago) by greg
Changes since 1.23: +15 -6 lines
Diff to previous 1.23 , to selected 1.39
More adaptive handling of real output format (integers and high-precision)
Sun Mar 9 20:07:27 2014 UTC (11 years, 2 months ago) by greg
Changes since 1.22: +23 -18 lines
Diff to previous 1.22 , to selected 1.39
Added flockfile calls and fixed SET_FILE_BINARY usage for consistency
Thu Dec 19 16:38:12 2013 UTC (11 years, 5 months ago) by greg
Changes since 1.21: +11 -5 lines
Diff to previous 1.21 , to selected 1.39
Sun Jun 14 00:33:16 2009 UTC (15 years, 11 months ago) by greg
CVS Tags: rad4R0, rad4R1
Changes since 1.20: +3 -2 lines
Diff to previous 1.20 , to selected 1.39
Sat Dec 23 17:27:45 2006 UTC (18 years, 5 months ago) by greg
Changes since 1.19: +56 -38 lines
Diff to previous 1.19 , to selected 1.39
Tue Jun 14 01:25:02 2005 UTC (19 years, 11 months ago) by greg
Changes since 1.18: +5 -2 lines
Diff to previous 1.18 , to selected 1.39
Fixed bug in rcalc with -l option where it sometimes hung
Thu Jun 2 04:47:27 2005 UTC (19 years, 11 months ago) by greg
Changes since 1.17: +9 -2 lines
Diff to previous 1.17 , to selected 1.39
Wed Feb 16 17:20:22 2005 UTC (20 years, 3 months ago) by greg
Changes since 1.16: +6 -1 lines
Diff to previous 1.16 , to selected 1.39
Added error check for files given with -n option
Fri Dec 10 05:52:14 2004 UTC (20 years, 5 months ago) by greg
Changes since 1.15: +2 -2 lines
Diff to previous 1.15 , to selected 1.39
Increased maximum input buffer size to 16 Kbytes
Thu Dec 9 22:09:40 2004 UTC (20 years, 5 months ago) by greg
Changes since 1.14: +2 -2 lines
Diff to previous 1.14 , to selected 1.39
Fixed bug for input lines containing only blanks
Mon Oct 11 10:02:15 2004 UTC (20 years, 7 months ago) by greg
Changes since 1.13: +4 -4 lines
Diff to previous 1.13 , to selected 1.39
Wed Jun 9 16:00:13 2004 UTC (20 years, 11 months ago) by greg
Changes since 1.12: +14 -9 lines
Diff to previous 1.12 , to selected 1.39
Sun Mar 28 20:33:12 2004 UTC (21 years, 1 month ago) by schorsch
Changes since 1.11: +4 -2 lines
Diff to previous 1.11 , to selected 1.39
Fri Nov 14 17:31:24 2003 UTC (21 years, 6 months ago) by schorsch
Diff to previous 1.10 , to selected 1.39
Reduced compile warnings.
Thu Nov 6 05:39:33 2003 UTC (21 years, 6 months ago) by greg
Changes since 1.9: +37 -2 lines
Diff to previous 1.9 , to selected 1.39
Wed Nov 5 19:03:03 2003 UTC (21 years, 6 months ago) by greg
Changes since 1.8: +12 -2 lines
Diff to previous 1.8 , to selected 1.39
Added check for too many input columns for binary buffer
Fri Aug 1 14:14:23 2003 UTC (21 years, 9 months ago) by schorsch
Changes since 1.7: +1 -5 lines
Diff to previous 1.7 , to selected 1.39
Eliminated CPM, MAC, and UNIX conditional compiles.
Sun Jul 27 22:12:01 2003 UTC (21 years, 10 months ago) by schorsch
Diff to previous 1.6 , to selected 1.39
Thu Jul 3 22:41:44 2003 UTC (21 years, 10 months ago) by schorsch
Changes since 1.5: +4 -4 lines
Diff to previous 1.5 , to selected 1.39
Sun Jun 8 12:03:09 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 1.4: +82 -51 lines
Diff to previous 1.4 , to selected 1.39
Sun May 25 05:27:16 2003 UTC (22 years ago) by greg
Diff to previous 1.3 , to selected 1.39
Bug fix in latest change that caused newlines to disappear from output
Sun Apr 27 06:08:03 2003 UTC (22 years, 1 month ago) by greg
Changes since 1.2: +97 -7 lines
Diff to previous 1.2 , to selected 1.39
Fri Feb 28 20:29:01 2003 UTC (22 years, 2 months ago) by greg
Diff to previous 1.1 , to selected 1.39
Removed redefinition warning to get back old rcalc behavior
Sat Feb 22 02:07:20 2003 UTC (22 years, 3 months ago) by greg
Diff to selected 1.39
